Octane 2x600MHz R14K 768MB V8
archaic
Unread postby archaic » Fri Sep 16, 2016 2:52 pm
It has been a long while since I was on here. I am posting up the hinv for the only Octane that I have left. I seem to have kept the wrong chassis as the v1.2 that I have will not allow me to use the PCI cardcage that is installed in the machine. I also thought that this configuration (minus the cardcage) wasn't supposed to work either. This is being posted from the Octane BTW.
      PM20600MHZ Board: barcode MNW046     part 030-1778-001 rev  C
            IP30 Board: barcode KSF463     part 030-1467-001 rev  D
    PWR.SPPLY.ER Board: barcode AAE9290784 part 060-0035-002 rev  A
             FP1 Board: barcode DZH559     part 030-0891-003 rev  B
        XTALKPCI Board: barcode GPZ089     part 030-0952-005 rev  C
          ODY128 Board: barcode KWC927     part 030-1404-003 rev  A
2 600 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 768 Mbytes
Xbow ASIC: Revision 1.2
Graphics board: V8
Gigabit Ethernet: eg0, PCI slot 2, firmware version 0.0.0
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 2
   Managed (":0.0") 1920x1200
   BUZZ version A.1
   PB&J version 1
   128MB memory
      Banks: 4, CAS latency: 3
    Monitor 0 type: Unknown
    Video Output: 1920 pixels, 1200 lines, 60.02Hz (1920x1200_60)
    Video Format Flags:  (none)
    Sync Disabled
    Using Gamma Map 0
Patrick
- You have got to be kidding... -
Re: Octane 2x600MHz R14K 768MB V8
Unread postby dexter1 » Mon Sep 19, 2016 4:10 am
Good to see you again Archaic. A dual 600 with 1.2 Xbow? That's something i haven't seen before...
archaic
Unread postby archaic » Mon Sep 19, 2016 5:30 pm
dexter1 wrote:Good to see you again Archaic. A dual 600 with 1.2 Xbow? That's something i haven't seen before...
I haven't either. All of my gear has been in storage for years, so I wasn't sure that anything was going to work. I think I just stuck all the parts that I had left in this chassis and it went into a box. I powered it on and it worked. I have had to reload it 4 times because the old hard drives that I had kept giving up the ghost. What's funny is all the hard drives that I had from DELL servers went bad, and all of the HP dives appear to be working fine. Go figure...
Patrick
