Octane2: 2x400MHz | V12 | DCD | DM2 | DM10 | PCI Cage | GigE
Unread postby recondas » Fri Sep 23, 2011 7:38 pm
Thanks to another nekochan member I've acquired a very clean Octane2 (the incandescent portion of the lightbar even works).
The graphics carrier originally included one of the SGI XIO dual-channel FC boards, until its services are needed I pulled it to prevent the automatic fastfan mode that occurs if XIO slot 'C' is populated (the V12 uses slot(s) A/B, and the DM2 slot 'D'). The installed memory is eight 256MB DIMMs (edit: now six 512MB and two 256MB DIMMs), and until I rearrange monitors the display is currently connected to the 13W3 port on the V12.
hinv -vm
      PM20400MHZ Board: barcode LKE894     part 030-1476-002 rev  B
            IP30 Board: barcode KTV280     part 030-1467-001 rev  D
             FP1 Board: barcode KVJ895     part 030-0891-003 rev  G
    PWR.SPPLY.ER Board: barcode AAE0210721 part 060-0035-002 rev  A
        XTALKPCI Board: barcode MDS825     part 030-0952-005 rev  E
  ODY128VERSIONB Board: barcode MDF834     part 030-1611-001 rev  C
       XT-DIGVID Board: barcode MJX248     part 030-1653-002 rev  H
2 400 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 3584 Mbytes
Xbow ASIC: Revision 1.4
Integral SCSI controller 7: Version IEEE1394 SBP2
  IEEE1394 Disk: node d0160100001dc0 port 0 lun 0 on SCSI controller 7 (unit 2)
Graphics board: V12
Iris Audio Processor: version RAD revision 13.0, number 2
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 1
  PCI Adapter ID (vendor 0x104c, device 0x8024) PCI slot 3
IIDC Video Camera: unit 0, revision 1.30, connected to DM10, unit 0
XT-DIGVID Multi-standard Digital Video: controller 1, unit 1, version 0x0
Dual Channel Display
/usr/gfx/gfxinfo -vv
        Managed (":0.0") 3200x1200
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: VSC 4892        Monitor 2 type: VSC 4892
         Video Output: 1600 pixels, 1200 lines, 60.00Hz (2@1600x1200_60_ds)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  VSC-4892
         Gain (all color components) - 0.000000 ; range [1,10]
        Channel 1:
         Origin = (1600,0)
         Sync Disabled
         Using Gamma Map 0
scsicontrol -i /dev/scsi/*
Device is  ready
/dev/scsi/sc0d2l0:  Disk          FUJITSU MAN3184MC       5507
Device is  ready
scsicontrol -i /dev/scsi/1394/d0160100001dc0/lun0/c7p0
/dev/scsi/1394/d0160100001dc0/lun0/c6p0:  Disk          SCM     CAMERAMATE-CF   1394
ANSI vers 4, ISO ver: 0, ECMA ver: 0; supports:
Device is  ready
configmon -h
  SEQ            NAME      LOCATION          SERIAL_NUM   PART_NUMBER  REVISION
    0              NA            NA                  NA            NA        NA
    1             FP1            NA              KVJ895  030-0891-003         G
    2            IP30            NA              KTV280  030-1467-001         D
    3      PM20400MHZ            NA              LKE894  030-1476-002         B
    4  ODY128VERSIONB            NA              MDF834  030-1611-001         C
    5       XT-DIGVID            NA              MJX248  030-1653-002         H
    6    PWR.SPPLY.ER            NA          AAE0210721  060-0035-002         A
    7        XTALKPCI            NA              MDS825  030-0952-005         E
    8     SCSI_CTLR_0            NA                  NA            NA        NA
    9         DRIVE_1            NA  3CE14L63    Copyrigh    SX173404LC      BD13
   10         DRIVE_2            NA        UFL3P1901VYE     MAN3184MC      5507
   11     SCSI_CTLR_1            NA                  NA            NA        NA
   12     SCSI_CTLR_7            NA                  NA            NA        NA
uname -aR
IRIX64 octane 6.5 6.5.30m 07202013 IP30
xtdigvid_hinv
/hw/node/xtalk/10
        XT-DIGVID (part number 030-1653-002 H), serial number MJX248
        IRIX number 1
        ML Device Index 1
xtdigvid_confidence
Unzipping ml reference frames...
done
Uncompressing xtdigvid reference frames...
done
***        XTDIGVID_CONFIDENCE ===== XTDIGVID_CONFIDENCE          ***
System type is: OCTANE2
System has 2 CPUs and 3584MB of memory
Found 1 XTDIGVID board(s)
Starting xtdigvid_confidence script ......
Total XTDIGVID boards in the system is 1 board(s).
Test will run for 1 loop(s).
Board(s) information:
  XT-DIGVID plugged in /hw/node/xtalk/10
    (Part number is 030-1653-002, Rev H), Serial number MJX248
>>>>> PLEASE NOTE ABOUT PART NUMBERS <<<<<
>>>>> Each part number above corresponds to an XTDIGVID board.
==> Please verify that each board information is correct.
==> Verify that the total board reporting number matches
==> the number of boards installed.  Are they matched ? (y/n): y
Continuing with the xtdigvid_confidence......
Running standard XTDIGVIDTST tests.
INSTRUCTION:
   1) Connect a LVDS cable from the xtdigvid connector labelled P1
      to the VBOB connector labelled P1.
   2) Connect a LVDS cable from the xtdigvid connector labelled P2
      to the VBOB connector labelled P2.
   3) On the VBOB, connect a coax from 'HD out 1' to 'HD in 1'.
                   connect a coax from 'HD out 2' to 'HD in 2'.
   4) On the VBOB, connect a coax from 'SD out 1' to 'SD in 1'.
                   connect a coax from 'SD out 2' to 'SD in 2'.
Is everything ready <y/n>?: n
....Further DM2 testing will have to wait until I acquire a VBOB and a pair of LVDS cables)
Re: Octane2: 2x360MHz | V12 | DCD | DM2 | PCI Card Cage | Gi
Unread postby recondas » Sun Sep 25, 2011 8:04 am
Added a couple of photos....
Unread postby nekonoko » Mon Sep 26, 2011 2:30 pm
Looks fantastic :)
Unread postby recondas » Mon Sep 26, 2011 9:19 pm
nekonoko wrote:Looks fantastic :)
Thanks! ;)
smj
Unread postby smj » Tue Sep 27, 2011 3:57 pm
That is entirely unacceptable. If I ever visit, I'm putting an Avery label on it. ;)
Unread postby recondas » Tue Sep 27, 2011 6:49 pm
smj wrote:That is entirely unacceptable. If I ever visit, I'm putting an Avery label on it. ;)
It did have one, but I got a little overzealous while appling low-gloss armorall.
BTW - don't you also have an V12-DCD-DM2-DM5-FC equipped Octane2 to immortalize in an hinv post? Preferably with a few photos so we can see just how pathological the Avery label fixation has become. :D
smj
Unread postby smj » Thu Sep 29, 2011 12:27 pm
recondas wrote:BTW - don't you also have an V12-DCD-DM2-DM5-FC equipped Octane2 to immortalize in an hinv post? Preferably with a few photos so we can see just how pathological the Avery label fixation has become. :D
Yeah, and I'd love to remove the FC board and re-arrange things to avoid fast-fan.
I have to complete a culling of the Octanes, and figure out what I'm keeping - probably just one built around the V12, another around the MXE+PVO. The sticking point is testing the components I've collected and building up the other three chassis so they can find new homes.
In theory that will be a trigger for an update of the remaining Octane' hinv posts.
fu
Unread postby fu » Sat Oct 01, 2011 10:53 am
mint indeed
reminds me a of a new old stock octane you got during the warehouse clearance, congrats rec :)
m20003293
Unread postby m20003293 » Fri Oct 07, 2011 1:46 am
Very nice....
Wow those DVI connectors are great :) Wish I could find them for my V10 card
Unread postby jan-jaap » Fri Oct 07, 2011 2:17 am
That is a very nice looking Octane!
recondas wrote:
xtdigvid_confidence
INSTRUCTION:
Good find. I will have to try this myself. I have the VBOB & cables, but all coax cables I have are survivors from the time I lived in a student house where we ran a 10base2 network :shock: They are buried so deep I may as well order some new ones :oops:
Unread postby recondas » Fri Oct 07, 2011 5:24 am
m20003293 wrote:Very nice.... Wow those DVI connectors are great :) Wish I could find them for my V10 card
Thank you. The DVI ports are on a Dual Channel Display option board commonly called a DCD. DCDs do make semi-rare appearances on eBay. Two nekochan members have recently had some listed on eBay, so you could also try a post in the wanted forum.
jan-jaap wrote:That is a very nice looking Octane!
Thank you as well. The nice appearance is courtesy of the care taken by the previous owner - it's nice not have have to deal with the 'it came from surplus where it was pushed across the floor on its plastic parts because it was too heavy to lift" appearance of so much of what appears on eBay these days.
jan-jaap wrote:Good find. I will have to try this myself.
If you happen to have a DIVO in one of your Onyx2s (which also work in an Octane), there are similar tools (divohinv and divotest) there too.
BTW, when you run the xtdigvid_confidence tests, please post some details.
Unread postby recondas » Fri Oct 14, 2011 5:23 pm
Added a gig and a half of RAM and updated the hinv.......
Re: Octane2: 2x360MHz | V12 | DCD | DM2 | DM10 | PCI Cage |
Unread postby recondas » Sun Oct 16, 2011 12:54 pm
...... and a pseudo DM10. This one is the Adaptec AFW-4300B with the red PCB mentioned in the Octane Hardware Aggregator (and elsewhere in the forums). It successfully reads and writes Compact Flash media using a MicroTech FWCameraMate.
I did discover if the 32-bit PCI Adaptec AFW-4300B was installed in a numerically lower PCI slot (in the PCI card cage) than the 64-bit PCI-X GigE board I'd get PCI Bridge errors during boot and neither would function reliably after boot. Installing the PCI-X board in PCI slot 1 and the 32-bit board in slot 3 resolved the issue.
Re: Octane2: 2x400MHz | V12 | DCD | DM2 | DM10 | PCI Cage |
Unread postby recondas » Thu Sep 20, 2012 2:47 pm
Added a dual 400Mhz processor module and updated the original hinv post.
Unread postby hamei » Tue Sep 25, 2012 10:29 pm
recondas wrote:...... and a pseudo DM10.
I wonder if neko's lockups with the Adaptec Duoconnect in the Tezro were due to a similar peculiarity ?
