Indigo2 195MHz R10k, 128MB RAM, Solid Impact
Unread postby jeffwa » Sat Apr 25, 2015 12:52 pm
I've been trying to add an Indigo2 to my collection for quite awhile and was lucky enough to snag TWO :) Both are in really good condition, the original quantum drives are even functional. I swapped the drives out using the method described in viewtopic.php?f=3&t=16728931 (huge thanks to darkninja for the detailed instructions). I won't do two hinv's because they're identical systems.
1 195 MHZ IP28 Processor
Main memory size: 128 Mbytes
On-board serial ports: 2
Graphics board: Solid Impact
EISA bus: adapter 0
:A3504L: :320: :1600SW: :Indy: :O2: :O2: :O2+: :Octane2: :Indigo2IMP: :Indigo2IMP:
Re: Indigo2 195MHz R10k, 128MB RAM, Solid Impact
Unread postby foetz » Sat Apr 25, 2015 1:18 pm
yeah a pair is great. not running out of spares too soon :-)
Unread postby chicaneuk » Sat Apr 25, 2015 2:38 pm
Shame they're only SolidIMPACT's but still looks like a good haul :)
Ryan Fox
Unread postby Ryan Fox » Wed Apr 29, 2015 10:55 am
Worth every hour that you put into them. They may be slow by today's standard, but can still serve as functional terminal/light workstation. :)
MAYA, nut-
