Upgraded Onyx2: 4 x 300MHz R12000, 8GB RAM, InfiniteReality3
iamcamiel
Unread postby iamcamiel » Thu Sep 01, 2016 11:25 am
I've upgraded the Onyx2 a bit; all CPU's are now 300MHz R12000's, after I managed to repair the failing CPU module, RAM's been doubled to 8GB, and the RM7's have been replaced with a single RM10:
hinv -vm
     IP31PIMM8MB Board: barcode JHC930     part 030-1401-002 rev  B
            IP31 Board: barcode JGY603     part 030-1255-003 rev  D
        MODULEID Board: barcode K0013182   part              rev
      4P1G5_MPLN Board: barcode GCH427     part 013-1839-001 rev  F
     IP31PIMM8MB Board: barcode JHC870     part 030-1401-002 rev  B
            IP31 Board: barcode JHD721     part 030-1255-003 rev  D
          GE16-4 Board: barcode JKA567     part 030-1398-001 rev  E
        QUAD-ATM Board: barcode ECE868     part 030-0948-003 rev  C
          BASEIO Board: barcode DYZ765     part 030-0734-002 rev  M
             MIO Board: barcode EYZ160     part 030-0880-003 rev  E
4 300 MHZ IP27 Processors
CPU 0 at Module 1/Slot 2/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 2.3. Scache: Size 8 MB Speed 200 Mhz  Tap 0xa
CPU 1 at Module 1/Slot 2/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 1/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 1/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 7680 Mbytes
Memory at Module 1/Slot 82: 4096 MB (enabled)
  Bank 7 contains 512 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 81: 3584 MB (enabled)
  Bank 7 contains 512 MB (Standard) DIMMS (disabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: InfiniteReality3
ATM XIO 4 port OC-3c: module 1, slot io5, unit 0 (ports: 0-3)
Iris Audio Processor: version RAD revision 7.0, number 1
  PCI Adapter ID (vendor 0x10a9, device 0x0002) PCI slot 0
  PCI Adapter ID (vendor 0x10a9, device 0x0002) PCI slot 1
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 6
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 7
IO6prom on Global Master Baseio in Module 1/Slot io2: Revision 6.156
/usr/gfx/gfxinfo -v
        Display has 2 channels
        4 GEs (of 4), occmask = 0x0f
        1 RM10 board (of 1) 1/0/0/0
        Texture Memory: 256MB/-/-/-
        Medium pixel depth
        32K cmap
        brd: 80f61806 3041606/-/-/- f9391002
        rm0: 15032057 15431057
              4631057 2/2/2/2
              4d31057 2/2/2/2/2/2/2/2
              4938057 5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5
         dg: 05532057
              5838057 1/1/1/1
              5631057 1/1
        GE:   NIC #:      0000.003b.68a3 (family: 0b)
              Serial #:   JKA567
              Part #:     030-1398-001
        KT:   No NIC serial number available.
        RM0:  NIC #:      0000.0058.dde0 (family: 0b)
              Serial #:   MJT762
              Part #:     030-1402-002
        TM0:  NIC #:      0000.0058.dd85 (family: 0b)
              Serial #:   KJD773
              Part #:     030-1588-002
        RM1:  No NIC serial number available.
        TM1:  No NIC serial number available.
        RM2:  No NIC serial number available.
        TM2:  No NIC serial number available.
        RM3:  No NIC serial number available.
        TM3:  No NIC serial number available.
        BP:   No NIC serial number available.
        DG:   NIC #:      0000.0018.4b53 (family: 0b)
              Serial #:   GFV091
              Part #:     030-1055-001
        DGOPT:No NIC serial number available.
:Onyx2: :PI: :Fuel: :Indigo: :Indigo: :Indigo2IMP: :Indy: + various DEC, IBM, Sun, HP, ...
Re: Upgraded Onyx2: 4 x 300MHz R12000, 8GB RAM, InfiniteReality3
Unread postby foetz » Thu Sep 01, 2016 12:40 pm
veeery nice one :D
Users browsing this forum: Yahoo [Bot] and 2 guests
