Indigo2, R10k 195MHz, 320MB, High IMPACT
numaflex
Unread postby numaflex » Sat Sep 10, 2016 7:29 am
After about half a year of skimming eBay for parts, she's finally up and running (again):
1 195 MHZ IP28 Processor
Main memory size: 320 Mbytes
On-board serial ports: 2
Graphics board: High Impact
EISA bus: adapter 0
        Product ID 0x0, 1 GE, 1 RE, 1 TRAM
        VC3 rev A, CMAP rev DMC rev D
        unknown, assuming 19" monitor (id 0xa)
smj
Re: Indigo2, R10k 195MHz, 320MB, High IMPACT
Unread postby smj » Sat Sep 10, 2016 5:08 pm
Congrats on getting the Indigo2 running, a nice complement to your Indy. Oh, and welcome to Nekochan!
cinenate35
Unread postby cinenate35 » Sat Sep 10, 2016 5:25 pm
Nice :Indigo2IMP: . Looks like it is in really great shape!
Nate
:Octane2: :O2: :O2:
Unread postby Trippynet » Sun Sep 11, 2016 2:34 am
Nice little system you've got there, now you just need some floor stands for it :)
duck
Unread postby duck » Sun Sep 11, 2016 6:00 am
It's upside down! All the polygons will fall out!
Nice I2 though, I miss mine a little more now :-)
___(o)=
\____)
Geoman
Unread postby Geoman » Mon Sep 12, 2016 9:06 am
duck wrote:It's upside down! All the polygons will fall out!
Exactly my thought! ^_^ But then: without stands upside down is actually the right thing to do - because the "exhaust"-side is free then.
