Personal Iris 4D/35, 36MHz R3000, 104MB, Turbo Graphics
iamcamiel
Unread postby iamcamiel » Wed Aug 31, 2016 5:12 am
After a power supply and TOD battery replacement, this PI 4D/35 possibly doesn't look as good as new, but does work as good as new.
hinv -v
1 36 MHZ IP12 Processor
FPU: MIPS R2010A/R3010 VLSI Floating Point Chip Revision: 4.0
CPU: MIPS R2000A/R3000 Processor Chip Revision: 3.0
On-board serial ports: 4
Data cache size: 64 Kbytes
Instruction cache size: 64 Kbytes
Main memory size: 104 Mbytes
Integral Ethernet: ec0, version 0
Integral SCSI controller 0: Version WD33C93A, revision 9
Iris Audio Processor, rev 3
Graphics board: GR1.2 Bit-plane, Z-buffer, Turbo options installed
gfxinfo
Graphics board 0 is "GR1" graphics.
        24 bitplanes, 4 auxplanes, 4 widplanes, 24 zplanes, turbo, RE2
        PIC revision B, single color cursor, board type GR1
CPU board:
Graphics board:
:Onyx2: :PI: :Fuel: :Indigo: :Indigo: :Indigo2IMP: :Indy: + various DEC, IBM, Sun, HP, ...
Re: Personal Iris 4D/35, 36MHz R3000, 104MB, Turbo Graphics
Unread postby jan-jaap » Wed Aug 31, 2016 6:32 am
Nice! Since you opened it up, did you verify that the little fan stuck to the lid of the E-module still works? Believe it or not, that little crap fan is all that prevents certain death due to overheating ...
iamcamiel
Unread postby iamcamiel » Wed Aug 31, 2016 6:35 am
jan-jaap wrote:Nice! Since you opened it up, did you verify that the little fan stuck to the lid of the E-module still works? Believe it or not, that little crap fan is all that prevents certain death due to overheating ...
Yes, I did. I had to take everything apart to get rid of all the dust inside. The fan is working.
Unread postby josehill » Wed Aug 31, 2016 7:00 am
It's nice to see such clean internals on a machine that age! Nice system!
Unread postby foetz » Wed Aug 31, 2016 11:04 am
very nice, what are you running on it? do you have some software from that era?
iamcamiel
Unread postby iamcamiel » Wed Aug 31, 2016 11:09 am
foetz wrote:very nice, what are you running on it? do you have some software from that era?
It's got IRIX 4.0.4 installed, but it looks like a fresh install, no user data or applications left on it.
iamcamiel
Unread postby iamcamiel » Thu Sep 01, 2016 1:11 am
And of course, the picture in my original post labeled "graphics card" does not show the graphics side of the machine, but the CPU side with the FORE ATM card plugged in. Here are two pictures of the graphics side of the cardcage:
Bare GR1.2 card:
With turbo extensions:
zuc
Unread postby zuc » Fri Sep 09, 2016 3:12 pm
I had one of these in my office in the 90s. Even at the time it seemed very large and heavy for a "personal" anything. :lol: :lol:
This one looks very nice, very clean! :)
:Indy: Indy - (indy) - R4600 - 133MHZ - 128MB RAM - 6.5.22
:Indy: Indy - (mimsy) - R4600 - 133MHZ - 160MB RAM - 6.5.22
:Indy: Challenge S (WIP)
:Indigo2IMP: Indigo2 - (indigo2) - R4400 - 200MHZ - 128MB RAM - 6.5.22
:Octane: Octane - (octane) - R12K - 2X300MHZ - 640MB RAM - EMXI+4TRAMs - 6.5.30
:Octane: Octane - (petrol) - R12K - 1X300MHZ - 1.5GB RAM - 6.5.30
:O2: O2 - (manxome) - R12K - 270MHZ - 256MB RAM - 6.5.30
SPARCstation 4 - (sparcstep) - MicroSparc - 85MHZ - 32MB RAM - NeXTSTEP 3.3
SPARCstation 5 - (sparc5) - MicroSparc - 85MHZ - 128MB RAM - Solaris 8
SPARCstation 20 - (sparc20) - HyperSparc - 2X125MHZ+1X160MHZ - 512MB RAM - Solaris 9
Sun Ultra 5 - (ultrasol) - UltraSparc - 333MHZ - 128MB RAM - Solaris 8
NeXTStation Turbo Color - (blackhole) - m68040 - 33MHZ - 80MB RAM - NEXTSTEP 3.3
Unread postby vishnu » Fri Sep 09, 2016 5:51 pm
Wow look at all those tenth of an inch center ICs! :mrgreen: 1990 date stamps on most of them... :P
