Octane2,2xR12K 360,1408MB,V10
m20003293
Unread postby m20003293 » Fri Oct 07, 2011 1:40 am
Still had to post the hinv of my new blue box..
Photos can be found here: http://forums.nekochan.net/viewtopic.php?f=14&t=16725638#p7342740
Selling the green box now on that auction site.. lack of space unfortunately:
http://www.ebay.de/itm/130583330008?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
Not trying to advertise here, but just look.. these things seem to be worth not really much these days.
Ok.. now for the new box, the infos:
IRIS 1% hinv -vvm
      PM20360MHZ Board: barcode LKH102     part 030-1591-001 rev  B
        Group ff Capability ffffffff Variety ff Laser 00000053b37d
            IP30 Board: barcode LKL269     part 030-1467-001 rev  D
        Group ff Capability ffffffff Variety ff Laser 000000593ecc
             FP1 Board: barcode MGE043     part 030-0891-003 rev  J
        Group ff Capability ffffffff Variety ff Laser 00000053aad1
    PWR.SPPLY.ER Board: barcode AAE9140400 part 060-0035-001 rev  C
        Group ff Capability ffffffff Variety ff Laser 0000003445fd
        XTALKPCI Board: barcode GXH027     part 030-0952-005 rev  C
        Group ff Capability ffffffff Variety ff Laser 000000253d6c
   ODY32VERSIONB Board: barcode LJV154     part 030-1655-001 rev  C
        Group ff Capability ffffffff Variety ff Laser 000000551488
2 360 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 1408 Mbytes
Xbow ASIC: Revision 1.4
  CDROM: unit 3 on SCSI controller 1
Integral SCSI controller 3: Version QL1080, low voltage differential
Graphics board: V10
  PCI Adapter ID (vendor 0x1077, device 0x1080) PCI slot 2
  PCI Adapter ID (vendor 0x114f, device 0x0029) PCI slot 3
PCI card, bus 0, slot 3, Vendor 0x114f, Device 0x8
IRIS 2% /usr/gfx/gfxinfo
        BUZZ version B.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: Unknown
Still trying to get that 3-com gbit controller in slot 1 working.. Patched the driver, still not working :oops:
