It is currently Thu May 23, 2013 3:31 pm
Post new topic Reply to topic  [ 1 post ]
Unread postPosted: Tue May 08, 2012 1:43 pm
Online
Got this from recondas over the weekend, finally got it somewhat configured (SSH, Samba etc) and swapped out the 4x256mb sticks for 4x512mb sticks that I had laying around.
hinv -vm
Code:
            IP34 Board: barcode NCL405     part 030-1707-004 rev -A
        IP34PIMM Board: barcode NCL237     part 030-1730-002 rev -E
       ASTODYV10 Board: barcode NNJ828     part 030-1826-003 rev -A
1 600 MHZ IP35 Processor
Main memory size: 2048 Mbytes
Graphics board: V10
Gigabit Ethernet: tg1, module 001c01, PCI bus 2 slot 1
Iris Audio Processor: version EMU revision A3, number 1
  PCI Adapter ID (vendor 0x1102, device 0x0004) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x4001) PCI slot 2
USB controller: type OHCI
/usr/gfx/gfxinfo
Code:
        BUZZ version B.2
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: ACR -21132
Next up is getting a vfo for 1680x1050x16@60hz working...
:Indigo: 33mhz R3k/48mb/XS24 :Indy: 150mhz R4400/256mb/XL24 :Fuel: 600mhz R14kA/2gb/V10 Image 8x1.4ghz Itanium 2/8GB :O3x08R: 32x600mhz R14kA/24GB :Tezro: 4x700mhz R16k/8GB/V12/DCD/SAS/FC/DM5 :O3x0: 2x700mhz R16k/4GB
Users browsing this forum: Adrenaline and 1 guest
