I bought this machine March 2011 as a first foray into IRIX, upgraded to a Fuel a few months later but decided to beef this up a bit as well, with:
- extra RAM, 128MB -> 384MB (I had 32MB SIMMs lying around and was lucky to find they were the right spec, plus some from Ebay seller "1-800-4-memory", whose bundle of ten 32MB SIMMs for a reasonable "best offer" was a cost-effective way of replacing eight 16MB ones),
- 6.5.22m overlays and patches from SGI supportfolio
- bigger disks, 2GB -> 9GB -> 18GB -> 36GB (the 2GB came 95% full, and the 36GB now has around 10GB free!)
- the faster CPU, 200/1MB -> 250/2MB, and
- fast ethernet: G160 (after an abortive attempt with EISA), which took more autoconfig's and reboots than I was expecting to get working.
Next? maybe a CDROM sled, as I have a spare Yamaha 8424, but it's as easy to connect that externally. Maybe it's "finished"!
hinv and gfxinfo now yield:
Code:
CPU: MIPS R4400 Processor Chip Revision: 6.0
1 250 MHZ IP22 Processor
Main memory size: 384 Mbytes
Secondary unified instruction/data cache size: 2 Mbytes on Processor 0
Data cache size: 16 Kbytes
On-board serial ports: 2
Graphics board: GU1-Extreme
E++ controller: ec1, version 0
EISA bus: adapter 0
Code:
8 GEs, 2 REs, 24 bitplanes, 4 auxplanes, 4 cidplanes, Z-buffer
GR2 revision 6, VB2.0
HQ2.1 rev A, GE7 rev B, RE3.1 rev A, VC1 rev B, MC rev C
unknown, assuming 19" monitor
