Indigo2, R10k 195MHz, 512MB, Solid IMPACT
rosmaniac
Unread postby rosmaniac » Mon Feb 29, 2016 2:42 pm
Whee. Eleven years after starting to work on this machine..... finally:
# hinv -mv
1 195 MHZ IP28 Processor
Main memory size: 512 Mbytes
  Tape drive: unit 2 on SCSI controller 0: DAT
On-board serial ports: 2
Graphics board: Solid Impact
EISA bus: adapter 0
# /usr/gfx/gfxinfo -vv
        Product ID 0x1, 1 GE, 1 RE, 0 TRAMs
        VC3 rev A, CMAP rev EMC rev D
# scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d2l0:  Tape          ARCHIVE Python 01931-XXX5.63
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
Device is  not ready
/dev/scsi/sc0d3l0:  Disk          IBM     DNES-309170     SAH0
ANSI vers 3, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds cmdqueing
Device is  ready
/dev/scsi/sc0d4l0:  CD-ROM        PLEXTOR CD-ROM PX-12TS  1.02
Device is  not ready
lorc-r10k 9#
# uname -R
6.5 6.5.22m
Machine was purchased to do Audio DAT downconversion....... just never got around to it until now. Thus, the Archive Python DAT drive.....
Re: Indigo2, R10k 195MHz, 512MB, Solid IMPACT
Unread postby uunix » Mon Feb 29, 2016 2:55 pm
Outstanding Chap.. worth the wait..
Unread postby dexter1 » Mon Feb 29, 2016 3:33 pm
Congratulations on your purple box! Looks like an Internal CDROM, those trays were rare.
Unread postby robespierre » Mon Feb 29, 2016 3:58 pm
I think it's an aftermarket CDROM drive, they shipped with Toshiba XM-3501B units. The Archive CTD-8000 DDS2 were stock.
Let the forum know if you have success with audio DAT transfers. I found that the DATplayer software really liked to hang.
Unread postby Trippynet » Tue Mar 01, 2016 1:16 am
Nice little system! I've always loved the purple Indigo 2s. One of the more bomb-proof systems that SGI made.
rosmaniac
Unread postby rosmaniac » Tue Mar 01, 2016 12:04 pm
robespierre wrote:I think it's an aftermarket CDROM drive, they shipped with Toshiba XM-3501B units.
It is; the Plextor 12X drives are settable to 512 byte sectors, and I happened to have fifty or so at the time.... I'm not sure how many I have right now.
It did come from the seller with a Toshiba drive, but it was broken, and I had the Plextor drives......
Thanks for the notice. I have the DATgoodies tarball, but haven't built them yet (I did grab the tardist of DATgoodies from somewhere else, but I've always been one to build things myself if possible). And while there is software for Linux and other u*ix variants out there, it is rumored to be less stable than the SGI stuff was, so for now it will be DATman. I also have an O2 that I'm getting up to 6.5.22 also, but it will have to be an external.
I will definitely follow up on the DAT transfers once I get some more round toits to get things set up properly.....
