O2, 400MHz R12000A, 576MB RAM, 73GB HDD
macroexp
Unread postby macroexp » Mon Sep 21, 2015 1:21 pm
Just upgraded from a 175MHz R10000 - a much more usable machine post-upgrade. Now if I could just find a 16:9 video mode that would agree with my monitor... And now a 15k RPM 73GB that's much quieter than the machine-gun Quantum Atlas 10k that was in there.
Also, replaced the PSU fan with a quieter (a hair less CFM) more modern fan.
Hardware:
janus 1# hinv -vm
1 400 MHZ IP32 Processor
Main memory size: 576 Mbytes
Secondary unified instruction/data cache size: 2 Mbytes on Processor 0
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
Graphics:
janus 1# /usr/gfx/gfxinfo -vv
        32 + 32 bitplanes
         Monitor 0 type: SAM 693
         Video Output: 1280 pixels, 1024 lines, 59.94Hz (1280x1024_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  SAM-693
HDD info:
janus 1# scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d2l0:  Disk          SEAGATE ST373453LC      DX10
Device is  ready
/dev/scsi/sc0d4l0:  CD-ROM        TOSHIBA CD-ROM XM-5701TA0167
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  reladdr synch linkedcmds
Device is  not ready
OS:
janus 1# uname -aR
IRIX janus 6.5 6.5.30f 07202013 IP32
:O2: (janus): 400MHz R12k, 576MB, 73GB 15k, modded PSU fan
:Indigo2IMP: (indigo2): 195MHz R10k, 512MB, SI, 36GB
Sun Ultra80 (mizar): 4x450MHz USII, 4GB, XVR-1200, 2x73GB 15k ZFS
2x :1600SW:+ML, :Octane: 195MHz R10k, currently not booting
macroexp
Re: O2, 400MHz R12000A, 576MB RAM, 18GB HDD
Unread postby macroexp » Fri Sep 25, 2015 8:08 pm
Yeah it's really a much better machine now - using it a lot more these days. The 400MHz R12k really speeds up the graphics too, feels like a much more modern machine. I'll probably try to max out the ram and maybe put an Audigy in it, well, just because. I also need a 1600SW adapter to hook it up to one of two I have. It's so strange to have the 1600SW hooked up to a Windows98 machine instead of the O2. :)
macroexp
Re: O2, 400MHz R12000A, 576MB RAM, 73GB HDD
Unread postby macroexp » Sat Oct 24, 2015 11:17 pm
Edits to first post and title due to some upgrades to HDD and PSU fan. I also have a Commodore 1084 hanging off the composite output now. I know TV work was one of the design points and practical uses of the O2, but I'm still amazed at how good the NTSC output is. Something about CRT color just seems ... natural.
Unread postby ClassicHasClass » Sun Oct 25, 2015 5:17 pm
I'd love to see a photo of the setup.
Unread postby dexter1 » Mon Nov 09, 2015 4:00 pm
What replacement fan did you install?
macroexp
Unread postby macroexp » Wed Nov 18, 2015 8:24 pm
I used a Cooler Master R4-BM8S-30PK-R0 - supposedly 40.8 CFM @ 3000 rpm, so about 2/3 of the CFM rating on the original fan, and at that rate it's not the quietest fan in the world. Still, it's just air noise now instead of the whine from the original fan. I wanted to err on the side of too loud vs. too little cooling, so I'm pretty happy with the choice.
I'm working on a photo. The photo's not the problem, it's moving enough of the rat's nest around so you can actually see it :)
Unread postby dexter1 » Thu Nov 19, 2015 2:04 am
According to http://datasheet.octopart.com/FBA08A12U ... 276522.pdf the original Panaflo is specced at 46.9 CFM so your Cooler Master is more like 6/7 of the Panaflo CFM rating. And all that cooling with only 28dB noise, that's very good!
You've wisely chosen for more throughput at the expense of noise. In the case of the R12K i fully agree with your decision.
I am waiting for a few hours downtime so i can pop in my replacement fan: EBM Papst 8412 NGME
