New Indigo XZ 4000
New Indigo XZ 4000
Unread postby uunix » Thu Aug 20, 2015 2:39 pm
Well, picked up my goodies from chicaneuk tonight and drove back very smoothly.
First problem, TOC battery, previous owner had done the mod, but connection wasn't secure.. sellotape and a hair clip has solved that.
While the Date was well out there was all sorts of failures, but setting the date has solved them.
Machine is in excellent condition and clean (thanks chicaneuk) albeit a few scratch's on the roof.
Came with a shitload of stuff, software, cables drives & enclosures.
BUT!!!!
Mouse does not work..
Logging in as root has the cursor in the centre of the screen on top of a shell.. So I can type stuff, but navigating around is a bit of an issue (ideas?).
In the collection of software, there is a CD called Desktop Special Edition 1.1 1995 812-0410-002 11/95
So much software, I haven't had a chance to go through it yet.
Of interest installed on the system, Usual C/C++/Fortran etc.. plus Pro/Engineer & it works.. and when it works.. the mouse moves, in very small jumps..
I'll post hinv once I get it on the network.. and it's name is BLACK...
I cannot believe after all these years I have an Indigo again.. without doubt my favourite SGI! :D
### Edit ### I think the mouse is disabled because it had tablet????
### Edit Edit ### And relax.. it's now working... :?
### Edit Edit Edit ### After a cold boot it starts playing up again. Mouse ball? Heat?
### Edit Edit Edit Edit ### Turns out it was a sticky ball.. judging by what I found.. I am not surprised.
grxinfo
   2 GEs, 1 RE, 24 bitplanes, 4 auxplanes, 4 cidplanes, Z-buffer
   GR2 revision 2, VB1.1
   HQ2 rev A, GE7 rev B,  RE3 rev D, VC1 rev B, MC rev C
   19" monitor
hinv -vm
CPU: MIPS R4000 Processor Chip Revision: 3.0
1 100 MHZ IP20 Processor
Main memory size: 128 Mbytes
Instruction cache size: 8 Kbytes
Data cache size: 8 Kbytes
Integral SCSI controller 0: Version WD33C93B, revision C
On-board serial ports: 2
Graphics board: GR2-XZ
Iris Audio Processor: revision 10
Well, chicaneuk did say he was a nice guy and that he was a graphics engineer.. well judging by the amount of porn I've found, I suspect he did very little work! The machines full of it!
Re: New Indigo XZ 4000
Unread postby foetz » Thu Aug 20, 2015 10:48 pm
uunix wrote:judging by the amount of porn I've found, I suspect he did very little work! The machines full of it!
:lol:
Pontus
Unread postby Pontus » Thu Aug 20, 2015 11:53 pm
Nice! vintage porn! :-D
Has anyone taken it upon them self to archive the early days of porn on the web? :twisted:
pentium
Unread postby pentium » Sat Aug 22, 2015 9:13 am
Pontus wrote:Nice! vintage porn! :-D
I got like, 20 ZIP disks I was given at a sci-fi convention of archived BBS porn from the very late 90's and before.
I keep that box for special occasions. ;)
Unread postby uunix » Sat Aug 22, 2015 10:11 am
pentium wrote:I got like, 20 ZIP disks I was given at a sci-fi convention of archived BBS porn from the very late 90's and before.
I have a zip drive :D
chicaneuk
Unread postby chicaneuk » Mon Aug 24, 2015 12:27 am
LOL - are you serious about the porn? Haha :) The drive in my system was dead so I never got to find out of there was anything interesting on it!
Unread postby robespierre » Mon Aug 24, 2015 1:23 am
I was alive for "BBS porn" (when the image had a watermark with a telephone number on it!) and I would be sincerely shocked if there was any after 1995. That's when almost all BBS's shut down for lack of interest.
Unread postby hamei » Mon Aug 24, 2015 2:49 am
robespierre wrote: I would be sincerely shocked if there was any after 1995. That's when almost all BBS's shut down for lack of interest.
Not exactly lack of interest, but BBSes were expensive ! Unless you had one right down the street, the phone bills were astronomical.
Unread postby uunix » Wed Aug 26, 2015 12:41 pm
So, with a problem with the randomizing chip inside the keyboard and mouse, I thought I'd just export the display and leave it headless.
First thing I wanted to play with was pro/E..
'YOU ARE ATTTEMPTING TO RUN A LOCKED Pro/E WITH AN INVALID DIPLAY SETTING.
PAH!!!
ah well surely the porn will work!
