Octane 2xR12k 300MHz 640MB 2x146GB SCSI
zuc
Unread postby zuc » Fri Aug 26, 2016 12:43 pm
hinv -vm
      PM20300MHZ Board: barcode JJP722     part 030-1356-001 rev  M
            IP30 Board: barcode JPC651     part 030-1467-001 rev  C
    PWR.SPPLY.ER Board: barcode AAE1120099 part 060-0035-003 rev  A
             FP1 Board: barcode KAK097     part 030-0891-003 rev  E
           MOT20 Board: barcode KDE683     part 030-1240-003 rev  G
2 300 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 640 Mbytes
Xbow ASIC: Revision 1.3
Graphics board: EMXI
gfxinfo -v
        VC3 rev A, CMAP rev F, Heart rev F
        21" monitor (id 0xb)
         Video Output: 1280 pixels, 1024 lines, 72.24Hz (1280x1024_72)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
:Indy: Indy - (indy) - R4600 - 133MHZ - 128MB RAM - 6.5.22
:Indy: Indy - (mimsy) - R4600 - 133MHZ - 160MB RAM - 6.5.22
:Indy: Challenge S (WIP)
:Indigo2IMP: Indigo2 - (indigo2) - R4400 - 200MHZ - 128MB RAM - 6.5.22
:Octane: Octane - (octane) - R12K - 2X300MHZ - 640MB RAM - EMXI+4TRAMs - 6.5.30
:Octane: Octane - (petrol) - R12K - 1X300MHZ - 1.5GB RAM - 6.5.30
:O2: O2 - (manxome) - R12K - 270MHZ - 256MB RAM - 6.5.30
SPARCstation 4 - (sparcstep) - MicroSparc - 85MHZ - 32MB RAM - NeXTSTEP 3.3
SPARCstation 5 - (sparc5) - MicroSparc - 85MHZ - 128MB RAM - Solaris 8
SPARCstation 20 - (sparc20) - HyperSparc - 2X125MHZ+1X160MHZ - 512MB RAM - Solaris 9
Sun Ultra 5 - (ultrasol) - UltraSparc - 333MHZ - 128MB RAM - Solaris 8
NeXTStation Turbo Color - (blackhole) - m68040 - 33MHZ - 80MB RAM - NEXTSTEP 3.3
