Fuel: 600MHz | V10 | 1GB | EMU Audio | gigE | DDS4
Unread postby recondas » Fri Jul 15, 2011 3:54 pm
hinv -vm
            IP34 Board: barcode NCL381     part 030-1707-004 rev -A
        IP34PIMM Board: barcode NCL234     part 030-1730-002 rev -E
       ASTODYV10 Board: barcode NAT111     part 030-1826-001 rev -B
1 600 MHZ IP35 Processor
Main memory size: 3072 Mbytes
Memory at Module 001c01/Slot 0: 1536 MB (enabled)
  Tape drive: unit 6 on SCSI controller 0: DAT
Graphics board: V10
Gigabit Ethernet: eg0, module 001c01, pci_bus 2, pci_slot 2, firmware version 0.0.0
Iris Audio Processor: version EMU revision A3, number 1
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 2
  PCI Adapter ID (vendor 0x1102, device 0x0004) PCI slot 3
  PCI Adapter ID (vendor 0x1102, device 0x7003) PCI slot 3
  PCI Adapter ID (vendor 0x1102, device 0x4001) PCI slot 3
USB controller: type OHCI
/usr/gfx/gfxinfo -v
        Managed (":0.0") 1600x1200
        BUZZ version B.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1600 pixels, 1200 lines, 59.83Hz (1600x1200_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
# l1cmd serial all
Local System Serial Number      EEPROM        08:00:69:10:72:F2
Local Brick Serial Number       EEPROM        NCL381
Reference Brick Serial Number   NVRAM         NCL381
NODE        IP34            NCL381         030_1707_004          A    00
MAC         MAC ADDRESS     NA             NA                    NA   NA
PIMM        IP34PIMM        NCL234         030_1730_002          E    00
XIO         ASTODYV10       NAT111         030_1826_001          B    00
DIMM 0     CE000000000000000C44CD02 M3 46L3313ET3-CA0   3E    10.0  N/A
DIMM 2     CE000000000000000C3B0000 M3 47L6423DT2-CA0   3E    10.0  N/A
DIMM 1     CE000000000000000C39CD02 M3 46L3313ET3-CA0   3E    10.0  N/A
DIMM 3     CE000000000000000C730100 M3 47L6423DT2-CA0   3E    10.0  N/A
# l1cmd env
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.19
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.19
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.02
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.32
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.47
          1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.47
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.10
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.27
PIMM0 12V bias    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.19
     Fuel SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.52
      Fuel CPU    Enabled  10%   1.44/  1.76  20%   1.28/  1.92    1.59
    PIMM0 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.48
PIMM0 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.27
  PIMM0 5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.07
  XIO 12V bias    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.06
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.02
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.46
  XIO 3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.30
FAN 0  EXHAUST    Enabled          920         1155
FAN 1       HD    Enabled         1560         2250
FAN 2      PCI    Enabled         1120         1591
FAN 3    XIO 1    Enabled         1600         2596
FAN 4    XIO 2    Enabled         1600         2481
FAN 5       PS    Enabled         1349         3183
 0 NODE 0            Enabled    [Autofan Control]    75C/167F   44C/111F
 1 NODE 1            Enabled    [Autofan Control]    75C/167F   44C/111F
 2 NODE 2            Enabled    [Autofan Control]    75C/167F   35C/ 95F
 3 PIMM              Enabled    [Autofan Control]    75C/167F   53C/127F
 4 ODYSSEY           Enabled    [Autofan Control]    75C/167F   44C/111F
 5 BEDROCK           Enabled    [Autofan Control]    85C/185F   46C/114F
uname -aR
IRIX64 IRIS 6.5 6.5.30f 07202013 IP35
scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d1l0:  Disk          SEAGATE ST336753LW      0006
Device is  ready
/dev/scsi/sc0d3l0:  Disk          SEAGATE ST3300007LW      0003
Device is  ready
/dev/scsi/sc0d6l0:  Tape          SEAGATE DAT    06240-XXX8160
Device is ready
/dev/scsi/sc1d6l0:  CD-ROM        TOSHIBA DVD-ROM SD-M17111005
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
Device is ready
1cmd flash status
Flash image B currently booted
Image      Status        Revision    Built
  A     valid           1.26.5       12/15/2003 12:57:41
  B     default         1.26.5       12/15/2003 12:57:41
Titox
Re: Fuel: 600MHz | V10 | 1.5GB | EMU Audio | gigE | DDS4
Unread postby Titox » Sat Jul 16, 2011 12:32 am
Nice machine. I see you have a Seagate DAT drive. I thought only Sony models were compatible with SGI. Can anyone add to the Fuel Hardware aggregator a list of compatible DDS's?
Thank you
http://www.f3b.es
http://unixverse.blogspot.com
gambonyx
Unread postby gambonyx » Sat Jul 16, 2011 3:27 am
Nice fuel!
I have a question to ask, but the Rams should not be in ascending order on the bank?
Does nothing if the bank 0/1 is - 256 and the bank 2/3 - 512?
Unread postby recondas » Sat Jul 16, 2011 4:27 am
Titox wrote:Nice machine.
Thanks
Titox wrote:I see you have a Seagate DAT drive. I thought only Sony models were compatible with SGI. Can anyone add to the Fuel Hardware aggregator a list of compatible DDS's?
That's easy enough - they're *all* compatible (with a minimal amount of end-user effort). This nekowiki article explains the basic process of modifying or adding to IRIX's list of tape definitions (or drivers. If you prefer). There's also a list of definitions for a few higher capacity tape drives (LTO, SDLT and DTF) in this thread: viewtopic.php?f=3&t=16724885
gambonyx wrote:Nice fuel!
Thanks
gambonyx wrote:I have a question to ask, but the Rams should not be in ascending order on the bank? Does nothing if the bank 0/1 is - 256 and the bank 2/3 - 512?
As long as they're installed with a matching pair in either bank, size order isn't an issue (take a look at the memory configuration rules in the Fuel User's Guide), and the Fuel seems pretty happy with the arrangement - it even announces it's "running in DDR mode" during power-on diagnostics:
Running in DDR mode
Discovering local IO ......................             DONE
Discovering NUMAlink connectivity .........             DONE
Found 1 objects (1 hubs, 0 routers) in 30360 usec
Intializing any CPUless nodes..............             DONE
BASEIO PROM Monitor SGI Version 6.210  built 02:30:38 PM Aug 26, 2004 (BE64)
1 CPUs on 1 nodes found.
PS/2 Keyboard & Mouse diagnostics
    Found mouse on port 0
    Found keyboard on port 1
PS/2 Keyboard & Mouse diagnostics passed
Graphics diagnostics
        Board version 1 - Buzz revision 2B
        On board sdram size: 32 Mb
        Cas latency: CAS 3
        4 banks by sdram module
Device passed diagnostics
Walking SCSI Adapter 0, (pci id 1)
1+ Device Vendor Product: SEAGATE ST336753LW
2- 3- 4- 5- 6+ Device Vendor Product: SEAGATE DAT    06240-XXX
7- 8- 9- 10- 11- 12- 13- 14- 15- = 2 device(s)
Walking SCSI Adapter 1, (pci id 1)
1- 2- 3- 4- 5- 6+ Device Vendor Product: TOSHIBA DVD-ROM SD-M1711
7- 8- 9- 10- 11- 12- 13- 14- 15- = 1 device(s)
GL1zdA
Unread postby GL1zdA » Sat Jul 16, 2011 4:30 am
Which EMU card is it? I assume it's EMU10K2 based (Audigy 2 ZS like)?
Unread postby recondas » Sat Jul 16, 2011 4:36 am
GL1zdA wrote:Which EMU card is it? I assume it's EMU10K2 based (Audigy 2 ZS like)?
It's an SB0090 - a first generation Audigy Platinum EX: viewtopic.php?f=3&t=16725195&#p7340993
gambonyx
Unread postby gambonyx » Sat Jul 16, 2011 11:25 pm
recondas wrote:As long as they're installed with a matching pair in either bank, size order isn't an issue (take a look at the memory configuration rules in the Fuel User's Guide), and the Fuel seems pretty happy with the arrangement - it even announces it's "running in DDR mode" during power-on diagnostics:
Ok!I got it! This excerpt from the manual page of the fuel that I have indicated, that's why '
In practice one must have the same density 'memory on both the banks,
So your reads 768MB DIMM per pair of properly.
256+512 dimm pair1 /256+512 dimm pair2 ;)
The following configuration rules apply to the memory banks and DIMMs in your system:
At least one DIMM pair must be populated.
DIMMs in the same DIMM pair must be the same density. For example, if DIMM 0 is 512 MB, then DIMM 2 must be 512 MB.
DIMMs must be installed in pairs.
