Origin 200 2xR10000 180MHz 256MB
Unread postby uunix » Thu Jun 09, 2016 7:23 am
Completely uninteresting, but this is the smashed up machine from the RTC
TWIST1 6# hinv -vm
    PIMM_2XT5_2M Board: barcode GFB452     part 013-2284-002 rev  A
            IP29 Board: barcode FXJ330     part 030-1244-001 rev  H
Location: /hw/module/1/slot/MotherBoard/node/xtalk/8/pci/2
2 180 MHZ IP27 Processors
CPU 0 at Module 1/Slot 1/Slice A: 180 Mhz MIPS R10000 Processor Chip (enabled)
  Processor revision: 2.6. Secondary cache size: 2 MB
CPU 1 at Module 1/Slot 1/Slice B: 180 Mhz MIPS R10000 Processor Chip (enabled)
Main memory size: 256 Mbytes
Memory at Module 1/Slot 1: 256 MB (enabled)
  Bank 0 contains 128 MB (Standard) DIMMS (enabled)
  Bank 1 contains 64 MB (Standard) DIMMS (enabled)
  Bank 2 contains 64 MB (Standard) DIMMS (enabled)
  CDROM: unit 3 on SCSI controller 1
IOC3 serial port: tty1
IOC3 serial port: tty2
Integral Fast Ethernet: ef0, version 1
Origin BASEIO board, module 1 slot 1
IOC3 external interrupts: 1
HUB in Module 1/Slot 1: Revision 3 (enabled)
mopar5150
Re: Origin 200 2xR10000 180MHz 256MB
Unread postby mopar5150 » Thu Jun 09, 2016 12:12 pm
I am amazed it functions at all after the smash up.
:Tezro: :O3x0: :A350:
Unread postby uunix » Thu Jun 09, 2016 12:58 pm
Well indeed yes, so am I. More amazed why it needs the MVS cable attached to fire up... BUT it gets better..
No idea what it is yet, but it all works (well apart from the projects being on a drive that doesn't exist anymore) and LITHO isn't licenced but there is a licence swapper app which may have something to do with it.
Hamie says it's rather good software.
Krokodil
Unread postby Krokodil » Thu Jun 09, 2016 5:09 pm
Let us be thankful and give thanks that the damage seems only to be cosmetic.
Sweet Origin200.
