O2: R12k 300MHhz, 768MB
commodorejohn
Unread postby commodorejohn » Thu Jun 02, 2016 10:57 pm
1 300 MHZ IP32 Processor
Main memory size: 768 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
 with no AV Card or Camera.
Vice: TRE
Currently posting from the new member of the family :) toasty set me up with a nice fresh install, lightly tricked-out with some fun 3D software, and I was able to boost it up to a solid 768MB RAM with sticks from my R5k O2, which has been demoted to a measly 288MB. Now I just need to get some more fun stuff loaded on here...
Re: O2: R12k 300MHhz, 768MB
Unread postby dexter1 » Thu Jun 02, 2016 11:03 pm
Gratz on your little toaster. Old or new skins?
Unread postby ClassicHasClass » Thu Jun 02, 2016 11:37 pm
Pics or, well, you know.
commodorejohn
Unread postby commodorejohn » Thu Jun 02, 2016 11:56 pm
New skins, so with the R5k I've got one of each (not counting the O2+, I suppose, but eh.) As for pics, well, here you be:
(Guest-starring the Blade 2000, which is now running stably and just awaiting a little more attention, and the HP 9000/712, which I still need to get set up with a working HP-UX install.)
Krokodil
Unread postby Krokodil » Fri Jun 03, 2016 5:09 am
Nice little system. My R5K is mostly relegated to being an install server these days.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
toasty
Unread postby toasty » Fri Jun 03, 2016 10:33 am
Woohoo! Nice to see it go to a good home. And with some company too :)
Past: :Fuel: :Octane2: :O2: :O2: :O2: :Indy: Present: MacBook
