Indigo, R4000/100MHz, 80MB, LG1
BetXen
Unread postby BetXen » Wed Aug 28, 2013 1:58 am
Here is my new Indigo machine.
It was still running since it was bought more than 20 years ago. During a long time, it was the web, database and service server as well as desktop computer of the IT manager of the Physics Departement of the Swiss Federal Institute of Technology. Latest services were removed this summer so that I could take it home... tadaaa !
It was only moved 2-3 times, and not powered off a lot more often, so it is in particularly good shape. Plastics are almost like new. Door is fully functional, with all hinges intact.
The Indigo is the very first Silicon Graphics I ever saw, in the mid-90's, when I visited the ECAL, Lausanne's Art School, more specifically the Infography department. I remember people were running TDI Explore on them. Unfortunately, mine is only equipped with the Entry graphic board. Who knows, I may upgrade it later, just for fun !
It is not connected to the network for the moment, so here is the basic hardware information and some pictures. I'll update with hinv and gfxinfo outputs later on.
hinv (from the PROM)
System: IP20
Processor: R4000 50MHz, with FPU
Primary I-cache size: 8KBytes
Primary D-cache size: 8 KBytes
Secondary cache size: 1024 KBytes
Memory size: 80MBytes
Graphics: LG1
SCSI Disk: scsi(0)disk(1)
SCSI Disk: scsi(0)disk(2)
SCSI Disk: scsi(0)tape(3)
Did you also see that the processor speed is 50MHz ? In the OS, hinv correctly reports 100MHz. Why ?
Indigo R4k/100, LG1
Indigo R4k/100, LG1, door open
Good old SGI logo
<--- EDIT 2013.09.03 --->
After putting in a "new" disk and installing Irix 6.5, here we are... Infos posted from the Indigo with Mozilla 1.0.2. So slow !
magnesium 1# hinv -mv
CPU: MIPS R4000 Processor Chip Revision: 2.2
1 100 MHZ IP20 Processor
Main memory size: 80 Mbytes
Instruction cache size: 8 Kbytes
Data cache size: 8 Kbytes
Integral SCSI controller 0: Version WD33C93B, revision C
  CDROM: unit 5 on SCSI controller 0
On-board serial ports: 2
Graphics board: LG1
Iris Audio Processor: revision 10
magnesium 2# /usr/gfx/gfxinfo
Graphics board 0 is "LG1MC" graphics.
        Managed (":0.0") 1024x768
        LG2 revision 3, REX revision 1.5, VC1 revision B, MC rev B ffi
        14" monitor, video option not installed.
magnesium 3# uname -aR
IRIX magnesium 6.5 6.5.22f 10070055 IP20
magnesium 4# scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d1l0:  Disk          IBM     DNES-309170     SAH0
ANSI vers 3, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds cmdqueing
Device is  ready
/dev/scsi/sc0d3l0:  Tape          ARCHIVE Python 25601-XXX2.54
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
Device is  not ready
/dev/scsi/sc0d5l0:  CD-ROM        PLEXTOR CD-ROM PX-32TS  1.03
Device is  ready
magnesium 5# /sbin/diskpatch -v
sc0d1l0:  Disk         IBM     DNES-309170     SAH0  Serial: AJ1R9863
Re: Indigo, R4400/100MHz, 80MB, LG1
Unread postby jan-jaap » Wed Aug 28, 2013 2:12 am
BetXen wrote:Did you also see that the processor speed is 50MHz ? In the OS, hinv correctly reports 100MHz. Why ?
Before the R4000, the internal and external clock of the CPU was the same, e.g. a 33MHz R3000 runs internally at 33MHz and so does the mainboard (or at least the bits interfacing the CPU).
R4000 (and contemporary Intel CPUs) introduced clock doubling: the internal frequency is a multiple of the external bus frequency.
In case of the first R4000 SGIs, the tech guys referred to the CPU by it's external frequency (50MHz), the marketing folks went with the highest number (100MHz). In the end, everybody went with the highest number, but the PROM still mentions the external frequency. Nothing to worry about.
These days with multi-GHz CPUs, the multiplier is of course much higher than 2 or 3x.
PS: nice looking Indigo!
BetXen
Unread postby BetXen » Wed Aug 28, 2013 4:42 am
Thanks for the info jan-jaap. Clear and precise, as usual :D
Unread postby ClassicHasClass » Wed Aug 28, 2013 10:27 am
That is a gorgeous Indigo.
fu
Unread postby fu » Wed Aug 28, 2013 11:56 am
BetXen wrote:...I visited the ECAL, Lausanne's Art School, more specifically the Infography department.
is this (still) an art major betx? with all these rivers of data these days it looks like its all statistics (for the shake of statistics)
BetXen
Unread postby BetXen » Wed Aug 28, 2013 2:21 pm
I dont really know, but I think it is still well renowned. At least it is still very active and you can very often hear news about it in the local radios.
The people I knew actually left a long time ago. It was mainly students and the previous IT manager. This guy helped me find Irix 3.0.2 QIC tapes when I was searching for media to reinstall the OS on my very first Silicon Graphics, a 4D/70GT.
I've just disassembled the box to give it a shower (only the plastics parts, don't worry). One screw to tight them all and in the shower to bring them... and it's done ! So well built... and the plastics is much more robust than later models. Everything is still in perfect shape and working order after 20 years. Times have changed ! Things were built to last...
[Title edited, since I realised that is was a R4000, not R4400]
BetXen
Re: Indigo, R4000/100MHz, 80MB, LG1
Unread postby BetXen » Tue Sep 03, 2013 1:42 pm
First post edited to add 'hinv', 'gfxinfo' and so on
fu
Unread postby fu » Tue Sep 03, 2013 5:15 pm
mea culpa, thought it was part of your degree/major
and that's mint indigo, i guess it's ready for the museum after its last bath :)
BetXen
Unread postby BetXen » Wed Sep 04, 2013 3:56 am
Hi fu.
No problem. Actually I didn't study there, but some kilometers away; some more scientific studies...
Yes, the machine is very clean now, inside and outside. I'll try to take better pictures in the next days, but will not be very often at home. Nothing is broken and once I removed the dust from the power supply it became very quiet. Only my R5k O2 does better.
On the OS side, it is for the moment running 6.5.22, but is very slow. I'll try 6.2 and maybe even a fresh install of 5.3 (I also still have the original harddisk, which is running fine besides the noise: 1 inch Conner disk 540Mo).
Regards,
jpstewart
Unread postby jpstewart » Wed Sep 04, 2013 8:00 am
BetXen wrote:On the OS side, it is for the moment running 6.5.22, but is very slow.
If you want to stick with 6.5.22, upgrade your RAM! The R4K Indigo can handle up to 384MB, and (in my experience) anything under 128MB is just too little for 6.5.x. 192MB and up is more realistic for actual use. I was quite pleased with the performance boost I got on my Indigo2 when going from 64MB to 320MB. (I realize it's not the same machine, but still....)
Of course, if you prefer the older IRIX versions anyway, then there's probably no need to upgrade RAM.
HP C8000
Digital DECstation 5000/125
Unread postby hamei » Wed Sep 04, 2013 6:30 pm
Have to agree with this ... when I had an Indigo (1) it was used next to an IBM Z-pro. The Z-Pro was dual Pentium Pro @ 240 mhz. The Indigo was a little slower at compute jobs but faster at graphics. Both were very usable. The Indigo was loaded on RAM, running 6.5 (but before 22 came out, probably about 14 ?)
Inidigo is a very nice computer. I really liked mine.
2 + 2 = 5
Unread postby vishnu » Wed Sep 04, 2013 11:40 pm
hamei wrote:Inidigo is a very nice computer. I really liked mine.
Well wha'd ya do wit it? :?:
You know what Mark Hughes said, an Indy is an Indigo without the "go"... ;)
BetXen
Unread postby BetXen » Wed Sep 21, 2016 11:45 pm
Tod clock replaced after memory upgrade.
Will update the hinv soon.
