Indy, R4400 175MHz, 96MB, 24bit Graphics
chicaneuk
Unread postby chicaneuk » Tue Jan 20, 2015 12:22 pm
It's seemed a little quiet on the hinv section for a while, so it seemed a good excuse to put up the details of my Indy. Another scrapper from work, this was absolutely barebones with a 100MHz CPU, 32MB RAM, 8 bit graphics and some extremely loud old drives measured in MB not GB :) It's duly received several upgrades to make it a bit more usable, and I also put in a 15K 146GB SCSI drive.
hinv output:
IRIS 1# hinv -v
CPU: MIPS R4400 Processor Chip Revision: 6.0
1 175 MHZ IP22 Processor
Main memory size: 96Mbytes
On-board serial ports: 2
Graphics board: Indy 24-bit
Iris Audio Processor: version A2 revision 4.1.0
Vino video: unit 0, revision 0, IndyCam not connected
gfxinfo output:
IRIS 2# /usr/gfx/gfxinfo
Graphics board 0 is “NG1” graphics.
         Managed (“:0.0”) 1024x768
         24 bitplanes, NG1 revision 6, REX3 revision B, VC2 revision A
         MC revision C, xmap9 revision A, cmap revision D, bt445 revision D
         Display 1024x768 @ 60Hz, monitor id 15
Couple of bad pictures..
Cheers.
Re: Indy, R4400 175MHz, 96MB, 24bit Graphics
Unread postby ClassicHasClass » Tue Jan 20, 2015 12:53 pm
Nice specs!
Unread postby uunix » Tue Jan 20, 2015 1:12 pm
You gotta love Indy..
Mines doing work tonight also.
Unread postby uunix » Tue Jan 20, 2015 1:41 pm
chicaneuk is that monitor SOG-OK or do you have a conversion device?
chicaneuk
Unread postby chicaneuk » Tue Jan 20, 2015 1:54 pm
The monitor does indeed seem to be SOG and is connected up by a DIY cable a friend of mine made up for me :) The problem with the monitor is that the native res isn't supported on any of my kit (1680x1050).
Unread postby jan-jaap » Tue Jan 20, 2015 2:10 pm
chicaneuk wrote:Another scrapper from work, this was absolutely barebones with a 100MHz CPU, 32MB RAM, 8 bit graphics and some extremely loud old drives measured in MB not GB :)
Yup, had one exactly like that in my first real job ... did real work with it too.
chicaneuk
Unread postby chicaneuk » Tue Jan 20, 2015 2:13 pm
I guess in it's defence, IRIX was a bit less bloated back then so probably booted and ran a bit quicker!
Unread postby jan-jaap » Tue Jan 20, 2015 2:48 pm
chicaneuk wrote:I guess in it's defence, IRIX was a bit less bloated back then so probably booted and ran a bit quicker!
True, but it came with IRIX 5.1.x which leaked memory like nothing else so it had to be rebooted every couple of days. :(
With IRIX 5.3 it was perfectly usable, especially after we upgraded the memory with an extra 64MB. Of course, 'usable' was compared to a contemporary PC, usually a 486DX/2 running Windows 95 or OS/2 Warp.
Unread postby foetz » Tue Jan 20, 2015 6:57 pm
uunix wrote:You gotta love Indy..
oh you're running cde. that's quite a rare sight
Unread postby josehill » Tue Jan 20, 2015 8:31 pm
foetz wrote:oh you're running cde. that's quite a rare sight
I'd boot mine up in CDE every now and then, just from curiosity. As far as CDE experiences go, the SGI version was quite nice and snappy. I can't quite put my finger on any objective reason why this was the case, but CDE somehow felt smoother on an SGI machine than on Sun or AIX machines of similar vintage and power. It's easy to setup CDE and then switch back to the Irix Interactive Desktop when finished (just a matter of installing the CDE eoe and then setting/unsetting some chkconfig flags), so if you are at all curious, I suggest giving it a try.
Unread postby foetz » Tue Jan 20, 2015 8:44 pm
oh i did run cde on irix myself a couple of times. it's just not something you see often
Unread postby josehill » Tue Jan 20, 2015 9:14 pm
foetz wrote:oh i did run cde on irix myself a couple of times. it's just not something you see often
That's for sure. Whenever I ran it, people would walk by and assume I was running a remote display. "Hey! How did you get those cool fonts in AIX?" :D
Unread postby ClassicHasClass » Tue Jan 20, 2015 10:51 pm
LOL! My only CDE systems right now are, indeed, my AIX boxes and my C8000. :)
Unread postby uunix » Wed Jan 21, 2015 1:21 am
The desktop you see is from a Power6 AIX CDE, I was telneted into the Indy.
Unread postby josehill » Wed Jan 21, 2015 6:59 am
uunix wrote:The desktop you see is from a Power6 AIX CDE, I was telneted into the Indy.
...which makes the last few remarks by foetz and me even funnier. Well, at least to me. :D
