chicaneuk's old o2
chicaneuk's old o2
Unread postby uunix » Wed Jan 28, 2015 1:33 pm
Xo2 3# hinv -v
1 300 MHZ IP32 Processor
Main memory size: 448 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
  PCI Adapter ID (vendor 0x10cd, device 0x1300) PCI slot 3
Video: MVP unit 0 version 1.4
AV: AV2 Card version 0, Camera not connected.
Vice: TRE
1600SW Flat Panel adapter board and display.
Xo2 4# /usr/gfx/gfxinfo
        Managed (":0.0") 1600x1024
        32 + 32 bitplanes
        Timing table flags:
         Monitor 0 type: Unknown
         Video Output: 1600 pixels, 1024 lines, 50.00Hz (1600x1024_50p)
Added bit more memory, 1600sw adapter & tonight an A/V2 board. (will be seeing what that can do later, first I have new PSU's for my OCTANES.
chicaneuk
Re: chicaneuk's old o2
Unread postby chicaneuk » Thu Feb 05, 2015 1:53 am
Nice :) Hope it's running well. See you bumped the RAM a smidgin as well.
Unread postby uunix » Thu Feb 05, 2015 6:31 am
It is indeed, currently playing with the new A/V2 card, but she hasn't missed a beat.
gocram
Unread postby gocram » Thu Feb 05, 2015 1:24 pm
Very nice O2, similar to one of mine. By the way, does it have a hypercube or ‘new logo’ shell? Did you also already try patching an output into your VBOB? (I thought of your other thread just now.)
LOOKING FOR:
ITEMS FOR SALE/TRADE
Unread postby uunix » Thu Feb 05, 2015 1:39 pm
It's the new logo, and yes I did (Live Output), it produces on the VBOB Console nothing @ any setting.. PAL 625, Pal 625 Square, NTSC etc, input though from the VBOB does produce the test signal (well it did until now, but then again, I'm cloning a disk on the controlling Octane, so it may not be initialized etc).
I know though it does output, as some strange combination last week or so produced a mini version of the o2's desktop.
