Onyx 350 IP 4x600Mhz & 4x700MHz, 3Gb
jeffwa
Unread postby jeffwa » Thu Apr 30, 2015 4:58 pm
This is another system I've been trying to get my hands on...not sure why, I can't stand Origin 350's. I guess the only logical reason is because I have rack space to spare, but not floor space for a deskside system. This one has an interesting story....it appears to be an engineering model (labeled as such) and originally had a lot of odd behaviors but is now working quite nicely. List of issues included env monitoring turned off, probably because of fan and power issues that would cause the brick to power itself down. Power issues were due to a bad HD (dang, no poking around the old root disk) and fan issues were simply fan's not plugged in. The one REALLY odd thing is that when I originally booted it up the PROM splash said "SGI Visual Workstation", but the l1 confirmed that it was a chimera blade. I'm kicking myself for not taking a picture because after re-flashing the PROM it now shows the expected "SGI Onyx Infinite Pefformance". *shurg* Anyone else see a Chimera blade display "Visual Workstation" before?
Also added another O350 brick to it just for kicks...
hinv
Processor 0: 600 MHZ IP35
Processor 1: 600 MHZ IP35
Processor 2: 600 MHZ IP35
Processor 3: 600 MHZ IP35
Processor 4: 700 MHZ IP35
Processor 5: 700 MHZ IP35
Processor 6: 700 MHZ IP35
Processor 7: 700 MHZ IP35
Main memory size: 3072 Mbytes
Integral SCSI controller 3: Version IDE (ATA/ATAPI) IOC4
  CDROM: unit 0 on SCSI controller 3
Integral SCSI controller 5: Version QL12160, low voltage differential
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
IOC3/IOC4 serial port: tty7
IOC3/IOC4 serial port: tty8
IOC3/IOC4 serial port: tty9
IOC3/IOC4 serial port: tty10
Graphics board: V12
Gigabit Ethernet: tg1, module 001c02, PCI bus 1 slot 4
And gfxinfo
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: DEL -8187
:A3504L: :320: :1600SW: :Indy: :O2: :O2: :O2+: :Octane2: :Indigo2IMP: :Indigo2IMP:
Re: Onyx 350 IP 4x600Mhz & 4x700MHz, 3Gb
Unread postby foetz » Thu Apr 30, 2015 10:43 pm
jeffwa wrote:it appears to be an engineering model (labeled as such)
might have been a test prom without updated text. cosmetics like that are usually ignored by engr. versions as they don't matter
Unread postby recondas » Fri May 01, 2015 7:02 pm
Congratulations! That's a very interesting system.
Because of it's unique engineering sample status, you might consider including the output of some of the L1 commands that could reveal differences between your system and production versions. Perhaps serial all, env, flash status, pci and topology -t (feel free to ad-lib at will).
In any case, thanks for sharing.
