octane2, r14k 2 600Mhz, 8Gb, EMXI
rs422
Unread postby rs422 » Fri Sep 02, 2016 8:27 am
i guess this is max gear for digital video manipulation.
octane 1# hinv -vm
      PM20600MHZ Board: barcode MXF574    part 030-1778-001 rev  C
            IP30 Board: barcode MYC406    part 030-1467-001 rev  K
            FP1 Board: barcode MKL174    part 030-0891-003 rev  J
    PWR.SPPLY.ER Board: barcode AAE3180008 part 060-0035-003 rev  A
        XTALKPCI Board: barcode FLX999    part 030-0952-005 rev  B
          MOT20 Board: barcode GPV497    part 030-1240-003 rev  B
      GALILEO15 Board: barcode FTA958    part 030-0931-003 rev  C
  FIBRE_CHANNEL Board: barcode KFV156    part 030-0927-003 rev  E
2 600 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 8192 Mbytes
Xbow ASIC: Revision 1.4
Integral SCSI controller 2: Version Fibre Channel AIC-1160, revision 2
Integral SCSI controller 3: Version Fibre Channel AIC-1160, revision 2
Graphics board: EMXI
Gigabit Ethernet: eg0, PCI slot 3, firmware version 12.4.10
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 3
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 0
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 1
Digital Video: unit 1, revision 4.2, TMI: revision 2, CSC: revision 1
octane 4# /usr/gfx/gfxinfo -vv
        HQ rev B, GE12 rev A, RE4 rev C, PP1 rev E,
        VC3 rev A, CMAP rev E, Heart rev F
        Video board present
        Video Format Flags:  (none)
        Sync Disabled
        Using Gamma Map 0
        Monitor Type:  unknown
        Gain (all color components) - 1.000000 (nominal)
:Indigo2:
Krokodil
Re: octane2, r14k 2 600Mhz, 8Gb, EMXI
Unread postby Krokodil » Fri Sep 02, 2016 2:44 pm
The only thing you're missing is the vPro. But EMXI is still pretty good and I understand some video editing applications require it.
Welcome to the Octane2 owners club.
Unread postby foetz » Fri Sep 02, 2016 7:06 pm
an interesting combination with the mxe. this one should be some serious fun :-)
