Octane 2 R12000 300MHz 1.5GB v6
Unread postby uunix » Mon Apr 06, 2015 2:37 am
This is the Octane 2 from the bunch I got down London some weeks back.
hinv
octane3 1# hinv -vm
      PM10300MHZ Board: barcode JKN337     part 030-1355-001 rev  M
            IP30 Board: barcode GRC962     part 030-0887-003 rev  M
    PWR.SPPLY.ER Board: barcode AAE1330132 part 060-0035-003 rev  A
             FP1 Board: barcode 98648B     part 030-0891-003 rev  C
           ODY32 Board: barcode LDE197     part 030-1403-003 rev  B
1 300 MHZ IP30 Processor
Heart ASIC: Revision E
Main memory size: 1536 Mbytes
Xbow ASIC: Revision 1.3
Graphics board: V6
octane3 2#
grxinfo (running headless)
octane3 2# /usr/gfx/gfxinfo
        Managed (":0.0") 1280x720
        BUZZ version A.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: Unknown
octane3 3#
smj
Re: Octane 2 R12000 300MHz 1.5GB v6
Unread postby smj » Tue Apr 07, 2015 3:50 am
A perfectly cromulent system. It's noble spirit would embiggen even the smallest nekochanner...
Unread postby uunix » Tue Apr 07, 2015 4:22 am
Indeed it is smj
Unread postby vishnu » Thu Apr 09, 2015 3:44 pm
Nice! :mrgreen:
What'cha gon' do with it? :?: :?: :?:
Unread postby foetz » Thu Apr 09, 2015 3:54 pm
vishnu wrote:Nice! :mrgreen:
please don't say playing quake :lol:
Unread postby uunix » Thu Apr 09, 2015 4:12 pm
Not a fan on Quake.. I think they look silly in those TRON like outfits.
What to do with it.. No idea yet. Probably end up spending loads of money on it to bring it up to the same spec as my other Octane2.
Maybe a BZ server?
