fuel R16000 800MHz 4GB V10 - I am complete!
Unread postby uunix » Sat Dec 19, 2015 2:52 pm
well nearly.. :D
Finally in my hands is my new fuel which is just darn beutiful and so quiet, perfect skins. Came with a really nice Dell monitor.
Not sure if this is a worry or standard, but when I plugged in the power there was a high pitched whine which went when I powered it on.
It's just so fast and quiet I can't get over it... resolution is 1920x1200 which coming from all my other boxes running at 1280x1024 is something to get used to. With my eyesight I've had to enlarge the icons somewhat..
Worth the pain and wait..
hinv -v
1 800 MHZ IP35 Processor
CPU 0 at Module 001c01/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Integral SCSI controller 2: Version QL12160, low voltage differential
Integral SCSI controller 3: Version QL12160, low voltage differential
Integral SCSI controller 4: Version SAS/SATA LS1068
Graphics board: V10
Gigabit Ethernet: eg0, module 001c01, pci_bus 1, pci_slot 3, firmware version 12.4.10
  PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 2
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 3
USB controller: type OHCI
gfxinfo
        Managed (":0.0") 1920x1200
        BUZZ version B.2
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: DEL -24543
         Video Output: 1920 pixels, 1200 lines, 60.02Hz (1920x1200_60)
jimmer
Re: fuel R1600 800MHz 4GB V10 - I am complete!
Unread postby jimmer » Sat Dec 19, 2015 3:16 pm
Congrats! - welcome to the 800Mhz Fuel club :)
:Fuel: redbox 800Mhz 4Gb V12
Unread postby josehill » Sat Dec 19, 2015 3:44 pm
Mine started to do that and gradually got worse, not too long before the power supply died, so pay attention if it gets worse.
uunix wrote:Not sure if this is a worry or standard, but when I plugged in the power there was a high pitched whine which went when I powered it on.
Unread postby Trippynet » Sun Dec 20, 2015 2:19 am
Very nice system, especially with the 800MHz CPU! If you say yours is quiet, you either mean "in comparison to an Octane", or a previous owner has already done some fan replacement. My own Fuel always sounded nice and quiet when I first turned it on, but was making certainly a fair amount of noise 10 minutes later as it warmed up (and the fans span up accordingly).
Unread postby uunix » Sun Dec 20, 2015 8:48 am
It's possible he did something to fans, but never mentioned it. I had it running for a good few hours last night and it never increased.. so I would say yes.. it's in comparison to my Octanes (especially my DCD v12 one).
EDIT:
Well it's certainly quiet now.. hanging.. last dmesg
NOTIC: /hw/module/001c01/Ibrick/xtalk/14/pci/2/scs_ctlr/0: 1068 SAS/SATA firmware version 1.22.1.0
EDIT:EDIT:
So I disconnected power lead to PSU for 30 mins and restarted.
It started up fine. No whining noise and the next item on dmesg was
Selecting SNII (or SN11)
BetXen
Unread postby BetXen » Mon Dec 21, 2015 7:51 am
Welcome to the club ! This is definitely a nice machine that works well... when PSU or V12 do not burn.
Have fun with it !
Unread postby ClassicHasClass » Mon Dec 21, 2015 8:18 am
Now you'll want a 900MHz PIMM, a V12 and a DCD. :)
Unread postby uunix » Mon Dec 21, 2015 11:02 am
Connected a USB Wacom Bamboo FUN and it is showing in hinv as : USB Human Interface Device: ID 0 type tablet
Is there any application that could use this?
Unread postby uunix » Sat Jan 09, 2016 1:09 pm
Swapped the CD drive for a SUN DVD Drive and was going to put a DAT72 drive in.. but then there was a dilemma.. The colour of the Sun was a grey type and the DAT was black.. that's just not cricket old chap. Then there was cable connection.. well not an issue really, since I have all SCSI types inside.. so the result was..
I fitted a SUN DDS3 Tape (also sun grey).. which is a bit pants, but 12GB of grey tape looks better than 36GB of black.. (I think I'll get a SUN LTO or similar in the future.).
Re: fuel R16000 800MHz 4GB V10 - I am complete!
Unread postby ClassicHasClass » Sat Jan 09, 2016 11:22 pm
I have one of the black Pioneer DVD drives and I put that in along with a black SGI OEM DAT. Matches everything. Sexy.
Unread postby uunix » Sun Jan 10, 2016 6:42 am
I've used tape wherever I have worked and found them to be 100% reliable. Never used DVD/CD and I have had a few issues with Disk drives.
MY tape backups here get stored at work, and work get stored here. All backup tapes are encrypted with passwords, although this wasn't the case in the early days using NT Backup.
Unread postby recondas » Sun Jan 10, 2016 8:28 am
ClassicHasClass wrote:I have one of the black Pioneer DVD drives and I put that in along with a black SGI OEM DAT. Matches everything. Sexy.
A half-height LTO drive should fit in a Fuel and would make for a very a nice high-capacity backup. One with a SCSI interface would probably be a bolt-in solution, but since IP35/the Fuel support LSI SATA/SAS controllers, an SAS-interfaced half-height LTO would probably result in the best performance.
Half-height LTO drives aren't DAT cheap, but with a little patience they do occasionally show up. With the typical it-ain't-mine-you're-on-your-own disclaimer, a brief search turned up a half-height SAS LTO3 (400GB per tape uncompressed) for $129 on eBay (and depending on capacity the SCSI variants can be had for as little as twenty bucks).
uunix if you haven't already seen the thread, another interesting parlor trick supported by the Fuel is IIDC or AV/C video or Compact Flash card access via Firewire.
Unread postby uunix » Sun Jan 10, 2016 1:22 pm
recondas wrote:uunix if you haven't already seen the thread, another interesting parlor trick supported by the Fuel is IIDC or AV/C video or Compact Flash card access via Firewire.
That sir looks an excellent thread, not so much for the firewire etc (at least not now), but for the DM2 in my Octane. Thank You.
Juda$
Unread postby Juda$ » Fri Jan 15, 2016 5:11 am
I am glad to hear its all working out well. Also just to let you know, I never changed the power supply fan so unless Ian Mapleson did before I received it I would presume that its an original.
[/img]
Proud Owner of
SGi Octane
Digital Alphastation
Digital Personal Workstation
Sun Microsystems Ultra Enterprise 2
HP B2000
Unread postby uunix » Thu Feb 25, 2016 5:26 am
Open the front flap on my Fuel and it has very nice matching dark grey SUN DVD & SUN DDS... well it did. Then the flap fell off the DDS!!!
So I've purchased a new black DVD drive and a black LTO2 drive. I had found a SUN Dat72 which would have been nice, but I ummed and arrrd too much and missed out and the SUN LTO's are all double height. So for about £40 I purchased the 2 black drives. Looking forward to fitting them I am.
Users browsing this forum: fleetingthought and 2 guests
