Octane R10K 250MHz 1152MB EMXI+SI+MCO 2x 9GB
ajw99uk
Unread postby ajw99uk » Tue Mar 10, 2015 6:18 pm
This is the Octane that uunix spotted on Ebay but could not collect, so I picked it up. Since then he seems to have found others to distract him ... so here's the hinv. I had been pessimistic as the model number suggested only a 175MHz machine, but it turned out to have been used within SGI until around 2006 and had been upgraded.
UPDATE 23 November 2016: I have passed this machine on to jebmayers, who will get far better use from it than I did (it has sat under a desk for most of the nearlt two years since I acquired it).
Part:030-1286-002;Name:PM20250MHZ;Serial:GTJ939;Revision:B;Group:ff;Capability:ffffffff;Variety:ff;Laser:000000246615;
Part:030-1467-001;Name:IP30;Serial:MEW365;Revision:D;Group:ff;Capability:ffffffff;Variety:ff;Laser:00000059d294;
Part:060-0038-001;Name:PWR.SPPLY.S2;Serial:AAC8150074;Revision:C;Group:ff;Capability:ffffffff;Variety:ff;Laser:00000021fe8d;
Part:030-0891-003;Name:FP1;Serial:98829B;Revision:F;Group:ff;Capability:ffffffff;Variety:ff;Laser:0000001a23bd;
Part:030-1240-003;Name:MOT20;Serial:KXX073;Revision:H;Group:ff;Capability:ffffffff;Variety:ff;Laser:00000049c163;
Part:030-1196-002;Name:MCO;Serial:GBG509;Revision:C;Group:ff;Capability:ffffffff;Variety:ff;Laser:0000001a301f;
Part:030-0938-003;Name:GM10;Serial:ENJ563;Revision:T;Group:ff;Capability:ffffffff;Variety:ff;Laser:000000183180;
1 250 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 1152 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: EMXI
Graphics board: SI
OCTANE Channel Option Board
   VC3 rev A, CMAP rev F, Heart rev F
   OCO board present (rev 2)
   Managed (":0.1") 1280x1024
   VC3 rev A, CMAP rev E, Heart rev F
Bit of a mixture - Xbow 1.4 and a newer m/b but Lucent PSU. The SCSI drives are two IBM 9GB units, now one a clone of the other with 128MB swap (the fx default) and the rest as a root partition. I think there should be TRAM showing for the SE board, it's there but maybe u/s - like the second processor, which PROM hinv reports but is disabled in IRIX. I have tried removing the PM to reseat it, but one stand-off seems stuck; the bolt can be loosened but the PM won't lift at that point (halfway along the side nearest the edge of the m/b). Dual-screen is nice; the "assumed 19" monitors" are a 17" CRT and a 22" LCD-TV! Pretty sure it had a CADduo card in a PCI cage at SGI but xinerama is doing the trick with a single keybd+mouse input. It does seem to "stall" at intervals, so perhaps some SGI-office-network config that needs to be cleaned out? Most services chkconfig'd off. Skins in good condition, as is one drive sled (the seller broke the other while pulling it out to show me the drive :( ).
Re: Octane R10K 250MHz 1152MB EMXI+SI+MCO 2x 9GB
Unread postby foetz » Tue Mar 10, 2015 6:55 pm
how do you know it was an sgi internal machine?
Unread postby ClassicHasClass » Tue Mar 10, 2015 11:21 pm
The glamour shots of Jim Clark on the desktop.
(Eww.)
ajw99uk
Unread postby ajw99uk » Wed Mar 11, 2015 1:24 pm
foetz wrote:how do you know it was an sgi internal machine?
The seller told me he'd got the machine from a friend who had worked at SGI Reading, corroborated by some desktop-[host] config files left over from when it was on the SGI network. I suppose they could be spoofs, but why bother? No signs of any IRIX source code.
Unread postby uunix » Wed Mar 11, 2015 1:40 pm
And all for 1 Pence... brilliant.
Unread postby foetz » Wed Mar 11, 2015 1:52 pm
ClassicHasClass wrote:The glamour shots of Jim Clark on the desktop.
:lol:
ajw99uk wrote:The seller told me he'd got the machine from a friend who had worked at SGI Reading, corroborated by some desktop-[host] config files left over from when it was on the SGI network. I suppose they could be spoofs, but why bother? No signs of any IRIX source code.
still a nice extra :-)
Unread postby ClassicHasClass » Wed Mar 11, 2015 6:22 pm
GREEN FOETZ
FEAR!!!!!
Unread postby foetz » Wed Mar 11, 2015 7:06 pm
ClassicHasClass wrote:GREEN FOETZ
FEAR!!!!!
:twisted:
Jack Luminous
Unread postby Jack Luminous » Thu Mar 12, 2015 1:43 am
FEAR!!!!!
LOL
Unread postby Trippynet » Thu Mar 12, 2015 2:56 am
FEAR!!!!!
And on 5555 posts as well...
Users browsing this forum: Baidu [Spider] and 1 guest
