Octane R12000 300MHz 640MB SSI (Nothing flash)
Unread postby uunix » Wed Mar 18, 2015 5:40 pm
      PM10300MHZ Board: barcode KFZ121     part 030-1355-001 rev  M
            IP30 Board: barcode GYY448     part 030-0887-004 rev  B
             FP1 Board: barcode 42452C     part 030-0891-003 rev  E
    PWR.SPPLY.ER Board: barcode AAE9160539 part 060-0035-002 rev  A
            GM20 Board: barcode ESC890     part 030-0957-003 rev  H
1 300 MHZ IP30 Processor
Heart ASIC: Revision E
Main memory size: 640 Mbytes
Xbow ASIC: Revision 1.3
  Disk drive / removable media: unit 2 on SCSI controller 0: 720K/1.44M floppy
Graphics board: SSI
Machine I bought a few weeks back, it was the R10000, fitted new R12000 300MHz[edited.. originally stated 3000MHz]. Clean install IRIX (just finished a net install after a few hiccups), popped in a tape and a floppy (but will probably remove the floppy after I've installed all the old stuff from floppies into my SoftWindows). It came with 3 Drives, 1x9GB currently installed & 2 34GB (One of which my son destroyed by knocking it off the table). I've got some video cards in the loft I'll be testing etc. All in all a nice clean box, a shame the front door panel broke in transit. Oh and it has a Cherokee PSU.
It does feel quite nippy.
Re: Octane R12000 300MHz 640MB SSI (Nothing flash)
Unread postby foetz » Wed Mar 18, 2015 5:52 pm
uunix wrote:fitted new R12000 3000MHz.
:shock:
:shock:
Unread postby uunix » Wed Mar 18, 2015 5:54 pm
:shock:
:shock:
3000Mhz.. :lol:
Unread postby vishnu » Wed Mar 18, 2015 6:35 pm
I had a hella time installing IRIX on my new Tezro, until I realized that the advertised-as-brand-new SCSI disk that I bought off ebay was toast. Things went much better after I put in a functioning disk... :mrgreen:
Unread postby uunix » Thu Mar 19, 2015 3:06 am
vishnu wrote:I had a hella time installing IRIX on my new Tezro, until I realized that the advertised-as-brand-new SCSI disk that I bought off ebay was toast. Things went much better after I put in a functioning disk... :mrgreen:
A working disk help immensely.
I did find that, with my son knocking the disk of the table, it did not behave like toast/bread does and landed on it's corner. It's funny, but as soon as I put it on the table, a thought went through my mind that someone would knock it off.. and they did!
Unread postby uunix » Thu Mar 19, 2015 2:46 pm
New hinv after a bit of messing tonight
Main memory size: 1024 Mbytes
Graphics board: MXI
What I don't get, unless I'm being silly, 8 Slots of 256Mb should equate to 2GB? Which what I have installed.
chicaneuk
Unread postby chicaneuk » Thu Mar 19, 2015 3:01 pm
Nice :) Is it early type green skins as per the Octane's you had to scrap?
Unread postby uunix » Thu Mar 19, 2015 3:06 pm
Yes, but very very clean. (apart from the slightly broken front door - not visible from front).
ajw99uk
Unread postby ajw99uk » Thu Mar 19, 2015 4:44 pm
uunix wrote:What I don't get, unless I'm being silly, 8 Slots of 256Mb should equate to 2GB? Which what I have installed.
Eight 256MB DIMMs or four 256MB kits? The labelling on DIMMs sold as part of two-DIMM kits often (usually?) shows the kit size. Once bought what I thought would be four 32MB SIMMs for the I2 which turned out to be 32MB in total because the seller had been caught out by that label "convention" (immediate refund, so sure it was an innocent mistake).
Unread postby uunix » Thu Mar 19, 2015 4:51 pm
good point, label says 256 on each stick from Kingston, so maybe you're right. Oh well.. better than original 600 odd MB
ajw99uk
Unread postby ajw99uk » Fri Mar 20, 2015 5:57 am
ajw99uk wrote:Eight 256MB DIMMs or four 256MB kits?
uunix wrote:good point, label says 256 on each stick from Kingston, so maybe you're right. Oh well.. better than original 600 odd MB
KSG-OCT/256 is definitely a kit part number - is that what you've got? - but 60% more RAM is better than 60% less!
Time to update the thread heading?
Unread postby uunix » Fri Mar 20, 2015 6:19 am
I hope no one has missed the SSI - MXI also
Unread postby uunix » Fri Mar 20, 2015 1:16 pm
Yup, Kit of 2
KSG oct/256
2078 001.A00
kit of 2 CE
