It is currently Tue Jun 18, 2013 5:00 pm
Post new topic Reply to topic  [ 2 posts ]
Unread postPosted: Tue Feb 28, 2012 4:44 am
I've had an O2 for some years but now finally have the space to use it so I thought I'd upgrade it a little and post the spec:
hinv -vm
Code:
1 300 MHZ IP32 Processor
Main memory size: 320 Mbytes
FLASH PROM version 4.18
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
gfxinfo -vv
Code:
        Managed (":0.0") 1600x1024
        32 bitplanes
         Monitor 0 type: SGX 1601
         Video Output: 1600 pixels, 1024 lines, 60.00Hz (1600x1024_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  SGI MultiLink
Yes, you've spotted that I haven't opened my wallet in years so I'm using a multilink adapter with a 1600sw (the 1600sw was my PC monitor for some years but now it can be with this O2 full time), not a flat panel adapter. If I can see an FPA at the right price I'll grab it. Anyone got one for reasonable cost in the UK?
scsicontrol -i /dev/scsi/*
Code:
/dev/scsi/sc0d2l0:  Disk          ModusLnkMXO3367SC800600SM108
Device is  ready
/dev/scsi/sc0d4l0:  CD-ROM        TOSHIBA CD-ROM XM-6201TA1037
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  reladdr synch linkedcmds
Device is  not ready
When I found this O2 about 6 years ago it had an R10k 195MHz and a 4GB HD so I have upgraded those already recently. CD-ROM also died and replaced. I am absolutely loving how easy these things are to swap components - making PCs look ridiculously tricky by comparison. RAM upgrade next perhaps? I seem to have the bug :roll:.
:Octane: :O2: :1600SW: [formerly :Indigo2: :Indy: :Indigo:]
Unread postPosted: Thu Mar 22, 2012 4:20 pm
I found eventually an affordable FPA for this O2 - so here is the changed hinv -vm:
Code:
Vice: TRE
1600SW Flat Panel adapter board and display.
...and here is the new gfxinfo:
Code:
        32 bitplanes
        Timing table flags:
         Monitor 0 type: Unknown
         Video Output: 1600 pixels, 1024 lines, 50.00Hz (1600x1024_50p)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  SGI Flat Panel 1600SW
Given I now have the display options for O2 for both MLA and the FPA, and that O2 performance is linked closely to its graphics performance, if anyone has software tests they would like me to perform to identify differences I might be able to run these. Certainly - and this is personal opinion alone - the FPA seems to give the more polished desktop experience.
