Tezro: 4x800Mhz | 8GB | V12 | DCD | 10GbE | SAS | USB | RAD
devv
Re: Tezro: 4x800Mhz | 8GB | V12 | DCD | 10GbE | SAS | USB | RAD
Unread postby devv » Sun May 29, 2016 1:53 am
My V12 is P/N 013-3416-007 REV.A. It does not have the 3-pin fan header. How it looks instead can be seen in the attached image.
The picture is not 100% clear, but the 2-pin header is in about the center of the image, and the 6-pin header is up and a little to the right.
(Update: Yes, I've searched for the part number -- it is appearing listed among the Fuel parts, so it's the Fuel one without the fan header.)
oOoO :Tezro: oOoO
devv
Re: Tezro: 4x800Mhz | 8GB | V12 | DCD | 10GbE | SAS | USB | RAD PICS
Unread postby devv » Sun May 29, 2016 1:56 am
I've forgotten about the "pics or it didn't happen" rule :) Here are some pictures of the system taken after I've replaced all the PCI cards I intended (so these pictures do match the hinv I posted).
oOoO :Tezro: oOoO
devv
Unread postby devv » Sun May 29, 2016 2:49 am
Regarding fan control, found an external fan controller with no audio, USB and other unnecessary items:
http://www.newegg.com/Product/Product.a ... 6811992006
It's not available from this particular page, but there are sellers who have it in stock -- this one is just good because of the pictures.
oOoO :Tezro: oOoO
Unread postby Trippynet » Sun May 29, 2016 4:00 am
Those skins look seriously mint. Congrats!
devv
Unread postby devv » Sun May 29, 2016 7:56 am
For future reference, the Papst fans at the end of Tezro (3 fans in a metal casing) are Papst 8312/12HL.
They can be purchased separately or in arrays of 3. (I don't know which type Tezro uses, will check later.)
Their specs are:
Type Papst 8312
Wires/pins 3
Size 80 x 80 x 32 mm
Nominal voltage VDC 12
Nominal voltage range VDC 6 .. 15
Speed min -1 3300
Power input W 2.6
Min. ambient temperature °C -20
Max. ambient temperature °C 75
Air flow m3/h 54
CFM 31 (<-- this is my assumption, not from the product sheet)
Sound power level B 5.2
Sound pressure level dB(A) 36
Particular design features:
Optional Vario-Pro: Highly flexible software configuration for the fan ensures an easily customisable
solution to meet the individual requirements of your application.
General features:
Material: fibreglass-reinforced plastic. Impeller PA, housing PBTP.
Electronic commutation completely integrated.
Protected against reverse polarity and locking.
Connection via single strands AWG 22, TR 64, bared and tin-plated.
Air exhaust over bars. Rotational direction clockwise looking at rotor.
Mass: 170 g.
Connection line Single strands AWG 22, TR 64, bared and tin-plated.
Locked-rotor protection Blocking and overload protection
Direction of rotation Right, looking at rotor
Direction of air flow Air exhaust over bars
Bearing Ball bearings
Lifetime L10 at 40 °C 70000 h
Lifetime L10 at maximum temperature 27500 h
Mass 0.170 kg
Housing material Fiberglass-reinforced PBT plastic
Material of impeller Fiberglass-reinforced PA plastic
Motor protection Protected against reverse polarity and locking.
Approval VDE, CSA, UL, CE
Info from http://www.spareelectronicparts.com/med ... t_8312.pdf
oOoO :Tezro: oOoO
devv
Unread postby devv » Sun May 29, 2016 8:52 am
In the "fan wall" there are 4 fans, 2x 8x8x2.5 and 2x 6x6x2.5, all are 3-pin.
The 8cm ones are Delta-Electronics AFB0812M, FAN AXIAL 80X25.4MM 12VDC WIRE, 53m^3/h airflow:
Voltage - Rated 12VDC
Size / Dimension Square - 80mm L x 80mm H
Width 25.40mm
Wires/pins: 3
Air Flow 31.4 CFM (0.889m³/min, 53m3/h)
Static Pressure 0.129 in H2O (32.1 Pa)
Bearing Type Ball
Fan Type Tubeaxial
Features -
Noise 28 dB(A)
Power (Watts) 1.44W
RPM 2700 RPM
Termination 2 Wire Leads
Ingress Protection -
Operating Temperature 14 ~ 158°F (-10 ~ 70°C)
Approvals CE, CSA, UL, VDE
Current Rating 0.120A
Voltage Range 7 ~ 13.8VDC
Material - Frame Plastic
Material - Blade Plastic
Weight 0.176 lb (79.83g)
Data from http://www.digikey.com/product-detail/e ... ND/2560432, http://partner.delta-corp.com/Products/ ... 0x25mm.pdf
oOoO :Tezro: oOoO
devv
Unread postby devv » Sun May 29, 2016 8:58 am
Behind the disks, there is another fan hiding, Papst Multifan 8312/2H, 3-wire as well. I am going to assume it is similar to the other 3 from the same manufacturer and similar model #, so won't check the specs.
oOoO :Tezro: oOoO
devv
Unread postby devv » Sun May 29, 2016 9:29 am
The 2 6x6x2.5 fans in the "fan wall" are Papst 612N/2ML:
Direction of rotation seen from the rotor: right
rated voltage 12.0 V
current consumption 50 mA
input 0.6 W
number of revolutions 3,000 1 / min
Max. air flow 23.0 m3 / h
weight 0.066 kg
Data from http://www.mbs.to/download/ebmpapst/612 ... E_V1.4.pdf
oOoO :Tezro: oOoO
Rhodamine
Unread postby Rhodamine » Sun May 29, 2016 8:17 pm
Very nice machine.
Regards, Adam
:Onyx2: :Octane: :Indigo: :Indigo: :Indigo: :Indigo2: :Indigo2IMP: :Indy:
devv
Unread postby devv » Mon May 30, 2016 2:11 am
ivelegacy wrote:can I see a picture of the L1 unit?
I see four USB plug in the back of the machine, is that a NEC chip?
Yes, it's the card listed on http://www.nekochan.net/wiki/Known_work ... atabase%29 (search for "9210286") in the page.
devv wrote:regarding the gfx's fan, as far as I understood
  • Tezro VPro-v12 gfx is equal to Fuel Vpro-v12 gfx
  • but Fuel VPro-v12 gfx doesn't have a fan on it
correct?
That is my understanding of it, yes. (A 'fan connector' though, not a 'fan' itself).
oOoO :Tezro: oOoO
Unread postby recondas » Mon May 30, 2016 8:58 am
devv wrote:http://www.nekochan.net/wiki/Known_working_PCI_cards_with_IRIX_%28A_visual_database%29
While there aren't any additional USB examples, the original forum thread does include a few other IRIX-friendly PCI boards.
mopar5150
Unread postby mopar5150 » Mon May 30, 2016 10:38 am
devv wrote:I wish :) Still hunting for 4x1Ghz instead of 4x800Mhz. But I have a feeling that'll be postponed for a couple years, given the prices of 4x1Ghz boards :)
If you are willing to trade in your 4x800 I can give you a good deal on the quad 1Ghz. :D
The plastics are mint on that system, you are very fortunate!
:Tezro: :O3x0: :A350:
devv
Unread postby devv » Thu Jun 02, 2016 2:57 pm
I got the USB keyboard and wireless Logitech mouse to work with this setup as documented on:
viewtopic.php?f=3&t=16730783&p=7390890#p7390890
oOoO :Tezro: oOoO
Krokodil
Unread postby Krokodil » Fri Jun 03, 2016 5:36 am
Nice Tezro, very well appointed. Looks to be in great shape too.
Tezro is not for me, but I'm glad other people love and cherish them.
devv
Unread postby devv » Thu Jun 16, 2016 1:02 pm
Continuing with documenting the fans in a Tezro:
The PSU fan is Delta Electronics AFB0812SH-F00 80x80x25mm
Dimensions: 80 x 80 x 25mm
Power: 12V DC (7.0 to 13.8 ) 0.51 Amp
Speed: 4000 RPM
Max Air Flow: 46.62 CFM
Noise Level: 40 dB-A
3-pin TAC connector
The wiring on that fan is Blue-Black-Red, and is not compatible with a typical PC 3-pin.
To work with a PC, the wiring needs to be changed to Black-Red-Blue.
When the fan is powered up, it clearly presents itself as a large contributor to Tezro's overall noise level.
In terms of replacement, it appears only the following 3 fan models have comparable CFM while being quieter than the original 40 dB:
Papst 8412 N/2GH 80mm, 3600 RPM, 46.5 CFM, 37 dB
Papst 8412 N/2G 80mm, 3100 RPM, 40.61 CFM, 32 dB
Enermax UC-8AEBS 80mm, 2800 RPM, 44.21 CFM, 32 dB
So, I went with Enermax.
oOoO :Tezro: oOoO
