Origin 2200 4 x R10k 250MHz, 2GB RAM
julesr
Unread postby julesr » Fri Apr 17, 2015 6:14 pm
Here's the Origin 2200 that I picked up a few weeks ago, running with two node boards fully populated with 64MB DIMMS, quad-port differential SCSI board, dual-port FC SCSI board, and a quad-port network / six-port serial combo board.
hinv output:
o22k 3# hinv -vm
        MODULEID Board: barcode K0027972   part              rev
       8P12_MPLN Board: barcode KAC200     part 030-1535-001 rev  B
            IP31 Board: barcode HXE840     part 030-1255-003 rev  D
        IP31PIMM Board: barcode DGK362     part 030-1313-002 rev  B
            IP31 Board: barcode HXE723     part 030-1255-003 rev  D
        IP31PIMM Board: barcode HXE954     part 030-1313-002 rev  A
          BASEIO Board: barcode KCF457     part 030-1124-002 rev  M
           MSCSI Board: barcode HMK175     part 030-1243-001 rev  M
   FIBRE_CHANNEL Board: barcode EAA623     part 030-0927-003 rev  B
           MENET Board: barcode GAH822     part 030-0873-003 rev  E
4 250 MHZ IP27 Processors
FPU: MIPS R10010 Floating Point Chip Revision: 3.4
CPU 0 at Module 1/Slot 1/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
  Processor revision: 3.4. Scache: Size 4 MB Speed 250 Mhz  Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 2/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
  Processor revision: 3.4. Scache: Size 4 MB Speed 250 Mhz  Tap 0x19
CPU 3 at Module 1/Slot 2/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
Main memory size: 2048 Mbytes
Memory at Module 1/Slot 1: 1024 MB (enabled)
  Bank 0 contains 128 MB (Standard) DIMMS (enabled)
  Bank 1 contains 128 MB (Standard) DIMMS (enabled)
  Bank 2 contains 128 MB (Standard) DIMMS (enabled)
  Bank 3 contains 128 MB (Standard) DIMMS (enabled)
  Bank 4 contains 128 MB (Standard) DIMMS (enabled)
  Bank 5 contains 128 MB (Standard) DIMMS (enabled)
  Bank 6 contains 128 MB (Standard) DIMMS (enabled)
  Bank 7 contains 128 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 2: 1024 MB (enabled)
Integral SCSI controller 7: Version Fibre Channel AIC-1160, revision 1
Integral SCSI controller 2: Version QL1040B (rev. 2), differential
Integral SCSI controller 3: Version QL1040B (rev. 2), differential
Integral SCSI controller 4: Version QL1040B (rev. 2), differential
Integral SCSI controller 5: Version QL1040B (rev. 2), differential
Integral SCSI controller 6: Version Fibre Channel AIC-1160, revision 1
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
IOC3/IOC4 serial port: tty7
IOC3/IOC4 serial port: tty8
Fast Ethernet: ef1, version 1, module 1, slot io3, pci 0
Fast Ethernet: ef2, version 1, module 1, slot io3, pci 1
Fast Ethernet: ef3, version 1, module 1, slot io3, pci 2
Fast Ethernet: ef4, version 1, module 1, slot io3, pci 3
Origin BASEIO board, module 1 slot 1: Revision 4
Origin MSCSI board, module 1 slot 4: Revision 4
  PCI Adapter ID (vendor 0x1077, device 0x1020) PCI slot 2
  PCI Adapter ID (vendor 0x1077, device 0x1020) PCI slot 3
Origin FIBRE CHANNEL board, module 1 slot 6: Revision 3
Origin MENET board, module 1 slot 3: Revision 3
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 0
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 1
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 3
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 0
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 1
IP27prom in Module 1/Slot n2: Revision 6.111
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.156
uname output:
o22k 4# uname -a
IRIX64 o22k 6.5 10060437 IP27
Re: Origin 2200 4 x R10k 250MHz, 2GB RAM
Unread postby recondas » Sat Apr 18, 2015 1:51 pm
Congratulations, that's a very nice setup.
Vladio
Unread postby Vladio » Sat Sep 26, 2015 9:31 am
Nice! I just found one myself.
:Octane2: Octane 2, Dual 600MHz R14k's, 2GB, v12
:O2000: Origin 2200, Dual 300mhz, 2GB
:Onyx2R: Onyx2
Mac Pro dual quad Xeon 16GB 1TB
HP dual core 4GB 500GB
Dell Workstation Dual quad Xeon 8GB 500GB RAID
Imac | HP laptop | Compaq | Commodore 64 floppy | TI 99 38k Peripheral Expansion Box
Unread postby vishnu » Sat Sep 26, 2015 4:25 pm
Hey guys post some pics fer cryin' out loud! :P
Vladio
Unread postby Vladio » Sat Sep 26, 2015 6:33 pm
vishnu wrote:Hey guys post some pics fer cryin' out loud! :P
Ha ha, will do. I just put it back together...disassembled it, cleaned it - inside and out, and reassembled. I'd of made Chip Foose proud.
:Onyx2R: Onyx2
Unread postby vishnu » Sun Sep 27, 2015 12:02 pm
I try to clean my computers out once a year. Well, the ones I use regularly anyway. A good air compressor makes that much less of a daunting task than would otherwise be the case.
Vladio
Unread postby Vladio » Sun Sep 27, 2015 1:51 pm
It's amazing the thick wad of dust that builds up in them. My computer room has laminate flooring and I clean in there frequently, those don't get bad but the ones over carpet get a lot of dust buildup. :shock:
:Onyx2R: Onyx2
Unread postby vishnu » Sun Sep 27, 2015 3:33 pm
I wish I had one room big enough for all my computers, currently they're spread over three rooms and they're all dominated by dust bunnies. :shock:
Unread postby ClassicHasClass » Mon Sep 28, 2015 8:26 am
I have a HEPA filter in the office going full blast and it still gets dusty, but I'm going to blame that on the cat and her litter box in the laundry room next door.
Unread postby vishnu » Mon Sep 28, 2015 11:43 am
ClassicHasClass wrote:I have a HEPA filter in the office going full blast and it still gets dusty, but I'm going to blame that on the cat and her litter box in the laundry room next door.
My computers are HEPA filters, since all the dust seems to end up inside them... :shock:
Unread postby uunix » Mon Sep 28, 2015 12:15 pm
My computers are dust bunny generators.. there were no dust bunnies until they arrived!
Unread postby robespierre » Mon Sep 28, 2015 1:03 pm
The ultimate source of dust is organic material from living things. People shed skin and hair; clothes shed fibers; and plants shed pollen, leaves, and bark. This is most of the dust that you see. Computers don't make any dust, they just trap it in places where it gets stuck.
Unread postby vishnu » Mon Sep 28, 2015 1:22 pm
ivelegacy wrote:understood
the attic has
  • no plants
  • no cats
  • no dogs
  • no human beings
so, no bunnies dust exist there
logical consequence: put all your machines in the attic :D
Okay, post a picture of this magical attic containing your IP30 or I say it doesn't exist! :lol:
Unread postby uunix » Mon Sep 28, 2015 1:41 pm
I swear legacy, you are on more drugs than the Rolling Stones ever were!
Unread postby uunix » Mon Sep 28, 2015 1:44 pm
the attic has
  • no plants
  • no cats
  • no dogs
  • no human beings
And make sure Lady GaGa is there as well.
