Onyx2 Deskside, 4x400MHz R12K, IR3, 8GB RAM
Black Cardinal
Unread postby Black Cardinal » Sun Jan 02, 2011 7:15 pm
Bringing this thing home from the freight terminal in my pickup truck caused some eye-rolling by my wife, but fortunately I had already rearranged the computer room to make space for it. It's in pretty good physical shape. Someone had apparently tried to force the DG5-2 board in at an angle and bent a few pins on the midplane, but I was able to straighten those with a probe tip from my logic analyzer and some patience.
It's a modest configuration but a lot of the fun will be in upgrading the machine! :D
% hinv -vm
        MODULEID Board: barcode K0010960   part              rev
            IP31 Board: barcode DLF573     part 030-1255-003 rev  A
        IP31PIMM Board: barcode FXV748     part 030-1313-002 rev  A
      4P1G5_MPLN Board: barcode DNA039     part 013-1839-001 rev  E
          GE14-4 Board: barcode GGB287     part 030-1129-002 rev  H
          BASEIO Board: barcode EDH395     part 030-0734-002 rev  J
             MIO Board: barcode FZY355     part 030-0880-003 rev  F
2 250 MHZ IP27 Processors
FPU: MIPS R10010 Floating Point Chip Revision: 3.4
CPU 0 at Module 1/Slot 1/Slice A: 250 Mhz MIPS R10000 Processor Chip (enabled)
  Processor revision: 3.4. Scache: Size 4 MB Speed 250 Mhz  Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 250 Mhz MIPS R10000 Processor Chip (enabled)
Main memory size: 1024 Mbytes
Memory at Module 1/Slot 81: 1024 MB (enabled)
  Bank 0 contains 128 MB (Standard) DIMMS (enabled)
  Bank 1 contains 128 MB (Standard) DIMMS (enabled)
  Bank 2 contains 128 MB (Standard) DIMMS (enabled)
  Bank 3 contains 128 MB (Standard) DIMMS (enabled)
  Bank 4 contains 128 MB (Standard) DIMMS (enabled)
  Bank 5 contains 128 MB (Standard) DIMMS (enabled)
  Bank 6 contains 128 MB (Standard) DIMMS (enabled)
  Bank 7 contains 128 MB (Standard) DIMMS (enabled)
  Tape drive: unit 5 on SCSI controller 0: unknown
IOC3 serial port: tty1
IOC3 serial port: tty2
IOC3 serial port: tty3
IOC3 serial port: tty4
Graphics board: InfiniteReality2
Iris Audio Processor: version RAD revision 7.0, number 1
  PCI Adapter ID (vendor 4265, device 3) pci slot 6
  PCI Adapter ID (vendor 4265, device 5) pci slot 7
IOC3 external interrupts: 1
IP27prom in Module 1/Slot n1: Revision 6.111
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.111
% /usr/gfx/gfxinfo -v
   Display has 2 channels
   4 GEs (of 4), occmask = 0x0f
   1 RM7 board (of 1) 1/0/0/0
   Texture Memory: 64MB/-/-/-
   Medium pixel depth
   32K cmap
   brd: 80160a04 3020c06/-/-/- f9391002
   rm0: 15032057 15431057
         4631057 1/1/1/1
         4d31057 2/2/2/2/2/2/2/2
         4938057 4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4/4
    dg: 05532057
         5838057 1/1/1/1
         5631057 1/1
   GE:   NIC #:      0000.0018.fc05 (family: 0b)
         Serial #:   GGB287
         Part #:     030-1129-002
   KT:   No NIC serial number available.
   RM0:  NIC #:      0000.000e.5f88 (family: 0b)
         Serial #:   EEA155
         Part #:     030-1054-001
   TM0:  NIC #:      0000.000e.4193 (family: 0b)
         Serial #:   EEA183
         Part #:     030-1053-001
   RM1:  No NIC serial number available.
   TM1:  No NIC serial number available.
   RM2:  No NIC serial number available.
   TM2:  No NIC serial number available.
   RM3:  No NIC serial number available.
   TM3:  No NIC serial number available.
   BP:   No NIC serial number available.
   DG:   NIC #:      0000.001f.7a34 (family: 0b)
         Serial #:   GTP669
         Part #:     030-1055-001
   DGOPT:No NIC serial number available.
    Video Output: 1280 pixels, 1024 lines, 72.00Hz (1280x1024_72.vfo)
    Video Format Flags:  (none)
    Sync Output(s):
     Composite sync on Green
     Composite TTL sync on Aux 0
    Using Gamma Map 0
Onyx2 IR2
Last edited by Black Cardinal on Thu May 11, 2017 10:46 pm, edited 3 times in total.
Black Cardinal
bigD
Re: Onyx2 Deskside, 2x250MHz R10K, IR2, 1GB RAM
Unread postby bigD » Sun Jan 02, 2011 7:39 pm
Good looking machine, man!
:Onyx2: :Indigo2: :O3x0:
zski128
Unread postby zski128 » Sun Jan 02, 2011 7:49 pm
Black Cardinal wrote:Bringing this thing home from the freight terminal in my pickup truck caused some eye-rolling by my wife
Ha, been there as well. That machine is in great shape. Nice find! Seems as though the east coast if flush with O2k desksides, would love to have one of these.
:O2000: :Indigo: :Indy: x2 :Octane: :O2: :Fuel:WIP :1600SW:x2
Unread postby recondas » Mon Jan 03, 2011 3:42 pm
Very nice looking Deskside - congratulations.
On the odd chance you don't already know <and just ok sound quality meets your needs>, there's a DC power jack on the back of the IO6G to power a set of Octane speakers <a Tezro has the same set up too>.
Black Cardinal
Unread postby Black Cardinal » Mon Jan 03, 2011 11:50 pm
Thanks! For fun, here's another picture, in a similar vein as a previous one (http://forums.nekochan.net/download/file.php?id=2820967&mode=view) I posted in my other hinv thread. My oldest son wanted to pose with the "big computer," too. Now he's almost 4 (he was 2-1/2 in the previous one).
He's been bugging me to finish getting it set up with its own monitor and keyboard so we can play 2-person tank games (bz, bzflag) over the LAN.
Black Cardinal
smj
Unread postby smj » Tue Jan 04, 2011 1:25 am
Nice snug setup and a good looking machine. The purple Indigo2 next to it seems to bring out the plum in the Onyx2 skins...
Ryan Fox
Unread postby Ryan Fox » Wed Jan 05, 2011 1:29 am
After the second one she simply just gave up lol
MAYA, nut-
Black Cardinal
Unread postby Black Cardinal » Wed Jan 05, 2011 9:38 am
smj wrote:Nice snug setup and a good looking machine. The purple Indigo2 next to it seems to bring out the plum in the Onyx2 skins...
Thanks, although it's a little too snug. I have to really watch the room temperature and keep it below 73 deg F or else the unit kicks into fastfan mode. Right now it's in an upstairs bedroom, and keeping this room cool enough is difficult. In the early evening I can just close the door and open the window, but one of my 2 year-olds sleeps in there and once he's in bed I have to close the window.
I really need to move my desk over a few inches and make some clearance around the Onyx2, but that's a huge undertaking...
If I have one complaint about the Onyx2, it's that it turned what was a cool-looking Indigo2 next to it into something that almost looks like a toy! :lol:
If anyone is interested in some more power consumption numbers, I measured the Onyx2's power draw with a Kill-a-Watt. It draws about 630W when idle, and 640W under load. Power factor was always darn near 1 when the key was in the On position. I'm running it on a 15A 120V circuit shared with several other computers and a laser printer, so I was happy to discover it drew much less than I was expecting. Of course, this is mostly because of the limited hardware installed.
Black Cardinal
Unread postby jan-jaap » Wed Jan 05, 2011 11:58 am
Just install a second node board, fill everything up with 512MB RAM kits (the 'sandwich model') add, a second RM and some misc options and watch that power consumption rise to ~ 950W 8-)
Do I get that right, you run an Onyx2 in a bedroom while your 2year old is sleeping there? Wow, I have to tell that to my wife :lol:
Black Cardinal
Unread postby Black Cardinal » Wed Jan 05, 2011 12:03 pm
jan-jaap wrote:Do I get that right, you run an Onyx2 in a bedroom while your 2year old is sleeping there? Wow, I have to tell that to my wife :lol:
Yeah, the roar of fans actually seems to lull him to sleep. :)
We have fraternal twins, and keep them in separate bedrooms so they don't keep each other awake. This one sleeps in our computer room, and my wife has her own computer in addition to the several that I own. He's pretty used to it.
Black Cardinal
Black Cardinal
Unread postby Black Cardinal » Sat Jan 29, 2011 12:50 pm
Updated hinv. The R10K's have been replaced by a 400MHz R12K node board, and the RAM has been upgraded to 2GB. The GUI is noticeably snappier, and according to my Kill-a-Watt it actually dropped the power consumption to 584W under load. I presume this is because of a process shrink relative to the R10K, and the denser DIMMs drawing less current.
I have another 400MHz node board loaded with another 2GB ready to install but I need to deal with a minor mounting hardware issue first.
% hinv -vm
            IP31 Board: barcode KRJ020     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode KRJ427     part 030-1423-002 rev  F
2 400 MHZ IP27 Processors
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
CPU 0 at Module 1/Slot 1/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 3.5. Scache: Size 8 MB Speed 266 Mhz  Tap 0xa
CPU 1 at Module 1/Slot 1/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 2048 Mbytes
Memory at Module 1/Slot 81: 2048 MB (enabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 6
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 7
HUB in Module 1/Slot 1: Revision 6 Speed 100.00 Mhz (enabled)
IP27prom in Module 1/Slot n1: Revision 6.94
IO6prom on Global Master Baseio in Module 1/Slot io1: Revision 6.150
Last edited by Black Cardinal on Sat Jan 29, 2011 1:01 pm, edited 1 time in total.
Black Cardinal
Geoman
Unread postby Geoman » Sat Jan 29, 2011 1:01 pm
~0.6 kW is not that much for this kind of machine imho
Black Cardinal
Unread postby Black Cardinal » Sat Feb 12, 2011 1:51 pm
Now with 4x400MHz R12K processors and 5GB RAM. Thanks go to recondas for some mounting hardware I needed to get both of these node boards installed. I also had some issues getting the second node board running, but I found the answers I needed by searching the forum. It was the typical POD logs issue.
Power consumption is up to 713W at idle, 770W under heavy CPU/graphics load.
Forum question: How do I edit the thread title to match the new configuration? I've seen it done by others before but I can't figure out how. Editing the subject for this post and the first post don't seem to do it.
            IP31 Board: barcode KRT708     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode KRT237     part 030-1423-002 rev  G
4 400 MHZ IP27 Processors
CPU 0 at Module 1/Slot 2/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 1 at Module 1/Slot 2/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 1/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 1/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 5120 Mbytes
Memory at Module 1/Slot 82: 2560 MB (enabled)
Memory at Module 1/Slot 81: 2560 MB (enabled)
HUB in Module 1/Slot 2: Revision 6 Speed 100.00 Mhz (enabled)
IP27prom in Module 1/Slot n2: Revision 6.94
IO6prom on Global Master Baseio in Module 1/Slot io2: Revision 6.150
Black Cardinal
Unread postby recondas » Sat Feb 12, 2011 5:24 pm
Black Cardinal wrote:Forum question: How do I edit the thread title to match the new configuration?
I don't get quite the same edit panel you do, but to the best of my pre-moderator recollection the title changing bits were the same. You'll have to edit the initial post to change the title of the thread.
In the top left panel of the 'Edit post' window should be selections for "Delete post", "Post icon", "Subject" and "Message body". The field to the right of "Subject" should be a editable text box containing the thread title. Changing the contents for that text box will change/update the thread title.
ratfink
Unread postby ratfink » Sat Feb 12, 2011 5:44 pm
If you have a way to measure power consumption, I'd be curious to see the consumption with the power supply on, but the key off. I know some SGIs are pretty high (something like 30w for a powered off Octane.)
Geof
:O2000: :Fuel: :Octane: :Octane2: :O2: +MacPro +Sun Ultra 40 +G4 MDD +G4 Cube +G3 B&W +MacBook Air +iPad +Amiga 3000 +Amiga 2000 Toaster
