O2: IP32 R12000 270MHz (1MB) CRM rev C, 512MB RAM, HP BD036
OlaHughson
Unread postby OlaHughson » Mon Sep 19, 2011 12:59 pm
IRIX Oxygenium 6.5 6.5.22m 10070056 IP32
1 270 MHZ IP32 Processor
Main memory size: 512 Mbytes
FLASH PROM version 4.18
  Tape drive: unit 4 on SCSI controller 1: DAT
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
Vice: TRE
Photos: http://www.flickr.com/photos/rhadmor/se ... 707408054/
(-)Ola Hughson
Current hardware inventory: http://olatheskunk.pl/computers/
