Fuel | 800mhz | 1GB | V12
Unread postby DaJuice » Mon Nov 09, 2015 9:07 pm
It had some stickers over the case to prevent tampering. The seller said it was used by the government but I have no info beyond that. It has a clean install of 6.5.30. I still need to set up a user and get some software on this guy. :)
            IP34 Board: barcode NRZ574     part 030-1707-005 rev -B
        IP34PIMM Board: barcode NPJ964     part 030-2024-001 rev -B
          ASTODY Board: barcode MZK255     part 030-1726-005 rev -A
1 800 MHZ IP35 Processor
CPU 0 at Module 001c01/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
  Processor revision: 3.0. Scache: Size 4 MB Speed 400 Mhz  Tap 0xb
Main memory size: 1024 Mbytes
Memory at Module 001c01/Slot 0: 1024 MB (enabled)
Graphics board: V12
USB controller: type OHCI
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: DEL 16404
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  DEL-16404
         Gain (all color components) - 0.000000 ; range [1,10]
Re: Fuel | 800mhz | 1GB | V12
Unread postby ClassicHasClass » Mon Nov 09, 2015 11:41 pm
Sexy Fuel is sexy.
Unread postby Trippynet » Tue Nov 10, 2015 12:50 am
That is a very nice Fuel indeed! Good skins and excellent spec too.
Unread postby s0ke » Tue Nov 10, 2015 5:35 am
Wow looks brand new. Very nice.
R16K 700: 2GB: V10: Noctua Fans
