Octane "1.5" V8 400mhz R12k 640mb
Slide
Unread postby Slide » Sat Jul 02, 2016 2:20 pm
It's been a long time (probably a decade?) since I've really played with my SGI gear or hung out on Nekochan...
In the process of cleaning out my basement, prepping to move, I liquidated half a dozen Sun machines and a ton of old PC gear, but I just couldn't bring myself to get rid of this thing. Pieced it all back together (finally installing the never-used-by-me V8 graphics) and dropped a fresh 6.5.30 install on it, and other than a few little quirks (I cannot get a browser to run for the life of me), and missing my MIPSpro licenses (Dammit!), it's a great -- but loud -- machine. It's running headless in the corner of my workshop at the moment, but once we get into the new place I'm going to see about putting it to proper use. It's officially an Octane, but I've replaced the PSU and mainboard to support the V8, and the Irix "System Manager" app now reports that it's a Octane2, so...There's that. ;)
Just need to find some more RAM, and a better CPU. And maybe a 1.4 XBow. Unfortunately, eBay isn't exactly the font of surplus gear it once was...
Replacing the 18gb SCA drive with an SSD would be nice, too, but I'm not exactly made of money! lol
On to the hinv!
      PM10400MHZ Board: barcode KXE106     part 030-1475-001 rev  B
            IP30 Board: barcode MFB406     part 030-1467-001 rev  D
             FP1 Board: barcode 40263C     part 030-0891-003 rev  E
    PWR.SPPLY.ER Board: barcode AAE9020563 part 060-0035-001 rev  B
          ODY128 Board: barcode LLD002     part 030-1404-003 rev  A
1 400 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 640 Mbytes
Xbow ASIC: Revision 1.3
  Disk drive: unit 3 on SCSI controller 1 (unit 3)
Graphics board: V8
        Managed (":0.0") 1280x720
        BUZZ version A.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
Re: Octane "1.5" V8 400mhz R12k 640mb
Unread postby dexter1 » Sun Jul 03, 2016 2:21 am
Welcome back Slide!
Posting in the Hardware Wanted section should get you sorted on a Xbow and maybe a better CPU although the R12K400MHz is very decent. V10's or V12's tend to be harder to find.
More recent SCA disks tend to be much quieter than the ones they came with the machines a decade ago. You might want to source one of these.
Unread postby Trippynet » Sun Jul 03, 2016 2:30 am
I second the quieter SCA drives. There are some very quiet ones around that can be picked up very cheaply these days. Pretty much all of the ones in the machines in my signature have been acquired for free from old servers at work and make very little noise.
Of course, there are also rubbish ones out there too, so check before you bid :)
Slide
Unread postby Slide » Mon Jul 04, 2016 5:20 pm
I hadn't considered trying to find newer SCA drives...last time I was in a data center with spinning disks, the 15k drives sounded like small turbines trying to achieve escape velocity, and honestly I'm not too worried about the drive noise; though, after getting accustomed to SSDs I was amazed by how loud and chunky they were...
For that matter, I'm still not even sure what I'm going to do with this thing. If I could get OpenVPN running on it I could use it for work, but the lack of tun/tap support in IRIX is confounding. No matter what direction I go, though, a dual CPU module is high on my "want" list. While the 400 is good, two would be better. And a 600 would be better, as well, but not as better as two 600s. :D
Unread postby Trippynet » Tue Jul 05, 2016 12:10 pm
Yeah, they vary a lot. I've acquired dozens of different hard drives from old servers at work and they've ranged from excellent ones which are virtually inaudible over the fan noise of the systems (my O2 with fan-mod was as quiet as a modern PC with one of these - and a 15k one too), to ones which sound like a jumbo-jet taking off. Generally, newer is often quieter as earlier SCA drives were typically quite noisy, but there are a few exceptions. Also, modern 15k ones are quieter usually than older 10k ones, so don't assume higher spindle speed automatically means more noise...
