Enron Octane 2 | 2x600mhz | 1.5GB | V12 | 70GB & 35GB
Vladio
Unread postby Vladio » Wed Sep 02, 2015 8:23 pm
I picked this Octane 2 up off ebay a couple years ago. The seller was asking $800 and I "offered" $400 thinking he wouldn't go for it - he did. The seller claimed to have worked for Enron although not with the computer. He said a friend worked in the lab where it was used for molecular modeling. It shipped with a spaceball which I never used but supposedly was used in the Enron lab. I can't confirm anything he said but the hardware did have Enron id tags and appears to be legit. Originally it came with a dual 300mhz configuration. I swapped it out for the dual 600's a month ago - it made a big difference in terms of speed. You can see in some of the pics that UPS did their usual shipping handling with these. The monitors took a beating during shipping and I literally poured them out of their boxes. They could of been packed a bit better but UPS beat the s**t out of the boxes, I'm guessing cause they were heavy. I filed a claim and they sent a stooge out to look and take pics. They then denied the claim. I tried to put them back together as best I could. I still have a box of small pieces I'm saving for a cold, snowy day this winter. Thanks for looking!
      PM20600MHZ Board: barcode MZJ219     part 030-1778-001 rev  C
            IP30 Board: barcode MKV518     part 030-1467-001 rev  D
    PWR.SPPLY.ER Board: barcode AAE2370269 part 060-0035-003 rev  A
             FP1 Board: barcode LPE477     part 030-0891-003 rev  H
  ODY128VERSIONB Board: barcode MZJ167     part 030-1611-003 rev  A
2 600 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 1536 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V12
Dual Channel Display
        Managed (":0.0") 2560x1024
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: NEC 26048       Monitor 2 type: NEC 26048
         Video Output: 1280 pixels, 1024 lines, 60.00Hz (2@1280x1024_60)
        Channel 1:
         Origin = (1280,0)
Yes, I do need to clean up the cables under the desk. This winter the whole setup's going to get cleaned up with all the wires cleanly run.
:Octane2: Octane 2, Dual 600MHz R14k's, 2GB, v12
:O2000: Origin 2200, Dual 300mhz, 2GB
:Onyx2R: Onyx2
Mac Pro dual quad Xeon 16GB 1TB
HP dual core 4GB 500GB
Dell Workstation Dual quad Xeon 8GB 500GB RAID
Imac | HP laptop | Compaq | Commodore 64 floppy | TI 99 38k Peripheral Expansion Box
Re: Enron Octane 2 | 2x600mhz | 1.5GB | V12 | 70GB & 35GB
Unread postby foetz » Wed Sep 02, 2015 9:12 pm
corporate gear usually is a good deal. most have been taken good care of and sometimes there's stuff left on the disk(s)
Unread postby uunix » Thu Sep 03, 2015 3:36 am
How neat and tidy is your setup.. :shock: :mrgreen: NICE!
Vladio
Unread postby Vladio » Thu Sep 03, 2015 8:31 am
It only came with one drive and it wasn't the original from Enron. It was reformatted but not 0'ed out so I was able to go through it. It was from Hertz car rental in Las Vegas. Nothing good on it. I was thinking, the original disk might of been confiscated or someone knew that it was best destroyed.
:Onyx2R: Onyx2
Vladio
Unread postby Vladio » Thu Sep 03, 2015 9:46 am
ivelegacy wrote:I have spoken with a dude from Ducati, and he confirmed they have destroyed everything when they switched from SGI/Irix to PC/Windows. Damn, an other good occasion lost, they were using CATIA and a lot of things from Alias-wavefront on their machines.
That's a shame. Kawasaki prob would of paid good money for those files. :lol: They can prob still get them from the Chinese. :lol: :lol:
:Onyx2R: Onyx2
Vladio
Unread postby Vladio » Thu Sep 03, 2015 9:47 am
uunix wrote:How neat and tidy is your setup.. :shock: :mrgreen: NICE!
The wires under the counter are really f'n with my ocd! :lol:
:Onyx2R: Onyx2
Unread postby uunix » Thu Sep 03, 2015 11:23 am
And that's why I never look under my desk.
Vladio
Unread postby Vladio » Thu Sep 03, 2015 11:58 am
I can't not see that mess! :lol: it jumps right out at me as soon as I walk in. :?
:Onyx2R: Onyx2
Unread postby ClassicHasClass » Fri Sep 04, 2015 12:14 am
An Enron SGI? You'd better check that the power is regulated.
Unread postby guardian452 » Sat Sep 05, 2015 11:19 am
nice posters of fairchild and steve&steve
Vladio
Unread postby Vladio » Sat Sep 05, 2015 2:30 pm
guardian452 wrote:nice posters of fairchild and steve&steve
To the left of the Steve's I have a nice pic of Eckert & Mauchly in the computer lab of the University of Pennsylvania.
:Onyx2R: Onyx2
nongrato
Unread postby nongrato » Fri Sep 11, 2015 9:49 am
You seem to have the same CD-ROM(Yamaha) as mine but in a different box. Does yours support software inject? (what happens if you enter "inject" in a shell prompt?)
:Octane2: :320:
Vladio
Unread postby Vladio » Fri Sep 11, 2015 7:22 pm
nongrato wrote:You seem to have the same CD-ROM(Yamaha) as mine but in a different box. Does yours support software inject? (what happens if you enter "inject" in a shell prompt?)
IRIS 1# inject
inject: Software inject not supported. Use hardware inject.
IRIS 2#
I think I still have the original drive from Enron somewhere. I'll look for it tomorrow...I believe "inject" worked with it.
:Onyx2R: Onyx2
nongrato
Unread postby nongrato » Sat Sep 12, 2015 4:41 pm
Vladio wrote:Software inject not supported.
Same here. That's strange because this cdrom worked fine with my Octane1.
:Octane2: :320:
Unread postby recondas » Thu Sep 24, 2015 4:30 am
ivelegacy wrote:I like the dual carrier you have, it allows to have two LCDs on the same frame … umm is it a custom frame or a commercial one ? I'd like to pick up one.
Based on the shape of the stand, it looks like an Ergotron DS100. Ergotron makes the DS100 in a number of multi-monitor configurations from dual (vertical or horizontal) to quad.
I have dual and quad versions, the expanded desktop makes it very easy to keep track when multiple applications are run at the same time. The base is very heavy (to serve as a counterweight), so in spite of the top-heavy appearance of the four-monitor arrangement it's very stable.
They can occasionally be found used on eBay for a reasonable price, but typically the listings are new products at full msrp, or used setups that include the price of monitors.
There's a dual version listed on US eBay with a buy-it-now price of $24 (plus shipping): http://www.ebay.com/itm/Ergotron-DS100- ... 1869835475
