Indigo, R4400 100Mhz, 192 Mb, GR2-XS
twix
Unread postby twix » Wed Sep 14, 2016 2:43 pm
Thanks to FlasBurn (13W3 to VGA cable), Dexter1 (keyboard) and Ian (memory), my Indigo is now up and running using XS graphics and Irix 6.2. I've used a HP widescreen LCD monitor to display the output from the XS, and it looks really good. No modification of the 13W3 to VGA cable was required.
The disk installed contained a very basic 6.2 setup and was configured to run an Apache webserver (and nothing else). Probably better to install 6.5, I think?
hinv -v:
1 100 MHZ IP20 Processor
CPU: MIPS R4000 Processor Chip Revision: 2.2
On-board serial ports: 2
Data cache size: 8 Kbytes
Instruction cache size: 8 Kbytes
Main memory size: 192 Mbytes
Integral SCSI controller 0: Version WD33C93B, revision C
Iris Audio Processor: revision 10
Graphics board: GR2-XS
/usr/gfx/gfxinfo:
        1 GE, 1 RE, 8 bitplanes, 4 auxplanes, 4 cidplanes, no Z-buffer
        GR2 revision 2, VB1.1
        HQ2 rev A, GE7 rev B,  RE3 rev D, VC1 rev B, MC rev B
        unknown, assuming 19" monitor
SGI machines: "wtmc04" Image, "blackjack" Image and "Biofysica" Image
Re: Indigo, R4400 100Mhz, 192 Mb, GR2-XS
Unread postby ClassicHasClass » Wed Sep 14, 2016 10:31 pm
hinv isn't sexy without the case pr0n. :)
twix
Unread postby twix » Wed Sep 14, 2016 11:05 pm
True. I will wipe the case to remove the dust and take some pictures of the current setup.
Unread postby dexter1 » Thu Sep 15, 2016 2:03 am
With 192 MB of Memory you can go irix 6.5.22m on your Indigo giving you access to nekoware mips3 and Foetz' stuff. The R4000 rev 2.2 CPU does have some bugs, but apart from the openssh problem on 6.5.22 it should run fine.
Irix 6.2 is also fun to run and MIPSPro is supported up to 7.3.1.3m
twix
Unread postby twix » Thu Sep 15, 2016 3:05 am
Since exchanging disks is easy, I'll keep the 6.2 installation and try to add some stuff to that, and also install 6.5.22 on a fresh disk. I have two disk sleds and plenty of (SCA) disks.
