Octane 2xR10k 400MHz, 2048MB, V12+DM2+VOB
fockion
Unread postby fockion » Fri Jan 04, 2013 2:34 am
Hi,
The newest addition to my collection
hinv -vm
            PM20 Board: barcode KYA016     part 030-1476-002 rev  B
            IP30 Board: barcode LKD614     part 030-1467-001 rev  D
             FP1 Board: barcode KBE183     part 030-0891-003 rev  G
    PWR.SPPLY.ER Board: barcode AAE0150158 part 060-0035-002 rev  A
        XTALKPCI Board: barcode MEJ121     part 030-0952-005 rev  E
  ODY128VERSIONB Board: barcode KWG943     part 030-1611-001 rev  C
   FIBRE_CHANNEL Board: barcode JKM842     part 030-0927-003 rev  E
       XT-DIGVID Board: barcode MHX098     part 030-1653-002 rev  H
2 400 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 2048 Mbytes
Xbow ASIC: Revision 1.4
  Disk drive: unit 1 on SCSI controller 1 (unit 1)
Integral SCSI controller 4: Version Fibre Channel AIC-1160, revision 2
Integral SCSI controller 5: Version Fibre Channel AIC-1160, revision 2
Graphics board: V12
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 0
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 1
socrates 48% /usr/gfx/gfxinfo
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1280 pixels, 1024 lines, 75.00Hz (1280x1024_75)
Sorry for low photo quality -- mobile phone photos. I'll try to take some with a real camera!
f.
:Octane2: 2xR14k 600MHz | 6GB | V12 + DCD
:Octane: R12k 400Mhz | MXE+ PVO
:Indigo2IMP: R4400 250MHz | MAXImpact + IMPACT VIDEO
fu
Re: Octane 2xR10k 400MHz, 2048MB, V12+DM2+VOB
Unread postby fu » Fri Jan 04, 2013 3:30 am
nice setup fock
did you sort the F190 w/ a proper 13w3 adapter?
just rotate the darn pics so we won't get any νευροκαβαλίκεμα :lol:
fockion
Unread postby fockion » Fri Jan 04, 2013 5:00 am
Hi Fu,
Pics rotated in order to avoid any physical injuries!!!
I made an adapter cable and works OK now, thanks!
f.
