Indy, R4600 133MHz, 128MB
zuc
Unread postby zuc » Fri Aug 26, 2016 12:30 pm
 $ hinv -vm
CPU: MIPS R4600 Processor Chip Revision: 2.0
FPU: MIPS R4600 Floating Point Coprocessor Revision: 2.0
1 133 MHZ IP22 Processor
Main memory size: 128 Mbytes
Data cache size: 16 Kbytes
On-board serial ports: 2
Graphics board: Indy 8-bit
Iris Audio Processor: version A2 revision 4.1.0
Vino video: unit 0, revision 0, IndyCam not connected
 $ /usr/gfx/gfxinfo
Graphics board 0 is "NG1" graphics.
        8 bitplanes, NG1 revision 6, REX3 revision B, VC2 revision A
        MC revision C, xmap9 revision A, cmap revision C, bt445 revision D
        Display 1280x1024 @ 60Hz, monitor id 15
:Indy: Indy - (indy) - R4600 - 133MHZ - 128MB RAM - 6.5.22
:Indy: Indy - (mimsy) - R4600 - 133MHZ - 160MB RAM - 6.5.22
:Indy: Challenge S (WIP)
:Indigo2IMP: Indigo2 - (indigo2) - R4400 - 200MHZ - 128MB RAM - 6.5.22
:Octane: Octane - (octane) - R12K - 2X300MHZ - 640MB RAM - EMXI+4TRAMs - 6.5.30
:Octane: Octane - (petrol) - R12K - 1X300MHZ - 1.5GB RAM - 6.5.30
:O2: O2 - (manxome) - R12K - 270MHZ - 256MB RAM - 6.5.30
SPARCstation 4 - (sparcstep) - MicroSparc - 85MHZ - 32MB RAM - NeXTSTEP 3.3
SPARCstation 5 - (sparc5) - MicroSparc - 85MHZ - 128MB RAM - Solaris 8
SPARCstation 20 - (sparc20) - HyperSparc - 2X125MHZ+1X160MHZ - 512MB RAM - Solaris 9
Sun Ultra 5 - (ultrasol) - UltraSparc - 333MHZ - 128MB RAM - Solaris 8
NeXTStation Turbo Color - (blackhole) - m68040 - 33MHZ - 80MB RAM - NEXTSTEP 3.3
Re: Indy, R4600 133MHz, 128MB
Unread postby dexter1 » Fri Aug 26, 2016 4:34 pm
A shiny Indy, albeit quite low spec. Congratz!
zuc
Unread postby zuc » Fri Aug 26, 2016 9:25 pm
Yes... low spec indeed! That's why I need the dual R12k Octane to lead the pack :D
Unread postby ClassicHasClass » Sat Aug 27, 2016 9:56 am
How's the case?
zuc
Unread postby zuc » Mon Aug 29, 2016 8:37 am
The case is in decent shape. It's a little yellowed on top but no cracks.
Krokodil
Unread postby Krokodil » Mon Aug 29, 2016 11:50 am
zuc wrote:Yes... low spec indeed! That's why I need the dual R12k Octane to lead the pack :D
Indeed a dual 300+ Octane is a force to be reckoned with.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
