Origin 350, 4 x 1 Ghz, 4 GB RAM
xiri
Unread postby xiri » Thu Oct 29, 2015 12:42 pm
Hi,
just picked up this Origin 350 that once ran at SGI. It is in great condition and, surprise,
even comes with a 10 Gigabit Ethernet adapter. It is the 3rd rackserver from top of the stack.
hinv -vm
IP59_4CPU Board: barcode NSJ339 part 030-1989-003 rev -B
2U_INT_53 Board: barcode NTX732 part 030-1809-006 rev -B
Location: /hw/module/001c04/IXbrick/xtalk/15/pci-x/0/1/ioc4
IO9 Board: barcode NWD099 part 030-1771-005 rev -B
4 1.0 GHZ IP35 Processors
CPU 0 at Module 001c04/Slot 0/Slice A: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
Processor revision: 3.0. Scache: Size 16 MB Speed 333 Mhz Tap 0x15
CPU 1 at Module 001c04/Slot 0/Slice B: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c04/Slot 0/Slice C: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c04/Slot 0/Slice D: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Memory at Module 001c04/Slot 0: 4096 MB (enabled)
Bank 7 contains 512 MB (Standard) DIMMS (enabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Integral Gigabit Ethernet: tg0, module 001c04, PCI bus 1 slot 4
10 Gigabit Ethernet: xg1, module 001c04, 100 MHz PCIX bus 2 slot 1
Gigabit Ethernet: tg1, module 001c04, PCI bus 2 slot 2 port 0
Gigabit Ethernet: tg2, module 001c04, PCI bus 2 slot 2 port 1
PCI Adapter ID (vendor 0x17d5, device 0x5831) PCI slot 1
PCI Adapter ID (vendor 0x14e4, device 0x1648) PCI slot 2
IOC4 firmware revision 83
HUB in Module 001c04/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c04/Slot n0: Revision 6.210
:Indigo: :Indigo2: :Indigo2IMP: :Indy: :O2: :O2+: :Octane: :Octane2: :Fuel: :O3x04R: :A3503L: :PrismDT: :Tezro:
BetXen
Re: Origin 350, 4 x 1 Ghz, 4 GB RAM
Unread postby BetXen » Thu Oct 29, 2015 1:49 pm
Lucky you !
Unread postby jan-jaap » Fri Oct 30, 2015 1:41 am
Nice!
I see you've got a few more units for some interesting experiments. That 10G adapter is SX I guess?
xiri
Re: Origin 350, 4x1 Ghz, 4 GB RAM
Unread postby xiri » Fri Oct 30, 2015 2:25 am
Right,
I just took a fast photo from the backside of the O350 with my mobile phone, looking in the IP35 hardware aggregator I cannot
see any 10 GE card in the list.
10 GE NIC (IP35)
Unread postby jan-jaap » Fri Oct 30, 2015 3:08 am
That's an SGI badged Neterion Xframe (S2IO). http://techpubs.sgi.com/library/tpl/cgi ... 10GBENA_UG
Mashek has some: http://www.ebay.com/itm/111536736224
I've seen 'em for less than that but I don't have any 10G infrastructure to connect to..
Unread postby hamei » Sat Oct 31, 2015 10:29 pm
jan-jaap wrote:That's an SGI badged Neterion Xframe ...
They aren't even that expensive ... but I bet a (non-Dlink) 10Gbit switch would be more than my entire retirement fund :(
jwhat
Unread postby jwhat » Thu Dec 07, 2017 4:17 pm
Hi Jan-Jaap, Xiri & others,
I read Neterion XFrame doco & it indicates that you “should not change physical interface” module.
Has anyone tried or looked at possibility of changing from SR/LR optical to 10GBASE-T ?
I see that there are physical media converters available, but these cost as much as (cheap) 10Gbe switch.
Cheers,
jwhat.
