Onyx2, 2xR12K 300 MHz + 2xR10K 195 MHz, 4GB, InfiniteReality 2E
iamcamiel
Unread postby iamcamiel » Mon Aug 22, 2016 7:51 am
hinv -vm
     IP31PIMM8MB Board: barcode JHC930     part 030-1401-002 rev  B
            IP31 Board: barcode JGY603     part 030-1255-003 rev  D
        MODULEID Board: barcode K0013182   part              rev
      4P1G5_MPLN Board: barcode GCH427     part 013-1839-001 rev  F
            IP27 Board: barcode DDE059     part 030-1266-001 rev  C
          GE16-4 Board: barcode JKA567     part 030-1398-001 rev  E
          BASEIO Board: barcode DYZ765     part 030-0734-002 rev  M
             MIO Board: barcode EYZ160     part 030-0880-003 rev  E
Processor 0: 300 MHZ IP27
Processor 1: 300 MHZ IP27
Processor 2: 195 MHZ IP27
FPU: MIPS R10010 Floating Point Chip Revision: 2.6
Processor 3: 195 MHZ IP27
CPU 0 at Module 1/Slot 2/Slice A: 300 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 2.3. Scache: Size 8 MB Speed 200 Mhz  Tap 0xa
CPU 1 at Module 1/Slot 2/Slice B: 300 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 1/Slice A: 195 Mhz MIPS R10000 Processor Chip (enabled)
  Processor revision: 2.6. Scache: Size 4 MB Speed 130 Mhz  Tap 0x9
CPU 3 at Module 1/Slot 1/Slice B: 195 Mhz MIPS R10000 Processor Chip (enabled)
Main memory size: 3584 Mbytes
Memory at Module 1/Slot 82: 2048 MB (enabled)
Memory at Module 1/Slot 81: 1536 MB (enabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: InfiniteReality2E
Iris Audio Processor: version RAD revision 7.0, number 1
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 6
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 7
HUB in Module 1/Slot 1: Revision 5 Speed 97.50 Mhz (enabled)
IO6prom on Global Master Baseio in Module 1/Slot io2: Revision 6.156
gfxinfo -vv
        Managed (":0.0") 3840x1080
        Display has 2 channels
        4 GEs (of 4), occmask = 0x0f
        2 RM7 boards (of 2) 1/1/0/0
        Texture Memory: 64MB/64MB/-/-
        Small pixel depth
        32K cmap
        brd: 80f61806 3020c06/3020c06/-/- f9391002
        rm0: 15032057 15431057
              4631057 2/2/2/2
              4d31057 2/2/2/2/2/2/2/2
              4938057 5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5
        rm1: 15032057 15431057
              4631057 1/1/1/1
              4938057 4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4
         dg: 05532057
              5838057 1/1/1/1
              5631057 1/1
        GE:   NIC #:      0000.003b.68a3 (family: 0b)
              Serial #:   JKA567
              Part #:     030-1398-001
              rev_code:   E
              grp_code:   0xff
              capability: "\ff\ff\ff\ff"
              variety:    0xff
        KT:   No NIC serial number available.
        RM0:  NIC #:      0000.0017.b1a3 (family: 0b)
              Serial #:   GFA527
              Part #:     030-1054-001
              rev_code:   G
              grp_code:   0xff
              variety:    0xff
        TM0:  NIC #:      0000.0017.b2f0 (family: 0b)
              Serial #:   GFA302
              Part #:     030-1053-001
              rev_code:   F
              grp_code:   0xff
              variety:    0xff
        RM1:  NIC #:      0000.000f.6d01 (family: 0b)
              Serial #:   DCN200
              rev_code:   E
              grp_code:   0xff
              variety:    0xff
        TM1:  NIC #:      0000.000e.4187 (family: 0b)
              Serial #:   EEA178
              rev_code:   E
              grp_code:   0xff
              variety:    0xff
        RM2:  No NIC serial number available.
        TM2:  No NIC serial number available.
        RM3:  No NIC serial number available.
        TM3:  No NIC serial number available.
        BP:   No NIC serial number available.
        DG:   NIC #:      0000.0018.4b53 (family: 0b)
              Serial #:   GFV091
              Part #:     030-1055-001
              rev_code:   L
              grp_code:   0xff
              variety:    0xff
        DGOPT:No NIC serial number available.
         Video Output: 1920 pixels, 1080 lines, 59.93Hz (IR_LG42LH3000_1920x1080_5993.vfo)
         Video Format Flags:  (none)
         Sync Output(s):
          Composite sync on Green
          Composite TTL sync on Aux 0
         Using Gamma Map 0
         Monitor Type:  Unknown
         Pedestal Enabled
         Channel not blanked
         Gain (all color components) - 1.000000 (nominal)
         Horizontal Phase - 0.00 pixels; range [0.00,2560.00]
         Vertical Phase - 0 lines; range [-2,2]
        Channel 1:
         Origin = (1920,0)
         Sync Output(s):
         Using Gamma Map 0
         Pedestal Enabled
         Channel not blanked
         SCH Phase - 0.0 degrees; range [-180.0,180.0]
scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d1l0:  Disk          COMPAQ  BD14688278      HPB4
Device is  ready
/dev/scsi/sc0d2l0:  Disk          COMPAQ  BD14689BB9      HPB1
Device is  ready
/dev/scsi/sc0d3l0:  Disk          COMPAQ  BD14689BB9      HPB1
Device is  ready
/dev/scsi/sc0d6l0:  CD-ROM        DEC     RRD46   (C) DEC 1337
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  reladdr synch linkedcmds
Device is  not ready
Notes:
- Looks like one 512MB bank of memory is not being recognized properly, will need to investigate.
- I replaced 8 of the fans in the fan tray with quieter ones (with proper CFM though) so the system is quiet enough for actual deskside use.
- The InfiniteReality 2E is not a proper 2E; the raster manager boards are RM7, not RM9.
- The "mirrors" demo runs smoothly full-screen across two 1920x1080 monitors.
:Onyx2: :PI: :Fuel: :Indigo: :Indigo: :Indigo2IMP: :Indy: + various DEC, IBM, Sun, HP, ...
Re: Onyx2, 2xR12K 300 MHz + 2xR10K 195 MHz, 4GB, InfiniteReality 2E
Unread postby ClassicHasClass » Mon Aug 22, 2016 9:56 am
*drool
Shiunbird
Unread postby Shiunbird » Tue Aug 23, 2016 1:50 am
How loud is that?
iamcamiel
Unread postby iamcamiel » Tue Aug 23, 2016 3:21 am
Shiunbird wrote:How loud is that?
It was pretty loud; one of the fans wasn't turning, forcing all the other fans into high speed mode; some of the other fans were making rattling noises, on top of the sound of a large vacuum cleaner sitting next to you.
I've replaced all but one of the fans with much quieter ones (37 dBa vs 54 dBa at the same amount of airflow); I initially planned to replace all of them, but the tach signal from the new fans is incompatible with that of the old fans (looks like the original fans were a custom job from NMB, the part number indicates a non-standard tach signal). So, I kept one of the original fans in there, and wired its tach output to each of the tach inputs on the system, keeping the MSC happy (and not shutting down the system as it did when I had all the fans replaced.
It's still a little loud, but bearable, think air conditioner in the same room.
Shiunbird
Unread postby Shiunbird » Wed Aug 24, 2016 5:19 am
Hmmm, I see. I've been using my IntelliStation with noise cancelling headphones. =)
Unread postby jan-jaap » Wed Aug 24, 2016 11:55 am
Nice to see you've got it up and running!
Unread postby uunix » Wed Aug 24, 2016 1:25 pm
Shiunbird wrote:Hmmm, I see. I've been using my IntelliStation with noise cancelling headphones. =)
Do you have the back cover on your IntelliStation? Mine is quieter than a nun in a dorm..
Unread postby foetz » Wed Aug 24, 2016 1:40 pm
congrats, that's a proper beast you got there :D
iamcamiel
Unread postby iamcamiel » Fri Aug 26, 2016 3:13 am
iamcamiel wrote:It's still a little loud, but bearable, think air conditioner in the same room.
I take that back; I've just turned on the A/C, I can't hear the Onyx at all anymore, so it's a lot less loud than the A/C.
Camiel.
Shiunbird
Unread postby Shiunbird » Fri Sep 02, 2016 12:41 am
I do have. I bought this thing brand new two years ago for 300 euro. =))))
So I have all the packaging, manuals, and it looks flawless (I just made a tiny scratch on the case hitting it with my G5).
But it's still too loud for my taste, specially next to the G5 or my 2011 Mac Mini. I feel tired if I sit next to it for hours.
But the noise cancelling headphones do miracle.
