Indigo2 195MHz R10k, 384MB RAM, Max Impact, 2x4GB disk
julesr
Unread postby julesr » Sun Apr 19, 2015 9:47 am
Here's the specs on my ex-Cray I2 with the Max Impact board set. I'm guessing that the granite CRT is an ex-Indy one (the guy I got it from had a bunch of Indy systems too) and that originally it would have had a white CRT to match the keyboard and mouse.
Now I just need to figure out something impressive to run on it!
hinv:
(eddy) ~ # hinv -vm
1 195 MHZ IP28 Processor
Main memory size: 384 Mbytes
On-board serial ports: 2
Graphics board: Maximum Impact/TRAM option card
EISA bus: adapter 0
gfxinfo:
(eddy) ~ # /usr/gfx/gfxinfo -v
        Product ID 0x0, 2 GEs, 2 REs, 4 TRAMs
        MGRAS revision 3, RA revision 5, RB revision 4
        VC3 rev A, CMAP rev DMC rev D
        16" monitor (id 0x2)
        Video board present
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
uname:
(eddy) ~ # uname -a
IRIX64 eddy 6.5 07151433 IP28
thanks
Jules
Re: Indigo2 195MHz R10k, 384MB RAM, Max Impact, 2x4GB disk
Unread postby foetz » Sun Apr 19, 2015 9:53 am
congrats, pretty much as much indigo as you can get :D
julesr
Unread postby julesr » Sun Apr 19, 2015 1:13 pm
Thanks - yeah, it is... I think I may have some larger-capacity RAM for it, but to be honest what with the graphics option and additional drive it's probably just about at the limit cooling-wise already - and 384 should be enough to play with! Only thing it's missing is the CD drive, but I think I can borrow one from one of my Sun machines if ever needed (I have the internal sled, just not the drive)
Unread postby foetz » Sun Apr 19, 2015 1:21 pm
yeah sun drives should work
ajw99uk
Unread postby ajw99uk » Sun Apr 19, 2015 2:45 pm
julesr wrote:Thanks - yeah, it is... I think I may have some larger-capacity RAM for it, but to be honest what with the graphics option and additional drive it's probably just about at the limit cooling-wise already - and 384 should be enough to play with!
Do you have 12x 32MB SIMMs? Swapping to 8x 64MB (ideally single sided) or 4x 128MB (if you can find them!) could give you more RAM for less power/heat? I don't stretch the 384MB in my I2 but that's "only" an R4K so I tend to avoid multi-multi-tasking!
Nice machine - wish I'd "gone purple" when jumping into SGI ownership. Don't think I'd get away with adding a second I2 (having since acquired a Fuel and - lurking away under the table until uunix decides what to do with another one - an Octane, and see my .sig for the non-IRIX set-up).
For CDROMs, my I2 has happily read from / burned to a Yamaha 8824S (but not sure if you could boot from it). A CDROM sled is working its way up the list of desiderata.
Welcome to nekochan
Unread postby uunix » Sun Apr 19, 2015 2:57 pm
Welcome to nekochan
aj, that penny Octane is all yours unless you don't want it.
julesr
Unread postby julesr » Sun Apr 19, 2015 3:16 pm
ajw99uk wrote:Do you have 12x 32MB SIMMs? Swapping to 8x 64MB (ideally single sided) or 4x 128MB (if you can find them!) could give you more RAM for less power/heat? I don't stretch the 384MB in my I2 but that's "only" an R4K so I tend to avoid multi-multi-tasking!
Yes, the machine's got 12x32 at the moment - I hadn't actually thought of larger-capacity modules being less power-hungry, but maybe they are and so there's scope for boosting the RAM without contributing significantly to the heat.
I had the choice of a teal or purple machine, and that was a no-brainer as I really don't like the look of teal ones ;) I didn't know at the time that it had such a high-spec (I'm not sure that the previous owner did either, he'd never actually powered it up), and that it had its shipping box and feet.
ScutBoy
Unread postby ScutBoy » Sun Apr 19, 2015 6:17 pm
Jules,
Have fun! ;)
Steve
:O2: :Indigo: :Cube: Image
julesr
Unread postby julesr » Sun Apr 19, 2015 7:44 pm
ScutBoy wrote:Jules,
Have fun! ;)
Steve
Steve! Definitely. It's a beautiful system!
Did you see that I got the Origin loaded up as far as possible (it doesn't have the right router boards to take four nodes)? It does indeed have a snafu front-panel switch as you suspected, but I think that I can fix it. I left it running on Friday because it was a cold day and it kept the room nice and toasty ;)
J.
Unread postby jan-jaap » Sun Apr 19, 2015 11:58 pm
Indigo2 MaxImpact is definitely a very nice Indigo2. Congrats.
julesr wrote:Did you see that I got the Origin loaded up as far as possible (it doesn't have the right router boards to take four nodes)? It does indeed have a snafu front-panel switch as you suspected, but I think that I can fix it.
I have both the router board(s) and the front panel switch but I'm on the wrong side of the Atlantic.
chicaneuk
Unread postby chicaneuk » Mon Apr 20, 2015 12:49 am
Very nice system indeed :)
