Tezro, quad 700 MHz, 5 GB
japes
Unread postby japes » Sun May 04, 2014 7:15 pm
I picked up a Tezro, it took a couple tries, but now I have one. It's not the prettiest, but it's not too ugly either.
The OS was panicing when I first had it on, and the console output was garbled or unresponsive. I've seen the L1 controller not turn on at first but turn on if I unplug and replug so I'm not sure if it has a hidden gremlin yet or not. At first it seemed to be when I plugged it into my USB-Serial adapter. Anyway, things I'll be keeping an eye on.
It had a stuck DVD drive so I replaced it with a new one from the recyclers for $2.00. I upgraded from 3 GB to 5 GB with memory I had on hand from building up my Origin 3000. I blame the 3k for my interest in the Fuel and now Tezro.
tezro 11# hinv -vm
       IP53_4CPU Board: barcode NCG813     part 030-1868-001 rev -C
       WS_INT_53 Board: barcode NRT021     part 030-1881-007 rev -A
          ASTODY Board: barcode MZD768     part 030-1726-004 rev -A
             IO9 Board: barcode NSX575     part 030-1771-005 rev -B
     PCI_SIO_UFC Board: barcode MYJ735     part 030-1657-003 rev  A
4 700 MHZ IP35 Processors
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0x1c
CPU 1 at Module 001c01/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 5120 Mbytes
Memory at Module 001c01/Slot 0: 5120 MB (enabled)
  Bank 7 contains 512 MB (Standard) DIMMS (enabled)
Integral SCSI controller 3: Version LS1030, low voltage differential
Integral SCSI controller 4: Version LS1030, low voltage differential
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: V12
Gigabit Ethernet: tg1, module 001c01, PCI bus 2 slot 2
  PCI Adapter ID (vendor 0x1000, device 0x0030) PCI slot 1
  PCI Adapter ID (vendor 0x104c, device 0xac28) PCI slot 2
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 1
  PCI Adapter ID (vendor 0x14e4, device 0x1645) PCI slot 2
IOC4 firmware revision 83
IP35prom in Module 001c01/Slot n0: Revision 6.172
l1 serial all
001c01-L1>serial all
Local System Serial Number      NVRAM         P1003492
Reference System Serial Number  NVRAM         P1003492
Local Brick Serial Number       EEPROM        NRT021
Reference Brick Serial Number   NVRAM         NRT021
INTERFACE   WS_INT_53       NRT021         030_1881_007          A    00
IO9         IO9             NSX575         030_1771_005          B    00
ODYSSEY     ASTODY          MZD768         030_1726_004          A    00
SNOWBALL    SNOWBALL_EDGE   NBL525         030_1927_003          B    00
NODE        IP53_4CPU       NCG813         030_1868_001          C    00
IO DGHTR    CHWS_IO_DAUG    NJS160         030_1875_003          A    00
DIMM 0     CE000000000000000CF39D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 2     CE000000000000000C2CAC00 M3 47L6423DT3-CA0   3D   10.0  N/A
DIMM 4     7F7FFE000000000012003BA5 CM2202B1            2     8.0  N/A
DIMM 6     7F7FFE000000000012003BAB CM2202B1            2     8.0  N/A
DIMM 1     CE000000000000000C4F9D00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 3     CE000000000000000C20AC00 M3 47L6423DT3-CA0   3D   10.0  N/A
DIMM 5     7F7FFE000000000012003B78 CM2202B1            2     8.0  N/A
DIMM 7     7F7FFE000000000012003B44 CM2202B1            2     8.0  N/A
l1 pci
001c01-L1>pci
Bus Slot Stat    Power Mode/Speed
  1    1 0x80 01   15W PCI   66MHz
  2    1 0x00 0f  none PCIX 100MHz
  2    2 0x00 0d   15W PCIX 100MHz
  2    3 0x00 0e   25W PCIX 100MHz
  3    1 0x00 00  7.5W PCI   33MHz
  3    2 0x00 0f  none PCI   33MHz
  4    1 0x80 01   15W PCI   66MHz
  4    2 0x80 0f  none PCI   66MHz
IO9/empty/gigE/dual-port u320 scsi
dual serial/empty/1gig FC/SNOWBALL-DM3
japes
Re: Tezro, quad 700 MHz, 5 GB
Unread postby japes » Sun May 04, 2014 7:20 pm
Here's a photo, terrible choice of monitor (1680x1050), but I'll find a 1600x1200 panel for it later.
Shot of the Tezro after unpacking at the office.
Unread postby ClassicHasClass » Sun May 04, 2014 9:21 pm
Very nice. I hope the gremlins stay away. Skins look pretty good in that photograph.
Unread postby recondas » Mon May 05, 2014 5:55 pm
Congrats japes - nice Tezro.
jmestrada
Unread postby jmestrada » Mon May 05, 2014 6:41 pm
Very nice! I've been eyeballing one on eBay myself... Just picked up an Octane2 in real good shape. Think my wife would choke me out if I bought another workstation! LOL
Unread postby ClassicHasClass » Tue May 06, 2014 7:00 am
I've been tempted a lot by the Tez but my limitation is space, heat and noise. The G5 is already pretty damn hot and noisy when it wants to be, and the Tez is much fatter. :P
japes
Unread postby japes » Fri May 16, 2014 6:26 pm
Tezro idles at about 340 watts with two 15k drives.
bigD
Unread postby bigD » Fri May 16, 2014 8:08 pm
Pimp!
:Onyx2: :Indigo2: :O3x0:
Octanelove
Unread postby Octanelove » Wed May 28, 2014 11:58 pm
what lovely Machine!, very nice, it's look Brand new! what you want use it to do?
I have two Octane2 in my home ! that also look pretty cool!
octane2
toxygen
Unread postby toxygen » Mon Oct 27, 2014 5:23 pm
How much did it cost you?
:Indigo2IMP: :Octane: This post was typed using dvorak keyboard layout - http://www.dvzine.org
Unread postby uunix » Mon Oct 27, 2014 5:29 pm
So nice.. and so big.. (said the actress to the vicar)...
japes
Unread postby japes » Mon Oct 27, 2014 11:51 pm
toxygen wrote:How much did it cost you?
I don't remember. I try not to remember what my old computers cost.
