O350 8x800Mhz, 8Gb, IR4
sgi-enthusiast
Unread postby sgi-enthusiast » Sat Oct 25, 2014 2:24 am
Hi,
Here are the details of the Onyx350 rack (1 of 4) that I recently acquired and now have operational with the assistance of smj and recondas. The first two systems are up and going so the description refers to the configuration of each.
hinv -vm
hinv -vm
       IP53_4CPU Board: barcode NCT116     part 030-1959-002 rev -B
          KTOWN2 Board: barcode MTL024     part 030-1593-001 rev  H
          GE16-4 Board: barcode MTT693     part 030-1800-001 rev  J
       2U_INT_53 Board: barcode NJW661     part 030-1809-005 rev -A
Location: /hw/module/001c22/IXbrick/xtalk/15/pci-x/0/1/ioc4
             IO9 Board: barcode NJL433     part 030-1771-005 rev -A
       IP53_4CPU Board: barcode NRG667     part 030-1959-003 rev -C
       XT-DIGVID Board: barcode NJG870     part 030-1928-004 rev  A
       2U_INT_53 Board: barcode NNX302     part 030-1809-006 rev -B
8 800 MHZ IP35 Processors
CPU 0 at Module 001c22/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
  Processor revision: 2.2. Scache: Size 8 MB Speed 400 Mhz  Tap 0xa
CPU 1 at Module 001c22/Slot 0/Slice B: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c22/Slot 0/Slice C: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c22/Slot 0/Slice D: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 4 at Module 001c24/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 5 at Module 001c24/Slot 0/Slice B: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 6 at Module 001c24/Slot 0/Slice C: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 7 at Module 001c24/Slot 0/Slice D: 800 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 8192 Mbytes
Memory at Module 001c22/Slot 0: 4096 MB (enabled)
  Bank 7 contains 512 MB (Standard) DIMMS (enabled)
Memory at Module 001c24/Slot 0: 4096 MB (enabled)
Integral SCSI controller 5: Version QL1240, differential
Integral SCSI controller 6: Version QL1240, differential
Integral SCSI controller 7: Version Fibre Channel QL2342 Port 1, 100 MHz PCI-X
Integral SCSI controller 3: Version Fibre Channel QL2342 Port 1, 100 MHz PCI-X
  Disk drive: unit 48 on SCSI controller 3 (unit 48)
  Disk drive: unit 50 on SCSI controller 3 (unit 50)
  Disk drive: unit 52 on SCSI controller 3 (unit 52)
  Disk drive: unit 54 on SCSI controller 3 (unit 54)
  Disk drive: unit 56 on SCSI controller 3 (unit 56)
  Disk drive: unit 58 on SCSI controller 3 (unit 58)
  Disk drive: unit 60 on SCSI controller 3 (unit 60)
  Disk drive: unit 62 on SCSI controller 3 (unit 62)
Integral SCSI controller 4: Version Fibre Channel QL2342 Port 2, 100 MHz PCI-X
  Disk drive: unit 49 on SCSI controller 4 (unit 49)
  Disk drive: unit 51 on SCSI controller 4 (unit 51)
  Disk drive: unit 53 on SCSI controller 4 (unit 53)
  Disk drive: unit 55 on SCSI controller 4 (unit 55)
  Disk drive: unit 57 on SCSI controller 4 (unit 57)
  Disk drive: unit 59 on SCSI controller 4 (unit 59)
  Disk drive: unit 61 on SCSI controller 4 (unit 61)
Integral SCSI controller 8: Version Fibre Channel QL2342 Port 2, 100 MHz PCI-X
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: InfiniteReality4
Gigabit Ethernet: tg1, module 001c22, PCI bus 1 slot 2 port 0
Gigabit Ethernet: tg2, module 001c22, PCI bus 1 slot 2 port 1
Integral Gigabit Ethernet: tg0, module 001c22, PCI bus 1 slot 4
Iris Audio Processor: version RAD revision 13.0, number 1
  PCI Adapter ID (vendor 0x1077, device 0x1240) PCI slot 1
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 2
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 2
  PCI Adapter ID (vendor 0x14e4, device 0x1648) PCI slot 2
IOC4 firmware revision 83
HUB in Module 001c22/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
HUB in Module 001c24/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c22/Slot n0: Revision 6.210
IP35prom in Module 001c24/Slot n0: Revision 6.210
gfxinfo
IRIS 2# /usr/gfx/gfxinfo -vv
Graphics board 0 is "KONAD" graphics.
        Managed (":0.0") 1920x1200
        Display has 2 channels
        4 GEs (of 4), occmask = 0x0f
        2 RM11 boards (of 2) 1/1/0/0
        Texture Memory: 1024MB/1024MB/-/-
        Extra-Large pixel depth
        32K cmap
        TVO option detected
        brd: 80f61808 3061c04/3061c04/-/- f9191002
        rm0: 05032057 35431057
              4631057 3/3/3/3
              4d31057 3/3/3/3/3/3/3/3
              4938057 5/5/5/5/5/5/5/5/5/5
        rm1: 05032057 35431057
              4631057 3/3/3/3
         dg: 05532057
              5838057 1/1/1/1
              5631057 1/1
        GE:   NIC #:      0000.006c.5ca5 (family: 0b)
              Serial #:   MTT693
              Part #:     030-1800-001
              rev_code:   J
              grp_code:   0xff
              capability: "\ff\ff\ff\ff"
              variety:    0xff
        KT:   NIC #:      0000.006c.6212 (family: 0b)
              Serial #:   MTL024
              Part #:     030-1593-001
              rev_code:   H
              grp_code:   0x11
              variety:    0xff
        RM0:  NIC #:      0000.0098.6e4b (family: 0b)
              Serial #:   NNW481
              Part #:     030-1651-005
              rev_code:   D
              grp_code:   0x11
              variety:    0xff
        TM0:  NIC #:      0000.0098.01d3 (family: 0b)
              Serial #:   NKY687
              Part #:     030-1650-005
              rev_code:   B
              grp_code:   0x11
              variety:    0xff
        RM1:  NIC #:      0000.0098.8f59 (family: 0b)
              Serial #:   NKZ648
              Part #:     030-1651-004
              rev_code:   C
              grp_code:   0x11
              variety:    0xff
        TM1:  NIC #:      0000.0080.af7d (family: 0b)
              Serial #:   NJC351
              Part #:     030-1650-004
              rev_code:   D
              grp_code:   0x11
              variety:    0xff
        RM2:  No NIC serial number available.
        TM2:  No NIC serial number available.
        RM3:  No NIC serial number available.
        TM3:  No NIC serial number available.
        BP:   No NIC serial number available.
        DG:   NIC #:      0000.0052.d23d (family: 0b)
              Serial #:   MFJ850
              Part #:     030-1242-001
              rev_code:   G
              grp_code:   0xff
              variety:    0xff
        DGOPT:NIC #:      0000.0051.f7d8 (family: 0b)
              Serial #:   MFP208
              Part #:     030-1511-004
              rev_code:   A
              grp_code:   0xff
              variety:    0xff
         Channel's Source Size: 1920 pixels, 1200 lines; Origin = (0,0)
         Video Output: 0 pixels, 0 lines, 0.00Hz ()
         Video Format Flags:  (none)
         Sync Output(s):
          Composite sync on Green
          Composite TTL sync on Aux 0
         Using Gamma Map 0
         Monitor Type:  Unknown
         Pedestal Enabled
         Channel not blanked
         Gain (all color components) - 1.000000 (nominal)
         Horizontal Phase - 0.00 pixels; range [0.00,0.00]
         Vertical Phase - 0 lines; range [-2,2]
Thanks for looking!
Re: O350 8x800Mhz, 8Gb, IR4
Unread postby foetz » Sat Oct 25, 2014 7:27 am
congrats, that's pretty much as much irix as you can get :D
sgi-enthusiast
Unread postby sgi-enthusiast » Sat Oct 25, 2014 11:35 pm
Hi Here is the output from the L2 controller as well!
M2006023-001-L2>ver
L2 version: 1.32.4
M2006023-001-L2>
M2006023-001-L2>serial all
001g04:
Local System Serial Number      NVRAM         M2006023
Reference System Serial Number  Attached L2   M2006023
Local Brick Serial Number       EEPROM        NBR425
Reference Brick Serial Number   NVRAM         NBR425
ID          KCARL1          NBR425         030_1598_004          C    00
001c22:
Local Brick Serial Number       EEPROM        NJW661
Reference Brick Serial Number   NVRAM         NJW661
INTERFACE   2U_INT_53       NJW661         030_1809_005          A    00
IO9         IO9             NJL433         030_1771_005          A    00
ODYSSEY     no hardware detected
RISER       2U_RISER        NGZ808         030_1808_006          B    00
NODE        IP53_4CPU       NCT116         030_1959_002          B    00
PS 1        DPS-500EBE      XPD0409000860  060-0178-003          S4
PS 2        DPS-500EBE      XPD0434005077  060-0178-003          S4
DIMM 0     7F7FFE000000000012003DC3 CM2202B1            2     8.0  N/A
DIMM 2     7F7FFE000000000012003DC4 CM2202B1            2     8.0  N/A
DIMM 4     7F94FFFFFFFFFFFFFE4D101D SM57264DSGI100C2   00FF   8.0  N/A
DIMM 6     7F94FFFFFFFFFFFF7E4D101D SM57264DSGI100C2   00FF   8.0  N/A
DIMM 1     7F7FFE000000000012003DC0 CM2202B1            2     8.0  N/A
DIMM 3     7F7FFE000000000012003DBE CM2202B1            2     8.0  N/A
DIMM 5     7F94FFFFFFFFFFFF807E880D SM57264DSGI100C2   00FF   8.0  N/A
DIMM 7     7F94FFFFFFFFFFFFBE4D101D SM57264DSGI100C2   00FF   8.0  N/A
001c24:
Local Brick Serial Number       EEPROM        NNX302
Reference Brick Serial Number   NVRAM         NNX302
INTERFACE   2U_INT_53       NNX302         030_1809_006          B    00
IO9         no hardware detected
RISER       2U_RISER        NND113         030_1808_006          B    00
NODE        IP53_4CPU       NRG667         030_1959_003          C    00
SNOWBALL    SNOWBALL_2U     NJG870         030_1928_004          A    00
PS 1        DPS-500EBE      XPD0323001633  060-0178-003          S1
PS 2        DPS-500EBE      XPD0451010045  060-0178-003          S4
DIMM 0     7F94FFFFFFFFFFFF207E880D SM57264DSGI100C2   00FF   8.0  N/A
DIMM 2     7F94FFFFFFFFFFFFA07E880D SM57264DSGI100C2   00FF   8.0  N/A
DIMM 4     7F7FFE000000000012003DC9 CM2202B1            2     8.0  N/A
DIMM 6     7F7FFE000000000012003DBA CM2202B1            2     8.0  N/A
DIMM 1     7F94FFFFFFFFFFFF814D101D SM57264DSGI100C2   00FF   8.0  N/A
DIMM 3     7F94FFFFFFFFFFFF014D101D SM57264DSGI100C2   00FF   8.0  N/A
DIMM 5     7F7FFE000000000012003DF4 CM2202B1            2     8.0  N/A
DIMM 7     7F7FFE000000000012003DCA CM2202B1            2     8.0  N/A
M2006023-001-L2>
M2006023-001-L2>env
001g04:
        5V AUX   Wait Pwr  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      3.3V AUX   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    3.302
FAN  0   BLOWER   Wait Pwr         1080            0
 0 L1               Wait Pwr   32C/ 89F   37C/ 98F   42C/107F   28C/ 82F
001c22:
          1.8V   Wait Pwr  10%   1.62/  1.98  20%   1.44/  2.16    0.014
           12V   Wait Pwr  10%  10.80/ 13.20  20%   9.60/ 14.40    0.125
        12V #2   Wait Pwr  10%  10.80/ 13.20  20%   9.60/ 14.40    0.125
          3.3V   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    0.258
        12V IO   Wait Pwr  10%  10.80/ 13.20  20%   9.60/ 14.40    0.063
        5V AUX   Wait Pwr  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      3.3V AUX   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    3.268
    PCI 5V AUX   Wait Pwr  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      PCI 3.3V   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    0.258
      PCI 2.5V   Wait Pwr  10%   2.25/  2.75  20%   2.00/  3.00    0.013
        PCI 5V   Wait Pwr  10%   4.50/  5.50  20%   4.00/  6.00    0.000
  XIO 12V BIAS <not present>
        XIO 5V <not present>
      XIO 2.5V <not present>
  XIO 3.3V AUX <not present>
 IP53 3.3V AUX   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    3.251
   IP53 5V AUX   Wait Pwr  10%   4.50/  5.50  20%   4.00/  6.00    5.018
      IP53 12V   Wait Pwr  10%  10.80/ 13.20  20%   9.60/ 14.40    0.125
     IP53 VCPU   Wait Pwr  10%   1.13/  1.38  20%   1.00/  1.50    0.000
     IP53 SRAM   Wait Pwr  10%   2.25/  2.75  20%   2.00/  3.00    0.000
     IP53 1.5V   Wait Pwr  10%   1.35/  1.65  20%   1.20/  1.80    0.000
FAN  0  EXHST 1   Wait Pwr         1980            0
FAN  1  EXHST 2   Wait Pwr         1980            0
FAN  2       PS   Wait Pwr         3200            0
FAN  3    PCI 1   Wait Pwr         1980            0
FAN  4    PCI 2   Wait Pwr         1980            0
 0 INTERFACE 0      Wait Pwr   31C/ 87F   48C/118F   55C/131F    9C/ 48F
 1 INTERFACE 1      Wait Pwr   31C/ 87F   48C/118F   55C/131F   10C/ 50F
 2 INTERFACE 2      Wait Pwr   31C/ 87F   48C/118F   55C/131F   22C/ 71F
 3 PCI RISER        Wait Pwr   31C/ 87F   48C/118F   55C/131F   18C/ 64F
 4 ODYSSEY        <not present>
 5 NODE             Wait Pwr   31C/ 87F   48C/118F   55C/131F   20C/ 68F
 6 BEDROCK          Wait Pwr  Not currently available
001c24:
          3.3V   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    0.000
        12V IO   Wait Pwr  10%  10.80/ 13.20  20%   9.60/ 14.40    0.125
      3.3V AUX   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    3.285
      PCI 3.3V   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    0.000
      PCI 2.5V   Wait Pwr  10%   2.25/  2.75  20%   2.00/  3.00    0.000
 IP53 3.3V AUX   Wait Pwr  10%   2.97/  3.63  20%   2.64/  3.96    3.268
   IP53 5V AUX   Wait Pwr  10%   4.50/  5.50  20%   4.00/  6.00    5.070
FAN  1       PS   Wait Pwr         3200            0
FAN  2    PCI 1   Wait Pwr         1980            0
FAN  3    PCI 2   Wait Pwr         1980            0
FAN  4      ODY   Wait Pwr         1679            0
 0 INTERFACE 0      Wait Pwr    [Autofan Control]    75C/167F   34C/ 93F
 1 INTERFACE 1      Wait Pwr    [Autofan Control]    75C/167F   34C/ 93F
 2 INTERFACE 2      Wait Pwr    [Autofan Control]    75C/167F   37C/ 98F
 3 PCI RISER        Wait Pwr    [Autofan Control]    75C/167F   30C/ 86F
 5 NODE             Wait Pwr    [Autofan Control]    75C/167F   36C/ 96F
                     Zone Temp     Target    Current   Zone Fan   Curr/Min
Zone Name  State     Sensors       Average   Average   Index      Fan %
EXHST      Wait Pwr     0,1,2,5,6  47C/116F  35C/ 95F          0   18%/ 18%
PS         Wait Pwr     0,1,2,5,6  47C/116F  35C/ 95F          1   55%/ 55%
PCI        Wait Pwr             3  45C/113F  30C/ 86F        2,3   55%/ 55%
SNO        Wait Pwr             4  35C/ 95F   0C/ 32F          4   55%/ 55%
Cheers
Unread postby recondas » Sun Oct 26, 2014 11:24 am
Very nice! With IR4 graphics/2GB of texture memory and eight 800MHz IP35 processors in a single rack it would easily qualify as my idea of the ultimate Silicon Graphics system for residential use.
If you have the OEM cables that from from the "TMDS Video Output" ports on the DG5/TVO (in the G-Brick) to the matching ports on the VBoB, and those cables happen to be labeled with an SGI part number, could you post those part numbers?
Unread postby vishnu » Sun Oct 26, 2014 12:48 pm
Can't have been fun shipping that bad daddy to Tasmania... :shock:
sgi-enthusiast
Unread postby sgi-enthusiast » Sun Oct 26, 2014 8:28 pm
The freight cost was considerably more than the purchase price not to mention that I had shipping crates on skids made especially for the racks. As I am sure you have all experienced the careful carrying capabilities of your local freight company who's motto may not live up to the condition your new acquisition arrives in (as the doors have those blue clip-on plastic panels, I could just imagine them smashed to pieces if the rack wasn't wrapped in bubble wrap and crated)!
sgi-enthusiast
Unread postby sgi-enthusiast » Mon Oct 27, 2014 1:57 am
Hi recondas
I thought about taking the other 2 RM11 boards out of the spare gbrick and either installing them in pipe '0' to make 4 or consolidating all the boards from the spare gbrick to make a pipe '1'. Not sure what the value of this would be considering there is only me to use it!
Agreed lots of horsepower but I don't actually have an application for the system so on that point, as a fellow IR system user, what do you actually use yours for? Do you have a particular application(s) you use that require the graphics system?
I have a quad 700 Tezro with 8Gb I generally toy with as its compact compared to the O350 rack (and a lot quieter) but if I hadn't bought these racks they would be at either the local metal recycler or the tip!
Here are the part numbers of the cables. Note that I checked both sets on the two racks I have here as well as the set from the Tezro and all three sets have the same part number detail on the label as follows;
'White' Cable: 018-0985-001 Rev B 03.42 UFI Code: 2134
'Black' Cable: 018-0946-001 Rev B 04.03 UFI Code: 2134
Unread postby jan-jaap » Mon Oct 27, 2014 2:15 am
recondas wrote:Very nice! With IR4 graphics/2GB of texture memory and eight 800MHz IP35 processors in a single rack it [...]
There's two GB installed (1GB per RM11), but in an IR system this does not result in 2GB of usable texture memory.
Framebuffer memory adds up, and the resulting bigger total amount means more features, or higher bit depth at a given resolution. An RM11 has 2.5GB of frame buffer memory (up from 80MB in RM10), but IIRC the 300MB/s fill rate limit still applies so I'm not sure what's the purpose of this -- not higher display resolutions I think.
Texture memory does not add up, it is used in parallel. So with multiple RMs you get higher fill rates.
Still pretty awesome. Congratulations on an impressive score!
recondas wrote:[...]would easily qualify as my idea of the ultimate Silicon Graphics system for residential use.
only if you own a pair of noise canceling headphones. :mrgreen:
recondas wrote:If you have the OEM cables that from from the "TMDS Video Output" ports on the DG5/TVO (in the G-Brick) to the matching ports on the VBoB, and those cables happen to be labeled with an SGI part number, could you post those part numbers?
As a side note: I've used generic high quality dual link DVI cables to wire my Onyx2 TVO option to a DMedia breakout w./ DM5 in the past. I'm pretty sure the DM5 showed up in the Onyx, but can't remember if I ever attached a HD-SDI monitor to look at the output signal. These are the same cables and VBOB I use with the Tezro normally. I think you have to flash something if you move a VBOB between an IR and a VPro system.
sgi-enthusiast
Unread postby sgi-enthusiast » Mon Oct 27, 2014 5:09 am
I missed the mark with the last reply and inadvertently gave you the P/N's for the LVDS cables NOT the TMDS cables so take 2!
'White' Cable: 018-0997-001 Rev A NSIA 4503
'Black' Cable: 018-0996-001 Rev A NSIA 4803
Headshell says 'Molex'
sgi-enthusiast
Unread postby sgi-enthusiast » Mon Oct 27, 2014 5:15 am
Hi Jan-jaap,
So what do you use your system for? Sounds like you are geared up for video work?
Regards
