O2, 300 MHz RM5200, 768 MB RAM, 146 GB HDD
toasty
Unread postby toasty » Tue Jun 24, 2014 6:35 pm
My first O2! It was on ebay "for parts/repair” because the seller couldn't test it and I decided to take a gamble on it. Turns out it just needed a SOG capable monitor :mrgreen:
hinv:
CPU: MIPS R5000 Processor Chip Revision: 10.0
FPU: MIPS R5000 Floating Point Coprocessor Revision: 10.0
1 300 MHZ IP32 Processor
Main memory size: 768 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
/usr/gfx/gfxinfo:
        32 + 32 bitplanes
         Monitor 0 type: DEL -12215
         Video Output: 1280 pixels, 1024 lines, 59.94Hz (1280x1024_60)
It’s just missing the blue skin, top cover, second hard drive sled, and cdrom kit. Luckily, I have a scsi cdrom drive laying around so I used that to install IRIX. All I have to do now is find those parts and make this system complete.
Past: :Fuel: :Octane2: :O2: :O2: :O2: :Indy: Present: MacBook
Re: O2, 300 MHz RM5200, 768 MB RAM, 146 GB HDD
Unread postby recondas » Wed Jun 25, 2014 4:30 am
Congratulations, and welcome to nekochan.
sgtprobe
Unread postby sgtprobe » Tue Jul 01, 2014 5:34 am
Nice rescue. And now it have been given a second chance thanks to you Sir! :)
Edit:
Oh, and welcome :)
Old polygon wrangler
___________________
http://www.edgeloop.se
mopar5150
Unread postby mopar5150 » Sat Jul 26, 2014 3:45 pm
I have a parts machine with good plastics and drive you can have for the price of shipping. Free if you come pick it up.
:Tezro: :O3x0: :A350:
Unread postby ClassicHasClass » Sat Jul 26, 2014 5:13 pm
I can attest that mopar5150 doesn't bite. :)
toasty
Unread postby toasty » Sat Jul 26, 2014 6:05 pm
ClassicHasClass wrote:I can attest that mopar5150 doesn't bite. :)
I just PM'd him :)
I'm still new to SGI's and I have question: are there any significant revisions to the O2's back (front?) plane? I did some research on my machine and it seems to be from 1999. If I get a chassis from 1996 (or a later one from 2001), I can stick my system module in it and it would still work, right?
mopar5150
Unread postby mopar5150 » Sat Jul 26, 2014 7:04 pm
As far as I know there should be no issue putting your system module into any O2. I have received O2s that had different SCSI cables, some with DVD drives and some with shielding around the SCSI cable to the CD. I will send you a system that was running fine and just gave its system board to an O2+ so you should be able to plug in and go.
And no, I don't bite........ yet :twisted:
toasty
Unread postby toasty » Sat Jul 26, 2014 8:07 pm
Gotcha, thanks for the info!
toasty
Unread postby toasty » Sat Aug 09, 2014 3:59 pm
Many thanks to mopar5150 for the case and AV module. This O2 battlestation is now fully operational :twisted:. I've updated the hinv in my original post and here's a picture.
Unread postby vishnu » Sat Aug 09, 2014 7:08 pm
Deluxe! :mrgreen:
What happened to your spacebar? :shock:
bigD
Unread postby bigD » Sat Aug 09, 2014 7:28 pm
Friggin' sexy, man!
:Onyx2: :Indigo2: :O3x0:
toasty
Unread postby toasty » Sat Aug 09, 2014 8:27 pm
vishnu wrote:What happened to your spacebar? :shock:
It was a dumpster find, haha. Only PS/2 keyboard I have at the moment. A granite SGI board and mouse is next on the list though!
Ryan Fox
Unread postby Ryan Fox » Sun Aug 10, 2014 9:58 am
its a pity that most of these end up in a landfill I recently found an Octane2 r14 500 v6 that i need to revive :)
Nice find!
MAYA, nut-
Unread postby vishnu » Sun Aug 10, 2014 4:13 pm
I fished a brand spankin' new HP DT528AL keyboard out of the electronics scrap bin at work last week. Admittedly I had to sort through a lot of completely trashed ones to find it, but every time they toss out another batch there's always at least one untouched beauty in the mix...
