It is currently Sat May 25, 2013 8:39 pm
Post new topic Reply to topic  [ 1 post ]
Unread postPosted: Sat Oct 15, 2011 2:57 am
Original spec when acquired, August 2011: R16K 700MHz, 1024MB RAM (4x256 standard), V10, 73GB HDs
UPDATE September 2011: replaced 73GB with two 146GB HDDs
UPDATE January 2012: RAM upgrade, soundcard
PCI cards are LSI 20320-HP, Creative SB0090 soundcard and Belkin F5U220 USB.
UPDATE September 2012: Belkin F5U503 Firewire card and 1TB external disk
UPDATE May 2013: replaced V10 (030-1826-003 rev -A) with V12 (ex-Tezro)
hinv -vm
Code:
            IP34 Board: barcode NAS621     part 030-1707-003 rev -M
        IP34PIMM Board: barcode MSY420     part 030-1891-001 rev -D
      ODY128B1_2 Board: barcode NWM092     part 030-1884-005 rev -B
1 700 MHZ IP35 Processor
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xa
Main memory size: 4096 Mbytes
Integral SCSI controller 6: Version IEEE1394 SBP2
Integral SCSI controller 7: Version LS1030, low voltage differential
Integral SCSI controller 8: Version LS1030, low voltage differential
  Disk drive / removable media: unit 6 on SCSI controller 1
Graphics board: V12
Iris Audio Processor: version EMU revision A3, number 1
  PCI Adapter ID (vendor 0x1033, device 0x0035) PCI slot 1
  PCI Adapter ID (vendor 0x1033, device 0x00e0) PCI slot 1
  PCI Adapter ID (vendor 0x1000, device 0x0030) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x0004) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x7003) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x4001) PCI slot 2
  PCI Adapter ID (vendor 0x104c, device 0x8024) PCI slot 3
USB controller: type OHCI
gfxinfo
Code:
   Managed (":0.0") 1920x1200
   BUZZ version B.2
   PB&J version 1
   128MB memory
      Banks: 4, CAS latency: 3
    Monitor 0 type: GSM 8704
    Video Output: 1920 pixels, 1200 lines, 60.00Hz (1920x1200_60p.vfo)
The "GSM8704" is in this case a TV - 22LG3000 - connected using DVI-HDMI; my Pi uses the other HDMI input and there is also a VGA input for the RiscPC and EspressoPC. This replaced an Iiyama 9017 CRT when we got a new TV!
uname -aR reports "IRIX64 redbox 6.5 6.5.30m 07202013 IP35"
scsicontrol -v
Code:
/dev/scsi/sc0d1l0:  Disk          FUJITSU MAP3147NP       5605
Device is  ready
/dev/scsi/sc1d4l0:  CD-ROM        TOSHIBA DVD-ROM SD-M14011007
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
Device is  not ready
/dev/scsi/sc1d6l0:  Disk          SyQuest SQ3270S         3_05
Device is  not ready
The Syquest shows "Device is not ready as there is no cartridge present - it seems to operate very nicely, mounting automatically when a cartridge is inserted and unmounting from the "Eject" option on the menu.
I also have a second 146GB drive fitted but only connect power when wanting to back up. The Fujitsu is set to spin up on command rather than power-on, so PROM-only operations can happen without wear on the drive (handy when fitting / troubleshooting other hardware!).
L1 info - for some reason I cannot get anything from "l1cmd pci" although I am sure this has worked in the past.
l1cmd flash status
Code:
Flash image A currently booted
Image      Status        Revision    Built
  A     user default    1.44.0       07/17/2006 18:20:38
  B     valid           1.44.0       07/17/2006 18:20:38
l1cmd serial all
Code:
Local System Serial Number      EEPROM        08:00:69:10:6F:CB
Local Brick Serial Number       EEPROM        NAS621
Reference Brick Serial Number   NVRAM         NAS621
NODE        IP34            NAS621         030_1707_003          M    00
MAC         MAC ADDRESS     NA             NA                    NA   NA
PIMM        IP34PIMM        MSY420         030_1891_001          D    00
XIO         ODY128B1_2       NWM092         030_1884_005          B    00
DIMM 0     CE000000000000000C9B0F00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 2     CE0000000000000028181900 M3 46L2820BT1-CA0   0B    8.0  N/A
DIMM 1     CE000000000000000C5F0B00 M3 46L2820DT2-CA0   2D   10.0  N/A
DIMM 3     CE0000000000000027CE1400 M3 46L2820BT1-CA0   0B    8.0  N/A
l1cmd env
Code:
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.125
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.096
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.337
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.470
          1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.466
        5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.122
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
 PIMM 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.125
          SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.522
          VCPU    Enabled  10%   1.13/  1.38  20%   1.00/  1.50    1.241
     PIMM 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.495
 PIMM 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
   PIMM 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.122
  XIO 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.938
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.457
  XIO 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
FAN  0  EXHAUST    Enabled          920         1188
FAN  1       HD    Enabled         1560         2280
FAN  2      PCI    Enabled         1120         1562
FAN  3    XIO 1    Enabled         1600         2463
FAN  4    XIO 2    Enabled         1600         2376
FAN  5       PS    Enabled         1349         3308
 0 NODE 0            Enabled    [Autofan Control]    80C/176F   35C/ 95F
 1 NODE 1            Enabled    [Autofan Control]    80C/176F   39C/102F
 2 NODE 2            Enabled    [Autofan Control]    80C/176F   28C/ 82F
 3 PIMM              Enabled    [Autofan Control]    80C/176F   41C/105F
 4 ODYSSEY           Enabled    [Autofan Control]    80C/176F   44C/111F
 5 BEDROCK           Enabled    [Autofan Control]    85C/185F   39C/102F
The V10 used to run at 38C, so 44C after an hour's use (and the PIMM at 2C wamer) was a very slight concern, but the fans seem only slightly faster. It was January 2012 when I last put env output in this entry, quite possible at night so the ambient temperature may have been several degrees lower (the Fuel is in a north-facing corner room). Checking again later, the V12 and PIMM were both down a couple of degrees AND the fans were slower, so I should stop worrying!
Fuel; Indigo2; RiscPC Kinetic-StrongARM RISCOS4.39; EspressoPC ViaC3/900 Debian-testing; RPi B RISCOS5.19 or Raspbian
