O2, R10K 195Mhz, 128MB
fogWraith
Unread postby fogWraith » Fri Jun 10, 2016 10:42 am
hinv -vm
1 195 MHZ IP32 Processor
Main memory size: 128 Mbytes
FLASH PROM version 4.18
PCI SCSI controller 2: Version ADAPTEC 7880
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
  PCI Adapter ID (vendor 0x9004, device 0x8178) PCI slot 3
Video: MVP unit 0 version 1.4
Vice: TRE
/usr/gfx/gfxinfo
        32 + 32 bitplanes
         Monitor 0 type: DEL 16396
         Video Output: 1280 pixels, 1024 lines, 59.94Hz (1280x1024_60)
Posting from Communicator 4.8, so, hopefully it didn't mess up entirely :P
Knezzen
Re: O2, R10K 195Mhz, 128MB
Unread postby Knezzen » Fri Jun 10, 2016 11:20 am
Looks good! Pics or it didnt happen ;)
:Octane: Dual 300mhz R12k - 256mb RAM - 146GB 15k RPM HD - V6 Graphics
Unread postby uunix » Fri Jun 10, 2016 11:41 am
Knezzen wrote:Looks good! Pics or it didnt happen ;)
Are you Vishu in disguise?
Knezzen
Unread postby Knezzen » Fri Jun 10, 2016 12:29 pm
uunix wrote:Are you Vishu in disguise?
The Swedish version! Like the Swedish chef, only worse.
fogWraith
Unread postby fogWraith » Fri Jun 10, 2016 1:30 pm
Whoever said MS Paint was bad? :P
Here you go !
mopar5150
Unread postby mopar5150 » Mon Jun 13, 2016 7:28 am
How do you guys keep finding SGIs with such nice skins? That machine looks beautiful!
:Tezro: :O3x0: :A350:
fogWraith
Unread postby fogWraith » Wed Jun 15, 2016 2:15 am
mopar5150 wrote:How do you guys keep finding SGIs with such nice skins? That machine looks beautiful!
Some people just seem to value their items, and want to keep them looking nice when passing the torch, I guess :P
And yes, it is beautiful... I clean it more often than the apartment ;)
Unread postby jan-jaap » Wed Jun 15, 2016 2:29 am
Basically there are two ways for a hobbyist to get his/her hands on a system:
original owner -> recycler -> ebay -> hobbyist
and
original owner -> employee takes it home -> hobbyist
Recycling people are a bunch of gorillas, they treat computers like they're taking out the trash. I guess to some extent they are ... Employees who take a system home usually pick the best looking, fastest system and usually take documentation, software and peripherals as well.
Krokodil
Unread postby Krokodil » Wed Jun 15, 2016 6:48 pm
and
In the case of my O2 it appeared to be in the guys house when he took the pictures. The Octane I don't know, it may have come from some sort of IT outfit and the Octane II went into storage for 7 years from a "class 1 datacenter".
