Fuel ~ new to me R14 600
s0ke
Unread postby s0ke » Wed Aug 20, 2014 12:54 pm
This is now GARBAGE.
Recently swapped my Octane2 for a Fuel from TeamBlackFox.
s0ke@redmenace:/usr/people/s0ke[s0ke@redmenace:~] ~ hinv -vm
            IP34 Board: barcode MZK064     part 030-1707-003 rev -M
        IP34PIMM Board: barcode MXF981     part 030-1891-001 rev -D
       ASTODYV10 Board: barcode NAS590     part 030-1826-001 rev -B
1 700 MHZ IP35 Processor
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xa
Main memory size: 2048 Mbytes
Integral SCSI controller 2: Version SAS/SATA LS1068
  Disk drive: unit 0 on SCSI controller 2 (unit 0)
  Disk drive: unit 1 on SCSI controller 2 (unit 1)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: V10
Gigabit Ethernet: eg0, module 001c01, pci_bus 1, pci_slot 2, firmware version 12.4.10
  PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 1
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 2
USB controller: type OHCI
redmenace 22# ./gfxinfo -vv
        BUZZ version B.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: ACR 515
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  ACR-515
         Gain (all color components) - 0.000000 ; range [1,10]
redmenace 1% uname -aR
IRIX64 redmenace 6.5 6.5.30f 07202013 IP35
Just upgraded thanks to mopar5150
       ASTODYV10 Board: barcode MZL917     part 030-1826-001 rev -B
New LS1068 with 120gb SSD for /usr/people
Also along with the LS1068 purchase. I picked up a 15k to use as my root drive. Compiled a new .vfo for my dell monitor as well.
[s0ke@redmenace:~] ~ gfxinfo
        Managed (":0.0") 1920x1088
        BUZZ version B.1
        PB&J version 1
        32MB memory
         Monitor 0 type: DEL -24398
         Video Output: 1920 pixels, 1080 lines, 60.00Hz (1920x1080_60)
Picked up some Noctua fans to quiet the beast. If it wasn't for the root drive spinning. I couldn't tell it was even on.
001a01-L1>env
ATTENTION: Environmental monitoring is disabled!
           12V   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
        12V IO   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.12
            5V   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.10
          3.3V   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.32
          2.5V   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    2.47
          1.5V   Disabled  10%   1.35/  1.65  20%   1.20/  1.80    1.47
        5V aux   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.10
      3.3V aux   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.27
PIMM0 12V bias   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.12
     Fuel SRAM   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    2.51
      Fuel CPU   Disabled  10%   1.13/  1.38  20%   1.00/  1.50    1.25
    PIMM0 1.5V   Disabled  10%   1.35/  1.65  20%   1.20/  1.80    1.49
PIMM0 3.3V aux   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.27
  PIMM0 5V aux   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.10
  XIO 12V bias   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
        XIO 5V   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.10
      XIO 2.5V   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    1.37
  XIO 3.3V aux   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.29
FAN 0  EXHAUST   Disabled          920         1168
FAN 1       HD   Disabled         1560         2290
FAN 2      PCI   Disabled         1120         1438
FAN 3    XIO 1   Disabled         1600            0
FAN 4    XIO 2   Disabled         1600            0
FAN 5       PS   Disabled         1600        22442
Description    State       Temp       Temp       Temp       Temp
NODE 0           Disabled  Disabled  Disabled  Disabled   35C/ 95F
NODE 1           Disabled  Disabled  Disabled  Disabled   33C/ 91F
NODE 2           Disabled  Disabled  Disabled  Disabled   28C/ 82F
PIMM             Disabled  Disabled  Disabled  Disabled   43C/109F
ODYSSEY          Disabled  Disabled  Disabled  Disabled   27C/ 80F
BEDROCK          Disabled  Disabled  Disabled  Disabled   37C/ 98F
:Fuel: REFUSE
R16K 700: 2GB: V10: Noctua Fans
Re: Fuel ~ new to me R14 600
Unread postby ClassicHasClass » Wed Aug 20, 2014 1:07 pm
Redmenace indeed!
I'm about to do all the swaps to get my 700 turned into an 800 this weekend.
s0ke
Unread postby s0ke » Wed Aug 20, 2014 1:13 pm
Very nice. I am coveting bigred. Hopefully I can obtain all the necessary parts to make mine as nice one day.
:Fuel: REFUSE
Unread postby ClassicHasClass » Wed Aug 20, 2014 1:35 pm
The 600MHz Fuel is still a very fine computer. The Fuel gets well-deserved flak for the uninspiring case, but it's the SGI I use by far the most.
s0ke
Unread postby s0ke » Wed Aug 20, 2014 1:43 pm
I already notice the speed difference, and surprisingly its also very quiet. Well quieter compared to most SGI systems.
:Fuel: REFUSE
Unread postby Raion-Fox » Wed Aug 20, 2014 2:51 pm
Quiet? That Octane2 is quieter to me and runs cooler too. Glad you got her working. I upgraded Miku here with 2GB and a V8 graphics card someone claimed was a V6 so my lucky day!
s0ke
Unread postby s0ke » Wed Aug 20, 2014 4:37 pm
Yes getting rid of the original PSU fan really helped quiet it down some.
:Fuel: REFUSE
Unread postby Trippynet » Thu Aug 21, 2014 1:06 am
That's a job on my to-do list as well. I'm always impressed by how quiet my Fuel is when I first turn it on - then how loud it is after 10 minutes have gone by!
Unread postby ClassicHasClass » Thu Aug 21, 2014 7:23 am
See, with a G5 in the same room, I never notice ...
Pontus
Unread postby Pontus » Thu Aug 21, 2014 11:21 pm
ClassicHasClass wrote:The 600MHz Fuel is still a very fine computer. The Fuel gets well-deserved flak for the uninspiring case, but it's the SGI I use by far the most.
Well, the fan duct is pretty darn cool :)
Unread postby ClassicHasClass » Fri Aug 22, 2014 9:49 am
Well, that's true. The cooling is, uh, cool. :D
Unread postby Trippynet » Fri Aug 22, 2014 12:40 pm
I'm not too bothered about the case. Sure it's rather PC like, but then the Fuel was designed to be a lower priced SGI machine in a time when SGI were losing money fast. On the plus side, it used the architecture/bus, CPUs (1GHz not withstanding) and graphics options of the Tezro, so from a performance/technical point of view it's pretty decent.
I bought one for a simple reason. I wanted to own one of the last hurrah's of the IRIX/MIPS era and didn't want a large and very noisy Tezro on my desk (as impressive as they are). Since I bought mine incidentally, Ian Mapleson has practically doubled his Fuel prices due to lack of spares, so I look upon mine as somewhat of a bargain of its time. I love my Indigo2 the most out of my SGIs, but I'm proud to own my Fuel as well :)
Unread postby ClassicHasClass » Fri Aug 22, 2014 4:05 pm
I completely concur with those reasons. I already have a hot and loud Unix workstation (quad G5) and I don't need another one! :P
s0ke
Unread postby s0ke » Fri Aug 22, 2014 9:18 pm
I do miss my Indigo2. It will always hold a special place in my heart.
:Fuel: REFUSE
Unread postby Raion-Fox » Fri Aug 22, 2014 10:14 pm
s0ke wrote:I do miss my Indigo2. It will always hold a special place in my heart.
What are you guys talking about? The Indigo2 I have for sale is not loud at all, except for the HDD on boot. Other than that it is with Alice and Shanghai in terms of noise ( their names are Touhou references )
