Octane2: 2xR14k@600MHz, V12, 4.5Gb
nongrato
Unread postby nongrato » Mon Aug 24, 2015 8:57 am
Last weekend I traveled to Moscow(~700kms from my place) to get myself a very phat Octane2. This used to be a Smoke system at Mosfilm. Originally it was equipped with a PCI-cage, three FC cards and a Dmedia board(no cables or VBOB), but I removed them because: 1) I can't make use of them, 2) fastfan.
Cosmetic condition is fair(especially after car plastic polish treatment), but the front door is missing, I am looking to buy one.
The current specs are:
      PM20600MHZ Board: barcode MSL454     part 030-1778-001 rev  C
            IP30 Board: barcode JMJ369     part 030-1467-001 rev  C
             FP1 Board: barcode MCC421     part 030-0891-003 rev  H
    PWR.SPPLY.ER Board: barcode AAE9020338 part 060-0035-001 rev  B
  ODY128VERSIONB Board: barcode MPH758     part 030-1611-001 rev  C
       XTALK_PCI Board: barcode MYX073     part 030-1275-005 rev  A
2 600 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 4608 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V12
Gigabit Ethernet: tg1, PCI slot 1
gfxinfo:
        Managed (":0.0") 1600x1200
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1600 pixels, 1200 lines, 72.24Hz (1600x1200_72)
GL1zdA
Re: Octane2: 2xR14k@600MHz, V12+DCD, 4.5Gb
Unread postby GL1zdA » Mon Aug 24, 2015 10:56 am
Fat indeed. I'm envious.
chicaneuk
Unread postby chicaneuk » Tue Aug 25, 2015 12:07 am
Beast! Nice Octane :)
eudatux23
Unread postby eudatux23 » Tue Aug 25, 2015 12:41 am
Very nice system!
:Octane2: SGI Octane 2 - Dual R12K 400 MHz - 250 0MB RAM - 73 GB HDD - vPro v12 - IRIX 6.5.30
:Indigo2IMP: SGI Indigo² - R10K 175 MHz - 320 MB RAM - 73 GB SCSI HDD - High Impact-AA + TRAM - IRIX 6.5.22f
:O2: SGI O2 - R5K 180 MHz - 96 MB RAM - 18 GB HDD - CRM - IRIX 6.5.30
Unread postby uunix » Tue Aug 25, 2015 12:59 am
Excellent. Worth the long trip I suspect.
Unread postby Trippynet » Tue Aug 25, 2015 2:41 am
Impressive! That's pretty much as maxed out as they come. Well worth the long drive I'd say!
nongrato
Unread postby nongrato » Tue Aug 25, 2015 11:00 am
Thanks, guys!
Alright, that DCD option appeared to be an useless piece of junk. The display mode is set to 72Hz, but my monitors actually don't do more than 30Hz. After five minutes my eyes feel like they're gonna bleed and the powerflip demo performs at 30FPS maximum(on a V12!) If someone wants it, I will willingly trade it for something useful, like a front door for my Octane2.
Unread postby uunix » Tue Aug 25, 2015 12:21 pm
I would indeed make that swap, but fear posting a plastic door weighing 10 grams to Russia would cost more than an Octane 2
Unread postby uunix » Tue Aug 25, 2015 12:26 pm
Actually nongrato if you make the journey to the UK, I'll give you a CRT (BNC/VGA) monitor that works at higher res and a front door for free.
nongrato
Unread postby nongrato » Wed Aug 26, 2015 3:51 am
Shipping a VW keyboard(which is way bigger and heavier)from the Netherlands was 29€.
Unread postby recondas » Wed Aug 26, 2015 8:16 am
nongrato wrote:Alright, that DCD option appeared to be an useless piece of junk. The display mode is set to 72Hz.....
Unless you're running an IRIX install modified specifically to suit Smoke, there should be a number of alternative DCD-compatible display formats to select from.
If you'd like to use the DCD to span your display across two monitors (of equal resolution), look in xsetmon for display formats prefaced with "2@" that meet your requirements.
Don't load a 2@ format if you have only one monitor connected, the single display will only receive half of the signal and may flicker horribly.
If you don't wish use a 2@ expanded display (or for the time being have only one monitor), just select any of the other single-monitor formats (that don't include the 2@ preface) that match your single monitor. If your monitor is analog, connect to the 13W3 port, if it's digital connect it to either of the DVI ports. In either case, all three ports will receive the same single image display.
nongrato
Unread postby nongrato » Wed Aug 26, 2015 11:22 am
recondas wrote:there should be a number of alternative DCD-compatible display formats
Which ones of them are DCD-compatible?
recondas wrote:Don't load a 2@ format if you have only one monitor connected,
Thanks, but I think I'm not an imbecile. Of course I tested it with two different sets of monitors: two LCDs, then two CRTs. It doubles the working space, but cuts the performance by the same amount. Absolutely worthless and overrated piece of junk: typical SGI. Thankfully I already have a buyer.
Krokodil
Unread postby Krokodil » Fri Aug 28, 2015 2:36 pm
That is a very nice find, looks like it's in great shape too. Hopefully it won't cause you grief like the previous one.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
gocram
Unread postby gocram » Fri Aug 28, 2015 6:36 pm
First of all, I must say, that's an amazing system you found! Nice pictures, thank you for sharing.
nongrato wrote:Image
Beware, those are the Flint/Flame and Smoke-tailored Odyssey (VPro) profiles from Discreet for usage in combination with Stingray (DMediaPro, e.g. DM2 for the Octane2 or DM3 for the Tezro and the VBOB with the DM5 daughterboard) video hardware. The flicker is simply the result of your monitor loading an unusual resolution and refresh rate, which is normally intended for use with a specific SGI-branded 23" or 24" CRT high resolution graphics (IFFFS jargon, i.e. ‘standard’ computer) monitor together with, ideally, a broadcast monitor, where both are synchronized, for the so-called graphics-to-video functionality.
So, if you instead want a multi-head monitor setup with a large desktop, you should ignore those Discreet profiles and rather pick one of the ‘standard’ display resolution and specifically multiple monitor setup profiles (see the lower left-hand panes in xsetmon) as delivered by SGI. Like that you can also simply go for, say, 1920 × 1200 over each of the DCD's DVI outputs, compared to the slightly lower resolution of 1920 × 1154 (as provided by Discreet for Flint/Flame and Smoke usage, as seen in the list in your screenshot; this is due the pixel clock limitation of the DM5, the non-standard implementation of the HD-SDI signal output on the VBOB, or maybe both, as I don't fully recall at the moment).
LOOKING FOR:
ITEMS FOR SALE/TRADE
nongrato
Re: Octane2: 2xR14k@600MHz, V12, 4.5Gb
Unread postby nongrato » Thu Sep 24, 2015 10:02 am
DCD sold, hinv updated.
:Octane2: :320:
