Onyx 200. 4xR12000 270MHz. 1536MB. IR2. FC. GigE. DAT
bjornl
Unread postby bjornl » Sat Jun 23, 2012 7:45 am
Here's a little experiment involving an Origin 200, Gigachannel and an Onyx2 graphics module. Not a supported SGI configuration, but it works.
I might have posted the different components before, in their natural configurations, but not put together like this.
Together it is quite noisy, not something you would like to have next to your desk.
It works fine running IRIX6.5.16m. There can be issues with keyboard/mouse support in newer IRIXes.
IRIS 1# hinv
4 270 MHZ IP27 Processors
Main memory size: 1536 Mbytes
Integral SCSI controller 6: Version QL1040B (rev. 2), single ended
  CDROM: unit 1 on SCSI controller 1
  Tape drive: unit 7 on SCSI controller 1: DAT
Integral SCSI controller 2: Version Fibre Channel QL2200A
Integral SCSI controller 3: Version Fibre Channel QL2200A
Integral SCSI controller 4: Version Fibre Channel AIC-1160, revision 2
Integral SCSI controller 7: Version QL1040B (rev. 2), single ended
Integral SCSI controller 8: Version QL1040B (rev. 2), single ended
Integral SCSI controller 5: Version Fibre Channel AIC-1160, revision 2
IOC3 serial port: tty1
IOC3 serial port: tty2
IOC3 serial port: tty3
IOC3 serial port: tty4
IOC3 parallel port: plp2
Graphics board: InfiniteReality2
Gigabit Ethernet: eg0, module 1, PCI slot 5, firmware version 0.0.0
Fast Ethernet: ef1, version 1, module 2, slot MotherBoard, pci 2
Origin 200 base I/O, module 2 slot 2
Origin PCI XIO board, module 1 slot 7: Revision 4
Origin 200 base I/O, module 1 slot 1
Origin FIBRE CHANNEL board, module 1 slot 2: Revision 4
IOC3 external interrupts: 1
IOC3 external interrupts: 2
IRIS 2# hinv -vm
  PIMM_270_4M_2P Board: barcode KVJ031     part 013-2511-001 rev  D
  XBOX_DUALXTOWN Board: barcode HLH794     part 030-1252-001 rev  F
        XBOX_EXT Board: barcode HJZ829     part 030-1264-001 rev  C
            IP29 Board: barcode KVJ192     part 030-1389-002 rev  B
   FIBRE_CHANNEL Board: barcode HPB024     part 030-0927-003 rev  C
          GE14-4 Board: barcode GKL909     part 030-1129-002 rev  H
           KTOWN Board: barcode FTF047     part 030-1067-001 rev  F
  PIMM_270_4M_2P Board: barcode KBW649     part 013-2511-001 rev  D
            IP29 Board: barcode KVG280     part 030-1389-002 rev  B
Location: /hw/module/2/slot/MotherBoard/node/xtalk/8/pci/2
CPU 0 at Module 1/Slot 1/Slice A: 270 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 2.3. Scache: Size 4 MB Speed 180 Mhz  Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 270 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 2/Slot 2/Slice A: 270 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 2/Slot 2/Slice B: 270 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 1536Mbytes
Memory at Module 1/Slot 1: 768 MB (enabled)
  Bank 0 contains 256 MB (Standard) DIMMS (enabled)
  Bank 1 contains 256 MB (Standard) DIMMS (enabled)
  Bank 2 contains 128 MB (Standard) DIMMS (enabled)
  Bank 3 contains 128 MB (Standard) DIMMS (enabled)
Memory at Module 2/Slot 2: 768 MB (enabled)
  PCI Adapter ID (vendor 4370, device 8704) pci slot 5
  PCI Adapter ID (vendor 4215, device 4128) pci slot 7
  PCI Adapter ID (vendor 4265, device 9) pci slot 5
  PCI Adapter ID (vendor 4215, device 8704) pci slot 6
  PCI Adapter ID (vendor 4215, device 8704) pci slot 7
  PCI Adapter ID (vendor 36868, device 4448) pci slot 0
  PCI Adapter ID (vendor 36868, device 4448) pci slot 1
HUB in Module 1/Slot 1: Revision 5 Speed 90.00 Mhz (enabled)
HUB in Module 2/Slot 2: Revision 5 Speed 90.00 Mhz (enabled)
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.156
IP27prom in Module 2/Slot n2: Revision 6.156
IRIS 3# /usr/gfx/gfxinfo
        Display has 8 channels
        4 GEs (of 4), occmask = 0x0f
        4 RM7 boards (of 4) 1/1/1/1
        Texture Memory: 64MB/64MB/64MB/64MB
        Extra-Large pixel depth
        32K cmap, 64K external gamma
         Video Output: 1280 pixels, 1024 lines, 60.00Hz (1280x1024_60.vfo)
IRIS 4# /usr/gfx/gfxinfo -v
        brd: 18160a04 3020c06/3020c06/3020c06/3020c06 51bf1002
        rm0: 15032057 15431057
              4631057 2/2/2/2
              4d31057 2/2/2/2/2/2/2/2
              4938057 5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5
        rm1: 15032057 15431057
              4631057 1/1/1/1
              4938057 4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4
        rm2: 15032057 15431057
              4631057 2/2/2/2
        rm3: 15032057 15431057
              4631057 2/2/2/2
         dg: 05532057
              5838057 1/1/1/1
              5631057 1/1/1/1/1/1/1/1
        GE:   NIC #:      0000.0028.a5c6 (family: 0b)
              Serial #:   GKL909
              Part #:     030-1129-002
        KT:   NIC #:      0000.0018.2913 (family: 0b)
              Serial #:   FTF047
              Part #:     030-1067-001
        RM0:  NIC #:      0000.0013.36f7 (family: 0b)
              Serial #:   EDZ751
              Part #:     030-1054-001
        TM0:  NIC #:      0000.0019.11f5 (family: 0b)
              Serial #:   FDR444
              Part #:     030-1053-001
        RM1:  NIC #:      0000.000e.42ba (family: 0b)
              Serial #:   EDW096
        TM1:  NIC #:      0000.000e.3eec (family: 0b)
              Serial #:   EDZ085
        RM2:  NIC #:      0000.0013.3306 (family: 0b)
              Serial #:   EDZ869
        TM2:  NIC #:      0000.0019.10b0 (family: 0b)
              Serial #:   FDR280
        RM3:  NIC #:      0000.0025.9c0e (family: 0b)
              Serial #:   DFC228
        TM3:  NIC #:      0000.002c.519b (family: 0b)
              Serial #:   GCE107
        BP:   NIC #:      0000.001d.abad (family: 0b)
              Serial #:   ERY238
              Part #:     013-1760-001
        DG:   NIC #:      0000.001a.381b (family: 0b)
              Serial #:   GFY097
              Part #:     030-1087-001
        DGOPT:No NIC serial number available.
         Video Format Flags:  (none)
         Sync Output(s):
          Composite sync on Green
          Composite TTL sync on Aux 0
         Using Gamma Map 0
joegill
Re: Onyx 200. 4xR12000 270MHz. 1536MB. IR2. FC. GigE. DAT
Unread postby joegill » Sat Jun 23, 2012 9:18 am
images, please !
If you can lift it all by yourself, I probably don't want it.
bjornl
Unread postby bjornl » Sun Jun 24, 2012 2:26 am
It is not the the prettiest setup, so I didn't take so many pictures, but I did of course take some.
The plastic covers are missing of the O200 for example. I have covers, except a Gigachannel cover I think.
Pictures are taken with my cellphone so the quality is not so good.
I have this in my garage, and when I'm not using it, it is just standing against the wall so the car will have room.
Four racks against the wall
It's a SGI branded Clariion rack in which I have placed the O200 and some other rack-stuff.
I pull out the Clariion and the Onyx2 rack to be able to access the back and connect it all.
I the right edge of the picture you can se the thick XTOWN-KTOWN cable and a smaller grounding cable between the chassis
Clariion rack
Back of Clariion. XTOWN, keyboard, mouse and serial connected, and of course the O200 + Gigachannel cables.
Back of Clariion
Back of Onyx2. KTOWN and monitor cable.
Back of Onyx2
I used a laptop to get IRIX installed. After that, I could run it from the normal keyboard/mouse.
The consoles
To make this more readable I didn't resize this picture, but it's not good quality
Closeup of Onyx 200 system info
Unread postby vishnu » Sun Jun 24, 2012 3:07 pm
That is amazing! :shock:
What'cha gonna do with it? :mrgreen:
jpstewart
Unread postby jpstewart » Mon Jun 25, 2012 7:47 am
vishnu wrote:What'cha gonna do with it? :mrgreen:
Make the rest of us jealous and cause a lot of head scratching? :lol:
When I first saw the thread, I was convinced "Onyx 200" was a typo. Apparently not. But it's that modularity of the hardware permitting such odd configurations that makes SGI hardware so much fun to play with, isn't it?
Perhaps this is the start of bjornl's evil plot to take over the world by leaving the rest of sitting here muttering under our breath, "what the heck?". Or maybe that's just me. :D
HP C8000
Digital DECstation 5000/125
bjornl
Unread postby bjornl » Fri Jun 29, 2012 12:02 pm
Thank you
What do you mean? There are dozens of household uses. Heating the garage, testing earprotection, weightlifting. Just to name a few... :)
I will probably run it very rarely since it is easier to startup the Onyx2 that is usually connected, but maybe I should try the MGRAS while I'm at it.
SAQ's Origin 2000/200 hardware aggregator was onto this idea, but it seems like my hinv was first.
Anyway, jpstewart is not far from the truth :D . It's fun to play with and I got to the wiki :D
Unread postby vishnu » Fri Jun 29, 2012 5:22 pm
bjornl wrote:What do you mean? There are dozens of household uses. Heating the garage, testing earprotection, weightlifting. Just to name a few... :)
Ha ha, yet more sgi hardware put to it's ultimate best use... :lol:
Voralyan
Unread postby Voralyan » Thu Jul 05, 2012 6:25 am
Nice :)
I will definitely try this if I ever get a Onyx 2 KCAR (this is what the IR "bricks" of the Onyx 2 were named
before they were actually bricks...?!).
I'm curious if it will work if the O200 has the older R10k PIMMs... I tried the Impact SE/SI setup and IRIX
complained about too old HUBs...
:A3502L: :O2000: :O200: = :O200: - :O200: :O200: :Octane: :Octane: :320: :O2: :Indigo2IMP: :Indy:
+ | d | i | g | i | t | a | l | +apple +[...] ;)
