Fuel: 600MHz | V12 | 4GB | EMU Audio | GigE
Unread postby recondas » Tue Jul 19, 2011 12:58 pm
 hinv -vm
            IP34 Board: barcode NCL405     part 030-1707-004 rev -A
        IP34PIMM Board: barcode NCL237     part 030-1730-002 rev -E
          ASTODY Board: barcode MYD122     part 030-1726-005 rev -A
1 600 MHZ IP35 Processor
Main memory size: 4096 Mbytes
Graphics board: V12
Gigabit Ethernet: eg0, module 001c01, pci_bus 2, pci_slot 2, firmware version 0.0.0
Iris Audio Processor: version EMU revision A3, number 1
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x0004) PCI slot 3
  PCI Adapter ID (vendor 0x1102, device 0x7003) PCI slot 3
  PCI Adapter ID (vendor 0x1102, device 0x4001) PCI slot 3
USB controller: type OHCI
 /usr/gfx/gfxinfo -v
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
# l1cmd serial all
Local System Serial Number      EEPROM        08:00:69:10:72:D9
Local Brick Serial Number       EEPROM        NCL405
Reference Brick Serial Number   NVRAM         NCL405
NODE        IP34            NCL405         030_1707_004          A    00
MAC         MAC ADDRESS     NA             NA                    NA   NA
PIMM        IP34PIMM        NCL237         030_1730_002          E    00
XIO         ASTODY          MYD122         030_1726_005          A    00
DIMM 0     CE000000000000000C6A0100 M3 46L2820DT2-CA0   2D    10.0  N/A
DIMM 2     CE000000000000000CAF7D00 M3 46L2820DT2-CA0   2D    10.0  N/A
DIMM 1     CE000000000000000C1F8200 M3 46L2820DT2-CA0   2D    10.0  N/A
DIMM 3     CE000000000000000C388200 M3 46L2820DT2-CA0   2D    10.0  N/A
# l1cmd env
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.19
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.25
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.04
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.32
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.47
          1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.47
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.07
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.29
PIMM0 12V bias    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.25
     Fuel SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.52
      Fuel CPU    Enabled  10%   1.44/  1.76  20%   1.28/  1.92    1.59
    PIMM0 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.49
PIMM0 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.29
  PIMM0 5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.04
  XIO 12V bias    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.12
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.04
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.47
  XIO 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.30
FAN 0  EXHAUST    Enabled          920         1222
FAN 1       HD    Enabled         1560         2220
FAN 2      PCI    Enabled         1120         1493
FAN 3    XIO 1    Enabled         1600         2220
FAN 4    XIO 2    Enabled         1600         2122
FAN 5       PS    Enabled         1349         2836
 0 NODE 0            Enabled    [Autofan Control]    75C/167F   42C/107F
 1 NODE 1            Enabled    [Autofan Control]    75C/167F   41C/105F
 2 NODE 2            Enabled    [Autofan Control]    75C/167F   30C/ 86F
 3 PIMM              Enabled    [Autofan Control]    75C/167F   49C/120F
 4 ODYSSEY           Enabled    [Autofan Control]    75C/167F   39C/102F
 5 BEDROCK           Enabled    [Autofan Control]    85C/185F   43C/109F
uname -aR
IRIX64 IRIS 6.5 6.5.30f 07202013 IP35
scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d1l0:  Disk          SEAGATE ST336753LW      0006
Device is  ready
/dev/scsi/sc1d6l0:  CD-ROM        TOSHIBA DVD-ROM SD-M17111005
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
Device is  ready
# l1cmd flash status
Flash image B currently booted
Image      Status        Revision    Built
  A     valid           1.26.5       12/15/2003 12:57:41
  B     default         1.26.5       12/15/2003 12:57:41
V12 on the left, V10 on the right.
V12<-- | --> V10
....with a little less flash.
gambonyx
Re: Fuel: 600MHz | V12 | 4GB | EMU Audio | GigE
Unread postby gambonyx » Tue Jul 19, 2011 5:30 pm
Very nice fuel!
They are like new,seals really well all 2.
This is close to full configuration.
We would like to ask another curiosity 'I'd like to know:In Hinv ram and premium type,the other fuel that you have the standard type, but this depends on the density 'of a type of RAM modules or and a different brand?
I've onyx2 of the standard type, but I also modules kingston 256mb, SGI original kits 1 of 16/4096mb origin. (I have only 12 of them) then the others are all to be 64mb but always sgi NEC I wanted to know if there is also the kind premium.
I was also interested to know if I can ask Onyx2 also on how to see the speed 'of the individual fans in real time, if there' some command like:
# l1cmd env
Thanks,
regards.
Unread postby recondas » Tue Jul 19, 2011 6:10 pm
gambonyx wrote:Very nice fuel!
Thanks
gambonyx wrote:We would like to ask another curiosity 'I'd like to know:In Hinv ram and premium type,the other fuel that you have the standard type, but this depends on the density 'of a type of RAM modules or and a different brand?I've onyx2 of the standard type, but I also modules kingston 256mb, SGI original kits 1 of 16/4096mb origin. (I have only 12 of them) then the others are all to be 64mb but always sgi NEC I wanted to know if there is also the kind premium.
The difference in premium and standard memory is essentially the same for your Onyx2 as it is for the later generation IP35 stuff. Premium memory includes additional logic called directory memory, necessary in larger Cray/NUMA linked configurations. In the O2K/Onyx2 directory memory is a physically separate entity that gets installed in the smaller memory slots (just below the standard DIMM slots on the O2k/Onyx2 node board). In the IP35 systems, the directory memory is incorporated into the standard DIMM itself. I've seen 512MB and 1GB Premium IP35 DIMMs, and there might also be 256MB premium DIMMs (but I've never seen one). So Premium memory serves no useful function on the Fuel and tower version of the Tezro (or an Onyx2 Deskside). The Fuel and Tezro Tower can't be NUMAlinked, and as far as SGI was concerned, a Rack-mount Tezro couldn't couldn't be configured with enough processors to need directory memory (though I suspect the processor limitation is more of a marketing distinction than a hardware limitation).
gambonyx wrote:I was also interested to know if I can ask Onyx2 also on how to see the speed 'of the individual fans in real time, if there' some command like # l1cmd env
Unfortunately, no. The Onyx2 Deskside uses an MSC (module system controller) rather than the L1 (level one) controller used by the IP35 family. While it doesn't report real-time temperatures or fan speeds, the MSC in your Onyx2 does monitor both, will display a warning via the MSC display and operating system, and will even shut the system down when pre-set levels are exceeded.
gambonyx
Unread postby gambonyx » Tue Jul 19, 2011 9:05 pm
Ok recondas, very good explanation, I understood everything, thanks a lot, things were important to me (I think also for many others) to know, you have been a great help as always. :)
Ryan Fox
Unread postby Ryan Fox » Tue Jul 19, 2011 11:53 pm
Great looking set of Fuels ^.^ They're almost new.. not a visible blemish or scratch...
I might pick up one of these off 'fleabay' , or bug Ian for one lol
MAYA, nut-
Unread postby jan-jaap » Wed Jul 20, 2011 1:08 am
You left the half rack too close to another system and Fuels started popping out ? :lol:
Ryan Fox
Unread postby Ryan Fox » Wed Jul 20, 2011 1:21 am
jan-jaap wrote:You left the half rack too close to another system and Fuels started popping out ? :lol:
What? The proverbial offsping of MIPS server rack meets PC? :P I wonder what you get when you combine a Compaq ProLiant
with a Tezro... -shudders-
MAYA, nut-
Unread postby recondas » Wed Jul 20, 2011 5:32 am
Ryan Fox wrote:What? The proverbial offsping of MIPS server rack meets PC? :P I wonder what you get when you combine a Compaq ProLiant with a Tezro... -shudders-
They're safely surrounded by IRIX-speaking relatives - there's a Tezro and an Onyx350 InfinitePerformance inside the short rack, and an Onyx300 InfiniteReality in the tall rack (it's just behind and at a right-angle to the short rack). The only non-sgi system in the room is a very-light weight linuxpc that I use as a NFS/L3/Synergy/DINA server, and he keeps his distance (not to mention being headless most of the time).
I'd suspect the Tezro and O350s - they only recently started cohabitating inside the short rack.. :D
[[C|-|E]]
Unread postby [[C|-|E]] » Wed Jul 20, 2011 8:05 am
They are really nice, both of them :). The Fuel is the MIPs SGI I like the less (do not ask me why, maybe because of the PC-like case they have) but those guys of yours look great!
Image _Betty Blue_
R12000A 400 Mhz; 1 Gb RAM; 72 Gb 15K HDD; IRIX 6.5.29
CrystalEyes; Dial Box; O2Cam "ZEYE"; external Toshiba SD-M1711 DVD-ROM; Octane speakers;
Lock bar; SGI microphone.
Mods: PSU Noctua fan; internal Toshiba SD-M1401 DVD-ROM; Adaptec AIC-7880P SCSI card.
_REKIEM_I7_
Seasonic X 1250W PSU / Intel I7 2600k 4 x 5,00 Ghz / 2 x Gainward 2Gb GTX 560Ti Phantom 2 / 32 Gb DDR3 / Intel x25-M 160 Gb SSD and 10 extra Tb
_REKIEM_T5400_
875W PSU / 2 x Intel Xeon Harpertown 4 x 3,33 Ghz / 1 x EVGA Geforce 4Gb GTX 980 Supercloked / 32 Gb DDR2 667 ECC / Samsung 840 Series Pro 128GB SSD and 3 extra Tb
_Raspberry Pi_
Unread postby recondas » Wed Jul 20, 2011 9:38 am
[[C|-|E]] wrote:They are really nice, both of them :).
Thanks - I didn't originally plan to end up with two, but could pass these by - largely because they both have late-production components; 460W power supplies, 030-1707-004 system boards, and even SD-M1711 DVD drives. Some early production Fuels had 430W power supplies and 030-1707-003 system boards. The 430W power supplies received some notoriety for premature failure, and the -003 system boards are prone to developing failures with the ICs that control environmental monitoring.
Though these Fuels came from different sources, I found it interesting that the local brick serial numbers and local system serial numbers (MAC addresses) didn't appear to be all that far apart - NCL381 / 08:00:69:10:72:F2 on the V10, and NCL405 / 08:00:69:10:72:D9 on the V12.
[[C|-|E]] wrote:The Fuel is the MIPs SGI I like the less (do not ask me why, maybe because of the PC-like case they have) but those guys of yours look great!
The Fuel offers a very capable IRIX system for not too much money, especially when compared to other graphics-capable IP35-generation hardware (like the Tezro, O350 or any of the IP35-based InfiniteReality systems). There are some advantages to IP35-era hardware - faster processors, memory and I/O access - native U160 LVD SCSI, the option to use USB keyboards/mice, firewire access to compact flash cards, SATA hard drives, GigE networking, and a native DVI graphics port (so you can stop running that LCD panel in analog mode).
060-0202-001 - Fuel 460W power supply
030-1707-004 - Fuel system board
030-1730-002 - 600MHz Fuel Processor daughter board
[[C|-|E]]
Unread postby [[C|-|E]] » Wed Jul 20, 2011 10:50 am
recondas wrote:...the option to use USB keyboards/mice, firewire access to compact flash cards, SATA hard drives, GigE networking, and a native DVI graphics port (so you can stop running that LCD panel in analog mode).
That is something really nice. I mean, I am very happy with my O2 but connecting the computer with the rest of the world is always a bit tricky. Basically, I have to use the LAN all the time because it lacks USB, firewire, etc, at it is only 100 megabit/second. Also, DVI support is highly desirable. At the moment I am thinking what to do about this, maybe I should install a firewire card and connect a firewire hard disc drive to the girl. Doing this I could exchange very large files more easily. A gigabit card is also an option... :).
Image _Betty Blue_
_REKIEM_I7_
_REKIEM_T5400_
_Raspberry Pi_
Unread postby hamei » Wed Jul 20, 2011 11:08 pm
[[C|-|E]] wrote:That is something really nice. I mean, I am very happy with my O2 but connecting the computer with the rest of the world is always a bit tricky. Basically, I have to use the LAN all the time because it lacks USB, firewire, etc, at it is only 100 megabit/second. Also, DVI support is highly desirable. At the moment I am thinking what to do about this, maybe I should install a firewire card and connect a firewire hard disc drive to the girl. Doing this I could exchange very large files more easily. A gigabit card is also an option... :).
Ryan Fox
Unread postby Ryan Fox » Thu Jul 21, 2011 12:06 am
Use the 'search' function Luke... :lol:
MAYA, nut-
[[C|-|E]]
Unread postby [[C|-|E]] » Thu Jul 21, 2011 2:45 am
Hehe, I was already reading the posts concerning firewire and gigabit cards in the O2, but thank you! :D.
Image _Betty Blue_
_REKIEM_I7_
_REKIEM_T5400_
_Raspberry Pi_
Unread postby recondas » Thu Jul 21, 2011 3:08 pm
Added photos of the power supply, processor and system boards (scroll back a few posts).
