Indigo2 R4400 250Mhz HighImpact + TRAM
jodys
Unread postby jodys » Fri Nov 21, 2014 7:36 am
# hinv -vm
CPU: MIPS R4400 Processor Chip Revision: 6.0
1 250 MHZ IP22 Processor
Main memory size: 128 Mbytes
Secondary unified instruction/data cache size: 2 Mbytes on Processor 0
Data cache size: 16 Kbytes
On-board serial ports: 2
Graphics board: High Impact/TRAM option card
EISA bus: adapter 0
# /usr/gfx/gfxinfo -vv
Graphics board 0 is "IMPACT" graphics.
        Product ID 0x0, 1 GE, 1 RE, 4 TRAMs
        VC3 rev A, CMAP rev EMC rev C
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  unknown
# uname -aR
IRIX GreenMachine 6.5 6.5.3m 01221552 IP22
And the original OEM 4GB drive.
# scsicontrol -i /dev/scsi/sc0d1l0
/dev/scsi/sc0d1l0:  Disk          SGI     QUANTUM XP34550SLXY4
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds cmdqueing
Device is  ready
It is not that I needed another SGI, but this machine had been on craigslist for a couple of weeks. Despairing for its fate, I bought it. I'm glad I did. It is very clean and well cared for--the owner had bought it brand new in 1996--and it came with with all the original boxes and accesories. Not the highest spec Indigo2, but enough for me. After saving the original OEM drive with its install of 6.5.3, I think I may just install 6.2, since it came with a license for a MipsPro that will will run on 6.2. It came with a delightfully large box of CDs, including the groovy "Adventures of Ratmandu and Whitewolf" binder filled with Developer Toolbox CD's.
Right before I left with the machine, I pulled out some crisp $20's to pay for the machine.
He gave me a sour look and said "That's not enough, it'll be about $40,000" and then we both smiled. Ahh, depreciation...
:Octane2: :Indy: :O2: :O2: :O3x0: :Indigo2IMP:
Re: Indigo2 R4400 250Mhz HighImpact + TRAM
Unread postby jan-jaap » Fri Nov 21, 2014 7:53 am
Nice one!
I've got one of these DeveloperToolbox binders too, the theme is the adventures of two magical Indian characters I think?
FWIW: MIPSpro licenses are not versioned, they will work up to the last version. You need the installation media, but the license will won't be the problem.
jpstewart
Unread postby jpstewart » Fri Nov 21, 2014 7:58 am
Very nice! I've always had a soft spot for the Indigo2 Impact machines and yours appears to be in nearly perfect cosmetic condition. That's amazing.
Getting all the accessories and CDs with it is a very nice bonus, too. Have fun with it!
HP C8000
Digital DECstation 5000/125
Unread postby ClassicHasClass » Fri Nov 21, 2014 10:15 am
Never seen an SGI unboxing. Nice find.
Unread postby vishnu » Fri Nov 21, 2014 12:31 pm
Wow! :shock:
That thing might be the most mint Indigo2 in existence, anywhere. :mrgreen:
Did the original owner say how much he paid for it? I think they were going for around ten kilobucks in 1996... :o
jodys
Unread postby jodys » Fri Nov 21, 2014 1:47 pm
The pictures do belie certain cosmetic imperfections and dust. However, it is great condition. The PO said he was in about $40,000 with software, too.
Thanks for the info re MIPSpro licenses. I have another machine licensed with 6.5 and 7.4, so I thought it might be nice to have a 6.2 machine.
Unread postby foetz » Fri Nov 21, 2014 1:49 pm
oh yeah, indigo2 with an r4400/250 is neat. it's one of the most compatible systems. if you switch the impact with a pre-mgras card you can run everything from irix4 up to 6.5.22.
and yes, running 6.5.x on this makes little sense since any older version will be a boost in comparison. with 5.3 this one will fly and you can even run coff :D
jodys
Unread postby jodys » Fri Nov 21, 2014 1:58 pm
foetz wrote:oh yeah, indigo2 with an r4400/250 is neat. it's one of the most compatible systems. if you switch the impact with a pre-mgras card you can run everything from irix4 up to 6.5.22.
Since I'd like to do some development on this machine, what is the last version of the SGI compilers to run on 5.3? I've got quite a few discs to look through. I assume that 5.3 is not compatible with Impact, right?
Unread postby foetz » Fri Nov 21, 2014 3:10 pm
jodys wrote:Since I'd like to do some development on this machine, what is the last version of the SGI compilers to run on 5.3? I've got quite a few discs to look through. I assume that 5.3 is not compatible with Impact, right?
it is. there's a special version of 5.3 that supports impact. the only rub is that it doesn't support xfs but that might not be a problem. however in case of the r4400/250 you'd need an older cpu to install it because that one only works after installing a few patches. funny enough the indigo2 version of irix4 does work due to seemingly less thorough checks :P
as for the compilers, 5.3 had the mips compilers i.e. not mipspro yet. namely mips c 3.19, c++ 4 and fortran77. the c++ is pre c++98 meaning there's no stl and other things common today. the f77 is pretty good because it supports a lot of extras beyond what's defined by fortran77.
bottom line if you're not much interested in c++ or write your own stuff so that it works there 5.3 makes for a nice dev platform. and for the odd case there's still gcc.
EDIT: the proper names are as follows
I  ftn_dev              1021572033  Fortran 77, 4.0.2
I  c++_dev              1021572035  C++, 4.0
I  c_dev                1021572033  C, 3.19
gocram
Unread postby gocram » Wed Dec 10, 2014 2:04 am
Amazing pictures, thanks for sharing!
For some reason, although mine didn't come in a box (but with little usage, from what the previous owner told me), my Indigo² — also a purple, albeit IP28 (i.e. IMPACT/10000) — is in an equally good condition and has the same (or equally) shiny untarnished metal, judging by the picture from the back.
LOOKING FOR:
ITEMS FOR SALE/TRADE
