Fuel 900MHz V10 1GB MAD DM10
hoosyny
Unread postby hoosyny » Sun Feb 08, 2015 9:25 am
Here is my Fuel.
The M-Audio Revolution 7.1 and DM10 cards are my additions.
The DM10 is a 3 port Firewire card manufactured by ATEN.
IRIS 1# hinv -vm
            IP34 Board: barcode MVV384     part 030-1707-003 rev -P
        IP34PIMM Board: barcode NSR779     part 030-2023-001 rev -B
       ASTODYV10 Board: barcode NZM617     part 030-1826-003 rev -B
1 900 MHZ IP35 Processor
CPU 0 at Module 001c01/Slot 0/Slice A: 900 Mhz MIPS R16000 Processor Chip (enabl
ed)
  Processor revision: 3.0. Scache: Size 8 MB Speed 450 Mhz  Tap 0xb
Main memory size: 1024 Mbytes
Memory at Module 001c01/Slot 0: 1024 MB (enabled)
Integral SCSI controller 2: Version IEEE1394 SBP2
Graphics board: V10
Iris Audio Processor: version MAD revision 1, number 2
  PCI Adapter ID (vendor 0x104c, device 0x8024) PCI slot 1
USB controller: type OHCI
IRIS 2# uname -R
6.5 6.5.30f
Re: Fuel 900MHz V10 1GB MAD DM10
Unread postby ClassicHasClass » Sun Feb 08, 2015 10:29 am
Specific model of the Aten card? I don't think that's on the Fuel HW aggregator.
Nice system! But you need more RAM! And a V12! And a DCD! You should give the 900MHz card to me! ;)
Unread postby Trippynet » Sun Feb 08, 2015 1:23 pm
You wasted no time! "Hello everyone. Oh, and eat my 900MHz Fuel".
Nice system by the way, but Classic is right that another GB or so of RAM and a V12 would be the cherry on the top :)
smj
Unread postby smj » Sun Feb 08, 2015 5:28 pm
A 900MHz PIMM? Outstanding! More RAM is always nice, but 1GB actually goes a long way under IRIX unless you're doing Serious Work.
Unfortunately finding a V12 may be time consuming and/or expensive.
Unread postby ClassicHasClass » Sun Feb 08, 2015 6:27 pm
But ... but ... isn't everyone here using their SGIs for Serious Businesseses?
Unread postby hamei » Sun Feb 08, 2015 7:13 pm
ClassicHasClass wrote:But ... but ... isn't everyone here using their SGIs for Serious Businesseses?
We're anything but Serious but I pulled half the memory out and still ...
Even running several "memory-hog" apps at once, I've never been able to use more than maybe 2 gigs. It will fill up with filesystem cache but heck, that's no biggy.
I've come to the conclusion that Yewnix really doesn't handle memory all that well. And fireflop, well, let's not even go there.
I'm sure there are some cases where more memory is a help but in general, the Big Memory thing seems to be kind of a fetish.
I'm definitely jealous of that cpu card tho. That's about the best Fuel you'll ever see :D
Unread postby vishnu » Mon Feb 09, 2015 12:44 am
True dat, hoosyny's cpu card is da schnizle but hamei if you want to firehose your Fool's RAM you need to load some of the Pro/E models we have at my place of employ... :twisted:
Unread postby Trippynet » Mon Feb 09, 2015 5:24 am
Does "idle pratting around and general experimenting" count? :)
Unread postby ClassicHasClass » Mon Feb 09, 2015 6:47 am
Sure sounds serious to me!
Unread postby vishnu » Mon Feb 09, 2015 2:32 pm
I use my SGI to build new IRIX kernels, doesn't everybody? 8-)
Unread postby uunix » Mon Feb 09, 2015 2:42 pm
I use my Octane 2 to attract women! And the o2 with 1600ws to attract the sister..
hoosyny
Unread postby hoosyny » Mon Feb 09, 2015 3:01 pm
I have studied this forum for knowing what to look for, but it was not cheap.
Actually I was just one second late and missed something that looked to be a quad 1GHz Tezro, fully equipped, V12, DCD, DM3, RAD, original OS, property of Autodesk stickers, for 700 USD + 200 USD shipping. Then I was so sad and bought the Fuel for the same price 700 + 200.
To justify the money and not cry for the Tezro, I am saying to myself that Fuel is much nicer than Tezro.
But I should not complain about costs because I plan an important business with it, like enjoying music and anime episodes.
I have not checked if the Firewire card works for something. I think that I have to install some drivers for it.
Unread postby Trippynet » Tue Feb 10, 2015 3:41 am
The Fuel is still a very nice system and does have some advantages over the Tezro (mainly noise, space and power-usage). If you don't need multi-processing capability and can live with the fact that the case isn't as funky, it can be just as good if equipped with a few extras like a soundcard, gigabit ethernet card, etc.
Although saying that, from the two SGIs in my signature, I'd say my Indigo2 does get more use than my Fuel funnily enough.
Unread postby ClassicHasClass » Tue Feb 10, 2015 7:01 am
The Texas Instruments TSB43AB23 is a compatible FireWire controller, so the card should "just work." You'll need the DM10 development libraries, see the Aggregator for more: viewtopic.php?f=3&t=9046
If you get this card working, we can add it to the list.
I like the Tez on paper, but the Fuel is a lot easier to live with. I already have one hot, loud computer. :)
Unread postby vishnu » Tue Feb 10, 2015 10:43 pm
Every time I turn my Tez on, the fans in the back sound like they're trying to launch the thing right off the desk, "Houston we have a problem, the Tezro's trying to go all Kitty Hawk on my ass..." :lol:
